Walmart and Valvoline
by Bullwinkle007. 01/22/19 09:10 PM
Getting Our Kicks On Route 66
by 2015_PSD. 01/22/19 08:40 PM
Uploading a short film clip from an IPhone.
by Snagglefoot. 01/22/19 07:52 PM
Purolator L34631 (torn media)
by LDM. 01/22/19 07:51 PM
THIS close to getting a VDB today at TPA
by 14Accent. 01/22/19 07:48 PM
Supco Appliance Parts.
by George7941. 01/22/19 07:36 PM
Unusual Jury summons.
by Chris142. 01/22/19 06:31 PM
Vibration feeling after new tires installed?
by MONKEYMAN. 01/22/19 05:51 PM
Sudden Shake - ‘18 Accord
by Throt. 01/22/19 05:43 PM
05 Ford 500 Intake hole - melted
by Geauxtiger. 01/22/19 05:41 PM
How's K&N 1004 on Kia/Hyundai GDI
by SlavaB. 01/22/19 05:18 PM
more PSD woes with cold weather
by Donald. 01/22/19 05:10 PM
Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
57 registered members (anndel, AttackingMid, bbhero, Bryanccfshr, AdRock, 9 invisible), 1,000 guests, and 39 spiders.
Topics297,006
Posts4,963,343
Members67,013
Most Online2,821
Jan 21st, 2019
Thread locker to keep un-torqued screw in place #4760465
05/17/18 09:46 PM
05/17/18 09:46 PM
Chicago, IL
EdwardC Offline OP
EdwardC  Offline OP
Chicago, IL
I have some machine screws that I need to screw into a metal structure (threaded). The machine screw needs to tighten down and hold another piece of metal, but I don't want it tight since I want the middle piece to be able to pivot and spin as needed. I feel that a nylon lock nut would be ideal for what I want (if the other side of the screw was accessible), but it's not.
So my question, is there a certain type of thread locking compound that would work best at keeping a machine screw locked in place while that screw isn't torqued at all? It's a fairly high vibration assembly, so I'm afraid that if I don't do anything, the screw will back out. I'd prefer it to be removable, so my first choice was to use a medium thread locker, or Vibra-tite VC-3, which I think both would be adequate, but I'm curious if there's a better product out there.
Thanks, I hope my description made sense!
Re: Thread locker to keep un-torqued screw in place [Re: EdwardC] #4760469
05/17/18 09:51 PM
05/17/18 09:51 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Use a shoulder bolt and a ny-lok nut.
Thick oil is better grin2
Re: Thread locker to keep un-torqued screw in place [Re: EdwardC] #4760477
05/17/18 10:00 PM
05/17/18 10:00 PM
Chicago, IL
EdwardC Offline OP
EdwardC  Offline OP
Chicago, IL
Thanks, I hadn't thought about swapping out the fastener, a shoulder bolt of appropriate length isn't a bad idea at all. I don't have access to the other side (basically a tapped blind hole), so I can't use any kind of nut (or else I'd just throw a normal nut on as a jam nut).
With a shoulder bolt, I could properly torque it down. I might be wrong, but my assumption was that most common thread lockers relied on the fastener being properly torqued to work right.
Re: Thread locker to keep un-torqued screw in place [Re: EdwardC] #4760490
05/17/18 10:27 PM
05/17/18 10:27 PM
SD
zrxkawboy Online content
zrxkawboy  Online Content
SD
Vibra-tite sounds ideal for this situation.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Thread locker to keep un-torqued screw in place [Re: EdwardC] #4760564
05/18/18 04:33 AM
05/18/18 04:33 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
+1 on the shoulder bolt, a full threaded machine screw with loctite is the wrong fastener for this job. You can use thin nylon washers to take most of the play out and have smoother movement.
Re: Thread locker to keep un-torqued screw in place [Re: EdwardC] #4760690
05/18/18 07:23 AM
05/18/18 07:23 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
+2 on shoulder bolt.
I use PVA wood glue on clean threads. Always comes loose when needed. Holds pretty well while in place. Poor mans Lock-Tite laugh
Re: Thread locker to keep un-torqued screw in place [Re: EdwardC] #4760749
05/18/18 08:00 AM
05/18/18 08:00 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Multiple options:
-Those already suggested
-Stake the top of the bolt / fastener
-Use Nail Polish (=lacquer and pigment, but can be borrowed or buy a close-out bottle at the pharmacy for $1) over the top / side of the fastener / bolt threads
-Solder (permanent, essentially) with a heat gun instead of soldering iron providing the heat
-Epoxy (a small ball of putty epoxy would be perhaps ideal at just one point of the top of the fastener / thread interface, could just grind off that part of the threads to remove the fastener, the remaining threads would allow removal / re-assembly)
I'm sure there are other options.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Thread locker to keep un-torqued screw in place [Re: EdwardC] #4760778
05/18/18 08:27 AM
05/18/18 08:27 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
polythene film from a bag of appropriate thickness.
(Poor man's Nylock)
Re: Thread locker to keep un-torqued screw in place [Re: EdwardC] #4761192
05/18/18 03:23 PM
05/18/18 03:23 PM
Chicago, IL
EdwardC Offline OP
EdwardC  Offline OP
Chicago, IL
Thanks everyone! I have several of these to assemble, so I may try a few different methods you guys listed and see how it turns out. I think my first trial is to see if I can get the proper length shoulder bolt.
I actually really do like the idea of thin nylon washers, I want the part to be able to turn, but I don't want or need it to turn super freely, a little resistance would be perfect actually.
Thanks again!
