Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
120 registered members (2015_PSD, 87sammy, 2010Civic, 3311, 01rangerxl, 7 invisible), 1,794 guests, and 55 spiders.
Topics286,088
Posts4,902,367
Members67,560
Most Online2,967
Mar 10th, 2019
PB Blaster and stuck spark plug, fixed #4760355
05/17/18 08:43 PM
05/17/18 08:43 PM
Idaho
sprite1741 Offline OP
Idaho
Had a stuck plug on number 2 on the 2.2 aluminum head. I knew it was not over torqued since I installed it with never seize and I just snug them up. Not sure what happened but it would unscrew about a quarter a turn and stop. Hit it with PB blaster and slowly worked back and forth with added blaster. Took about an hour letting it sit, working it again and again. It came out and the threads are fine. Just an FYI for anyone this happens to. Don't panic and think the worse. Cold engine, no heat. All the others were fine.
2005 Grand Prix GXP 5.3L Supertech Synthetic Dexos 5w30 Fram Ultra 3506
1986 Dodge Lancer 2.2L Turbo, Supertech Synthetic 10w30 Fram Ultra 3614
Re: PB Blaster and stuck spark plug, fixed [Re: sprite1741] #4760380
05/17/18 08:57 PM
05/17/18 08:57 PM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
Sweet. I always think the worse. Glad it worked out for you.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: PB Blaster and stuck spark plug, fixed [Re: sprite1741] #4760387
05/17/18 09:01 PM
05/17/18 09:01 PM
out there
spasm3 Offline
spasm3  Offline
out there
Back and forth is the key. Probably carbon on the exposed threads. Back and forth knocks the carbon loose a bit at a time and avoids stripping the threads.
Good job!
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: PB Blaster and stuck spark plug, fixed [Re: sprite1741] #4760391
05/17/18 09:06 PM
05/17/18 09:06 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
That makes sense .
Congrats on the win ! :-)
Wyr
God bless
Re: PB Blaster and stuck spark plug, fixed [Re: sprite1741] #4760400
05/17/18 09:12 PM
05/17/18 09:12 PM
midwest
JamesBond Online content
JamesBond  Online Content
midwest
Did the pb-blaster go down past the plug? Good job getting it out.
Re: PB Blaster and stuck spark plug, fixed [Re: sprite1741] #4760415
05/17/18 09:26 PM
05/17/18 09:26 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
What brand was the plug?
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: PB Blaster and stuck spark plug, fixed [Re: JamesBond] #4760442
05/17/18 10:03 PM
05/17/18 10:03 PM
Idaho
Idaho
Yes it did, the top of the piston was very wet. I used a lot of blaster. I put a piece of paper towel taped to a dowel and soaked it up. Wanted to make sure it was PB and not coolant.
Re: PB Blaster and stuck spark plug, fixed [Re: sprite1741] #4760501
05/18/18 12:05 AM
05/18/18 12:05 AM
USA
oldhp Offline
oldhp  Offline
USA
Or let the engine cool over night. Next morning start the engine and pour MMO into TB, PCV etc. Shut it off and let it sit. Now the MMO, PB-Blaster etc is on the inside threads of the plug soaking the carbon loose.
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: PB Blaster and stuck spark plug, fixed [Re: sprite1741] #4760680
05/18/18 08:16 AM
05/18/18 08:16 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
The back and forth in increasing arcs is SOP for any stuck bolt. The motion forces the lube further down the threads.
Thick oil is better grin2
Re: PB Blaster and stuck spark plug, fixed [Re: andyd] #4760731
05/18/18 08:50 AM
05/18/18 08:50 AM
Idaho
Idaho
Yes, I took it slow and didn't try to force it. 32 year old aluminum heads and steel plug. First time this ever happened. I had those plugs out 3 years ago. The plug didn't look fouled so still a mystery why just one, but it's an old engine. The threads were really gunked up, black carbon and anti-seize. Maybe I used too much. Anyway I cleaned up everything and installed new plugs, wires, cap and rotor. All good.
Re: PB Blaster and stuck spark plug, fixed [Re: sprite1741] #4760744
05/18/18 08:59 AM
05/18/18 08:59 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
As stated, lube and go back and forth as necessary. Be kind to your machine and forget rushing any "nothing job".
To oldhp: If your process works, GREAT. It seemed a little involved to me as I don't think the MMO would cooperate so effectively.
My guess is that it'd just burn off like fuel:air mixture would.
Cheers,
Re: PB Blaster and stuck spark plug, fixed [Re: sprite1741] #4760763
05/18/18 09:08 AM
05/18/18 09:08 AM
Waterloo, ON
Bluestream Offline
Bluestream  Offline
Waterloo, ON
2000 VW Beetle 1.8T M5
2006 Pathfinder 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
