Elf 4T moto tech 10w50 is good?
by firstime911. 01/15/19 09:25 PM
New Champ Filter
by CapitalTruck. 01/15/19 08:30 PM
19 Elantra vs corolla vs civic vs 18 Mazda 3
by wolf_06. 01/15/19 07:28 PM
New guage cluster need to be programed?
by callbay. 01/15/19 07:28 PM
good brand of inner tie rod?
by motor_oil_madman. 01/15/19 07:27 PM
Look at this blast from the past!
by SubieRubyRoo. 01/15/19 05:50 PM
Factory service manuals?
by buck91. 01/15/19 05:49 PM
Road Trip - Drive My Own Car or Rent?
by The Critic. 01/15/19 05:23 PM
‘19 GTI specs 0w-20 508 00
by LotI. 01/15/19 05:22 PM
Fram TG11955
by advocate. 01/15/19 03:03 PM
Bosch Steeltech = Wix?
by Black_Thunder. 01/15/19 02:44 PM
CVT and 6 speed automatic
by jerseyguy123. 01/15/19 01:56 PM
Hypothetical - X6M vs X5M vs AMG GLE63
by OVERKILL. 01/15/19 01:48 PM
2001 dodge neon coolant reservoir
by mobilaltima. 01/15/19 01:38 PM
Washing under car at self-service wash (salt)
by TmanP. 01/15/19 01:19 PM
Full Synthetic High Mileage in 40w range.
by FlyPenFly. 01/15/19 12:41 PM
2018 Silverado 3500HD TPMS Re-Learn
by Phishin. 01/15/19 12:36 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
110 registered members (2003f7, 97prizm, 1.8Tango, AdditiveOCD, AdRock, 28oz, 11 invisible), 1,741 guests, and 34 spiders.
Topics296,610
Posts4,955,817
Members66,950
Most Online2,577
Jan 14th, 2019
Drain it or keep it? #4760174
05/17/18 04:35 PM
05/17/18 04:35 PM
MURICA
maverickfhs Offline OP
MURICA
For 06 Civic, I reused my A02 OEM Honda Oil filter from last time. Drained old oil and filled it with Valvoline 5W20 synthetic blend.
Currently OLM says 50% and oil has 4100 miles and 5 months old; including short trips as well as 1-2 hrs highway speed drives, but overall combination of both.
While Oil filter has ~10K miles and 13 months old.
1-Should I change oil and filter now? Or
2- Continue another 3000-3500 miles and then replace both in fall?
Your thoughts or advice?
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
Re: Drain it or keep it? [Re: maverickfhs] #4760180
05/17/18 04:40 PM
05/17/18 04:40 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Honda says it's ok to replace the filter every other oil change. They don't put a 10k mile limit or time interval on the filter.
Re: Drain it or keep it? [Re: maverickfhs] #4760190
05/17/18 04:51 PM
05/17/18 04:51 PM
Tri State Conservative
Zee09 Offline
Zee09  Offline
Take it to 10% on the olm and then do it all!
"If I walked on water, they'd say I couldn't swim."
Re: Drain it or keep it? [Re: maverickfhs] #4760193
05/17/18 04:52 PM
05/17/18 04:52 PM
Los Gatos, CA
JeffKeryk Online content
JeffKeryk  Online Content
Los Gatos, CA
Personally, I would not reuse an oil filter.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Drain it or keep it? [Re: maverickfhs] #4760196
05/17/18 04:56 PM
05/17/18 04:56 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
My question would be is your Honda affected by fuel dilution? If it is I'd change as much of the oil as I could. Have you ever done a UOA and checked?
2004 Corolla 128175
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74615
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Drain it or keep it? [Re: JohnnyJohnson] #4760199
05/17/18 04:58 PM
05/17/18 04:58 PM
MURICA
MURICA
Never done a UOA and also don't think this model R18 engine is affected with fuel dilution.
Re: Drain it or keep it? [Re: maverickfhs] #4760202
05/17/18 05:00 PM
05/17/18 05:00 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Just run it down to 10%~20% OLM and change it all then smile
Re: Drain it or keep it? [Re: maverickfhs] #4760229
05/17/18 05:36 PM
05/17/18 05:36 PM
Ontario, Canada
newbe46 Offline
newbe46  Offline
Ontario, Canada
I assume you have been changing the filter every time our drain the oil, this is only a one-off.
I personally wouldn't do it but if you must, I don't think it's a big deal if you re-use a filter for another OCI. Keeping the correct oil level would be more important.
Definitely replace both at the end of this OCI but I wouldn't lose any sleep over it.
2003 E46 M3 Convertible
2004 Odyssey EX-L
2004 Impreza TS Wagon
Re: Drain it or keep it? [Re: maverickfhs] #4760245
05/17/18 05:58 PM
05/17/18 05:58 PM
pa
benjy Online content
benjy  Online Content
pa
reading on Noria enlightened me as to the value of filter changes being most important, even more so than the best oil!!!!!
Re: Drain it or keep it? [Re: maverickfhs] #4760319
05/17/18 07:06 PM
05/17/18 07:06 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
If I'm understanding correctly, its done 2 OCI's and you want to do three?
Personally, I probably wouldn't.
Only non-destructive ways I can think of to tell would be (a) differential pressure test, which you'd have to build, or (b) back-flush it and see what comes out.
(b) seems to offer the possibility of regenerating the filter, but you'd have to check that your procedure didn't damage it.
If you aren't prepared for the punk technology pioneering involved in (a) or (b), you could change it but cut the old one open and have a look, which might give you a guide for next time.
Re: Drain it or keep it? [Re: Ducked] #4760368
05/17/18 07:48 PM
05/17/18 07:48 PM
MURICA
MURICA
Not at all, oil filter is on 2nd oil. I would NOT do 3, unless it's a 2K-3K interval.
I am planning to cut this filter though!
Re: Drain it or keep it? [Re: maverickfhs] #4760383
05/17/18 07:59 PM
05/17/18 07:59 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
I can never keep track of when i change and when i skipped. I just change them both every time.
If you're asking the question you are worried about it. go ahead and reset the clock and sleep easy.
Re: Drain it or keep it? [Re: danez_yoda] #4760389
05/17/18 08:02 PM
05/17/18 08:02 PM
MURICA
MURICA
Well said, from this time. I'll write mileage and date on oil filter with a sharpie or scratch on it.
It'll be a lot easier next time.
Re: Drain it or keep it? [Re: maverickfhs] #4760474
05/17/18 09:56 PM
05/17/18 09:56 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
Keep it in and keep going. I've left my filter on for 2 oil changes for many thousand miles on my Element (same K24 as your TSX, and I run extended intervals to -2,000mi on the OLM with synthetic), which totals to over 14,000mi on the filter without significantly elevated silicon in the UOA. I've done the same on my wife's old 2009 Civic with the R18.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3721975/Honda_A01_14,226mi._(2_OCI)_Cu
Re: Drain it or keep it? [Re: maverickfhs] #4760505
05/17/18 11:18 PM
05/17/18 11:18 PM
Cajun Country, La.
BlueOvalFitter Offline
Cajun Country, La.
Install a new oil filter at EVERY oil change!
