Washing coolant down a storm drain?
by jharrison - 02/22/20 12:57 AM
storm door installation question
by FirstNissan - 02/22/20 12:13 AM
Kirkland VS M1
by A_Spruce - 02/21/20 11:24 PM
Ryan Newman bar
by P10crew - 02/21/20 10:16 PM
Good aftermarket shocks and struts?
by Micahmcmeen - 02/21/20 09:49 PM
Oil Marketing
by Mathew_Boss - 02/21/20 09:45 PM
run to your walmart NOW!
by willow - 02/21/20 09:39 PM
When redundancy goes out the window
by Exhaustgases - 02/21/20 08:34 PM
Please help me decide....
by ecureed - 02/21/20 08:03 PM
Flywheel pic
by Chris142 - 02/21/20 07:49 PM
Rislone Hyper Fuel
by rrretiree7 - 02/21/20 07:40 PM
Bosch Brakes
by ChiTDI - 02/21/20 07:16 PM
Which 15W40 for an Onan generator?
by atikovi - 02/21/20 06:39 PM
Valvoline Advanced 5W40 MST
by BurntMusic - 02/21/20 06:04 PM
2014 F250, 6.7L 13,000 OCI Amsoil AME 15w40
by claluja - 02/21/20 05:43 PM
What Are These On My Caliper Pistons?
by Fitz98 - 02/21/20 05:37 PM
Gun carry insurance
by Colt - 02/21/20 05:25 PM
drywall crack. how do i fix it?
by WhyMe - 02/21/20 02:55 PM
Yokohama AVID Ascend GT
by Bottom_Feeder - 02/21/20 02:53 PM
Getting my Chevy 4.3 to 300k
by CharlotteB - 02/21/20 02:16 PM
Hubbs1982, AW4BYT, YOUSSEF, b3e3, Bogdon
70775 Registered Users
31 registered members (carlprop, ChiTDI, Chuck1986, c502cid, Cdn17Sport6MT, cb4017, 1 invisible), 1,310 guests, and 19 spiders.
Topics301,769
Posts5,202,391
Members70,775
†Idler/Tensioner Pulleys #4759376 05/16/18 11:57 PM
R
raburn2906 Offline OP
R
I'm going to be replacing the serpentine belt, tensioner, and pulleys on my 2008 F150 4.6. Does anyone have recommendations? Dayco or Gates, pros or cons of either.
2008 Ford F150 XLT 4.6L
195,832 - Valvoline FS Max Life 5W30 - Motorcraft FL820-S
2001 Ford F150 XLT 5.4L
233,655 - Valvoline FS Max Life 5W30 - Wix 51372
Re: †Idler/Tensioner Pulleys [Re: raburn2906] #4759410 05/17/18 03:39 AM
Char Baby Offline
IMO, if this is an OE belt, replace with OE since it has 10yrs & 165K on them. You went this far on OE, why change and possibly get less.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: †Idler/Tensioner Pulleys [Re: raburn2906] #4759420 05/17/18 04:23 AM
dlundblad Offline
I also vote OE.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: †Idler/Tensioner Pulleys [Re: raburn2906] #4759467 05/17/18 05:43 AM
B
bullwinkle Offline
B
^Another vote for OE-just say no to Chinese bearings!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: †Idler/Tensioner Pulleys [Re: raburn2906] #4759532 05/17/18 06:54 AM
Chris142 Offline
The dayco tensioners are normally made in Canada by the oe supplier
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: †Idler/Tensioner Pulleys [Re: raburn2906] #4759548 05/17/18 07:08 AM
B
barkingspider Offline
B
I just replaced all mine on the GMC w Dayco and no problems. I have used gates in the past and itís all good. Canít go wrong w either one or OEM
04 Avalanche Z71 4x4
Re: †Idler/Tensioner Pulleys [Re: raburn2906] #4759653 05/17/18 08:30 AM
T
Trav Offline
T
You can use Dayco but you have to be very careful, the box may say made in Canada or USA but you must look at the bearing.
If its made in China or nothing because they turned the bearing over so you cant see it (yes they are scumbags) pass.
This means no internet order from Rock you have to see it or just go OE.
Gates blows don't even waste your time.
Re: †Idler/Tensioner Pulleys [Re: raburn2906] #4759743 05/17/18 10:03 AM
bdcardinal Offline
I vote OE, but obviously I am biased.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: †Idler/Tensioner Pulleys [Re: raburn2906] #4759830 05/17/18 11:30 AM
69GTX Offline
You don't want to be in there again for the life of the car. Get OE or an exact equivalent. OE isn't often that much more money.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: †Idler/Tensioner Pulleys [Re: Trav] #4759972 05/17/18 01:31 PM
Claud Offline
How do you justify that statement?. I've always used Gates or Dayco, never had an issue with either brand.
Claud.
Re: †Idler/Tensioner Pulleys [Re: bullwinkle] #4759980 05/17/18 01:36 PM
P
Piston_slap Offline
P
You got a problem with Uncle Ho and his Yak grease?
1994 Ford Econoline w/302 & 4R70W
Valvoline 10W-40, WIX Gold
Isotope U235
Re: †Idler/Tensioner Pulleys [Re: Claud] #4759995 05/17/18 01:49 PM
T
Trav Offline
T
Claud.
Multiple very early failures on 4.6 and 5.4 engines (and others), its that simple.
Re: †Idler/Tensioner Pulleys [Re: Trav] #4760045 05/17/18 02:13 PM
Claud Offline
Claud.
Got a link to this? I'm just curious, not trying to troll you.
Claud.
Re: †Idler/Tensioner Pulleys [Re: raburn2906] #4760091 05/17/18 02:59 PM
N
nobb Offline
N
All the manufacturers for these use whatever bearing they might be able to source. Without seeing it, there's no way to know for sure. But there has to be a ton of noise and play before anything bad happens. The bearings are also usually a standard size like 6203, so they can easily be pressed off and replaced. These are so easy to change that I wouldn't overthink it.
Re: †Idler/Tensioner Pulleys [Re: raburn2906] #4760102 05/17/18 03:12 PM
A
artificialist Offline
A
1. OEM
2. Dayco
2010 Lancer Ralliart Sportback
