Walmart and Valvoline
by Bullwinkle007. 01/22/19 09:10 PM
Getting Our Kicks On Route 66
by 2015_PSD. 01/22/19 08:40 PM
Uploading a short film clip from an IPhone.
by Snagglefoot. 01/22/19 07:52 PM
Purolator L34631 (torn media)
by LDM. 01/22/19 07:51 PM
THIS close to getting a VDB today at TPA
by 14Accent. 01/22/19 07:48 PM
Supco Appliance Parts.
by George7941. 01/22/19 07:36 PM
Unusual Jury summons.
by Chris142. 01/22/19 06:31 PM
Vibration feeling after new tires installed?
by MONKEYMAN. 01/22/19 05:51 PM
Sudden Shake - ‘18 Accord
by Throt. 01/22/19 05:43 PM
05 Ford 500 Intake hole - melted
by Geauxtiger. 01/22/19 05:41 PM
How's K&N 1004 on Kia/Hyundai GDI
by SlavaB. 01/22/19 05:18 PM
more PSD woes with cold weather
by Donald. 01/22/19 05:10 PM
Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
87 registered members (asiancivicmaniac, aleneros, 2015_PSD, ammolab, 9 invisible), 1,255 guests, and 43 spiders.
Topics297,006
Posts4,963,322
Members67,013
Most Online2,821
Jan 21st, 2019
Starting lawn mower that sat for 12 years #4760004
05/17/18 01:53 PM
05/17/18 01:53 PM
Atlanta, GA
RoGuE Offline OP
RoGuE  Offline OP
Atlanta, GA
I'm being given a lawn mower that has been sitting for about 12 years. It was purchased in about 2003. It is a Toro 6.5HP, 22" deck, self propelled recycler mower. I plan on dumping the oil, and putting fresh gas in it to see what happens. Is there any other kind of maintenance I need to do first or should I just stick to those two things?
2007 Chevrolet Malibu
2.2L Ecotec
Re: Starting lawn mower that sat for 12 years [Re: RoGuE] #4760009
05/17/18 01:56 PM
05/17/18 01:56 PM
NY, USA, etc.
oilpsi2high Offline
oilpsi2high  Offline
NY, USA, etc.
Spray oil into the cylinder before pulling.
Spray starting fluid in the carb to clean out gunk.
Pull cord.
Re: Starting lawn mower that sat for 12 years [Re: RoGuE] #4760012
05/17/18 01:57 PM
05/17/18 01:57 PM
Outer Banks, NC
NormanBuntz Offline
NormanBuntz  Offline
Outer Banks, NC
Before you start the engine, remove the spark plug, spray some light lube in there and crank the engine for 10-15 seconds to get some oil circulated. A can of good carburetor cleaner is likely in your near future. Good luck. That's a good mower.
2017 Honda Odyssey SE, 17K
2013 Honda Accord LX, 58K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: Starting lawn mower that sat for 12 years [Re: RoGuE] #4760013
05/17/18 01:59 PM
05/17/18 01:59 PM
CA
raytseng Offline
raytseng  Offline
CA
theres a difference between repair and maintenance.
if youre in the repair phase just get it working first.
then you can consider what you want to so for maintenance.
e.g. filter, blades, spark plugs, fuel treatment, oil. paint
Re: Starting lawn mower that sat for 12 years [Re: raytseng] #4760049
05/17/18 02:16 PM
05/17/18 02:16 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
If fuel with ethanol was left in it there's a good chance you'll find a "nose picking's worth" of plastic clogging the fuel jet.
If you're lucky, it'll start right up.
Re: Starting lawn mower that sat for 12 years [Re: RoGuE] #4760052
05/17/18 02:17 PM
05/17/18 02:17 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Dont forget to dump that 12yrs old gasoline too smile
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Starting lawn mower that sat for 12 years [Re: RoGuE] #4760090
05/17/18 02:58 PM
05/17/18 02:58 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Plan on rebuilding the carb to get it running properly.
2015 Ford F250 w/Powerstroke
Re: Starting lawn mower that sat for 12 years [Re: Donald] #4760095
05/17/18 03:02 PM
05/17/18 03:02 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
I doubt it needs a rebuild after with so little wear and tear, but you will most likely need to clean the main jet.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Starting lawn mower that sat for 12 years [Re: RoGuE] #4760103
05/17/18 03:15 PM
05/17/18 03:15 PM
California
boom10ful Offline
boom10ful  Offline
California
I'll assume it has a Tecumseh engine on it. If so, don't bother cleaning the carb. These are hard to clean in my opinion. Here's a link to a genuine Tecumseh carburetor. Make sure it's the one for your motor if you do buy one.
https://www.ebay.com/itm/GENUINE-TECUMSEH-WITH-GASKET-640350-640303-640271-LV195EA-LEV100-LEV105-LEV120/251939869314?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
Re: Starting lawn mower that sat for 12 years [Re: maxdustington] #4760144
05/17/18 03:58 PM
05/17/18 03:58 PM
Canada
boraticus Offline
boraticus  Offline
Canada
What he said. Carb will likely need cleaning. Wire, solvent & compressed air. No magic elixirs required.
Re: Starting lawn mower that sat for 12 years [Re: RoGuE] #4760226
05/17/18 05:33 PM
05/17/18 05:33 PM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
Id second the spraying a little lube down the cylinder, or at least pulling the park plug wire off to get some oil splashing around before starting.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI Fuchs 5/40 GT Pro XTL
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Starting lawn mower that sat for 12 years [Re: RoGuE] #4760308
05/17/18 06:57 PM
05/17/18 06:57 PM
Sask, Canada
BrianF Offline
BrianF  Offline
Sask, Canada
If it has oil, then try and pull start it. Who knows, maybe it will fire and run on the old gas. If it doesn't run then go down the list, fuel, air, spark. Its a lawnmower here people, not the space shuttle. Maybe he should load up the seafoam in the fuel, amsoil in the crankcase changed at 5 hour intervals. Don't over think this.
2006 Trailblazer LT. QSUD with Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30 with Hastings LF608.
1993 GMC 1500. QSAD with Fram PH5
Re: Starting lawn mower that sat for 12 years [Re: RoGuE] #4760456
05/17/18 09:24 PM
05/17/18 09:24 PM
EasTn
Sealbilly Offline
Sealbilly  Offline
EasTn
I'd bet a paycheck if gas was left in it you'll have to clean it first before it will run. The gas will be orange and it will smell different. Marvels Mystery Oil is a good cylinder soak for engines that haven't been run in a long time. Take the plug out and pour it in and let it sit a while pull the rope several times then replace plugs. I have revived many small engines like this,,, dirt bikes, lawn mowers, generators.
Re: Starting lawn mower that sat for 12 years [Re: RoGuE] #4760538
05/18/18 03:14 AM
05/18/18 03:14 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
I am surprised that no one suggested 2stroke oil as pre-lube for a cylinder smile
Re: Starting lawn mower that sat for 12 years [Re: boom10ful] #4760827
05/18/18 09:26 AM
05/18/18 09:26 AM
Atlanta, GA
RoGuE Offline OP
RoGuE  Offline OP
Atlanta, GA
Gas tank is bone dry.
Yes a Tecumseh 6.5HP. I'll keep this is mind if it's all gummed up.
2.2L Ecotec
