Elf 4T moto tech 10w50 is good?
by firstime911. 01/15/19 09:25 PM
New Champ Filter
by CapitalTruck. 01/15/19 08:30 PM
19 Elantra vs corolla vs civic vs 18 Mazda 3
by wolf_06. 01/15/19 07:28 PM
New guage cluster need to be programed?
by callbay. 01/15/19 07:28 PM
good brand of inner tie rod?
by motor_oil_madman. 01/15/19 07:27 PM
Look at this blast from the past!
by SubieRubyRoo. 01/15/19 05:50 PM
Factory service manuals?
by buck91. 01/15/19 05:49 PM
Road Trip - Drive My Own Car or Rent?
by The Critic. 01/15/19 05:23 PM
‘19 GTI specs 0w-20 508 00
by LotI. 01/15/19 05:22 PM
Fram TG11955
by advocate. 01/15/19 03:03 PM
Bosch Steeltech = Wix?
by Black_Thunder. 01/15/19 02:44 PM
CVT and 6 speed automatic
by jerseyguy123. 01/15/19 01:56 PM
Hypothetical - X6M vs X5M vs AMG GLE63
by OVERKILL. 01/15/19 01:48 PM
2001 dodge neon coolant reservoir
by mobilaltima. 01/15/19 01:38 PM
Washing under car at self-service wash (salt)
by TmanP. 01/15/19 01:19 PM
Full Synthetic High Mileage in 40w range.
by FlyPenFly. 01/15/19 12:41 PM
2018 Silverado 3500HD TPMS Re-Learn
by Phishin. 01/15/19 12:36 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
141 registered members (AdRock, 92saturnsl2, 97prizm, 28oz, AdditiveOCD, 15 invisible), 1,965 guests, and 34 spiders.
Topics296,608
Posts4,955,759
Members66,950
Most Online2,577
Jan 14th, 2019
Tire knot or something else? #4759377
05/16/18 11:58 PM
05/16/18 11:58 PM
New Orleans
podan Offline OP
podan  Offline OP
New Orleans
My wife took her 2013 Mazda CX-9 (FWD) in for a recall on the lower control arms. They replaced the arms, aligned it, and rotated the tires. She claims that shortly after that she could feel a vibration in the steering wheel. She drove it from New Orleans to Florida, and by the time she came back said the car was terrible. I drove it today, at low speeds ( <20 MPH) the steering wheel shakes. There are no unusual noises. The shake gets worse until you get on up to interstate speed, and the shake becomes more of a vibration. The vehicle does not pull to either side when driving or braking. I have looked at the front tires, and one seems more worn than the other but I cannot see and obvious bulges or flat spots. Any hints before I take it back to the dealership? I just don't believe the problem is related to the lower control arms replacement or an I wrong?
Re: Tire knot or something else? [Re: podan] #4759380
05/17/18 12:00 AM
05/17/18 12:00 AM
TX
raburn2906 Offline
raburn2906  Offline
TX
Wheel weight missing or loose can cause a lot of those issues.
2008 Ford F150 XLT 4.6L
174,004- Valvoline Synthetic Max Life - Wix 51372
2001 Ford F150 XLT 5.4L
216,091- Valvoline Synthetic Max Life - Wix 51372
Re: Tire knot or something else? [Re: podan] #4759392
05/17/18 01:48 AM
05/17/18 01:48 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
Wheel balance or warped disc
Cable ties should hold it
Re: Tire knot or something else? [Re: podan] #4759408
05/17/18 03:31 AM
05/17/18 03:31 AM
pa
FT92 Offline
FT92  Offline
pa
possible bent wheel
Re: Tire knot or something else? [Re: podan] #4759424
05/17/18 04:31 AM
05/17/18 04:31 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Move the suspected tire/wheel to the rear and see if there is still a front shake.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Tire knot or something else? [Re: Char Baby] #4759465
05/17/18 05:40 AM
05/17/18 05:40 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Wheel merely glances against a curb could do all that you describe.
You vehicle has an "X" in the name, CX-9, and it's FWD not 4WD?
Re: Tire knot or something else? [Re: podan] #4759505
05/17/18 06:29 AM
05/17/18 06:29 AM
USA
mk378 Offline
mk378  Offline
USA
Noticeable at very low speeds means it is something that is fundamentally not round, not a weight imbalance. Find some good flat pavement, hold the steering wheel loosely and drive very slowly to feel for any "once around" side to side movement.
As it got worse after driving it is most likely a faulty tire. Can also be that the wheel is not seated on the hub due to corrosion or other debris in between.
Re: Tire knot or something else? [Re: podan] #4759614
05/17/18 08:06 AM
05/17/18 08:06 AM
Massachusetts
deven Offline
deven  Offline
Massachusetts
Or it could just be that they didn't torque the lug nuts of one tire properly. Seen many times this causing the steering wheel shake!
Proud user of ROYAL PURPLE products!
2016 Acura RLX Sports Hybrid(Royal Purple HPS 5w30 + M1-110 oil filter)
KEEP IT SIMPLE STUPID. IT'S ONLY OIL
Re: Tire knot or something else? [Re: podan] #4759643
05/17/18 08:25 AM
05/17/18 08:25 AM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
After the tire rotation, a bent rim/out-of-round tire is now in the front, causing the noticeable shimmy.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Tire knot or something else? [Re: podan] #4759646
05/17/18 08:26 AM
05/17/18 08:26 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Just sounds like a bent rim or bent tire. Was on the back before and you did not notice, now that it is on the front you do.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Tire knot or something else? [Re: podan] #4759915
05/17/18 12:42 PM
05/17/18 12:42 PM
New Orleans
podan Offline OP
podan  Offline OP
New Orleans
Thanks for all the ideas. When I have time this weekend I am going to take one tire off at a time and put the spare tire on in its place (even though it is a temporary spare - not full size) and see what happens.
Re: Tire knot or something else? [Re: podan] #4759989
05/17/18 01:45 PM
05/17/18 01:45 PM
Va.
Piston_slap Offline
Piston_slap  Offline
Va.
I had a tire knot appear and show the same symptoms. Slow driving <10 mph you could feel the front end rise and fall maybe an inch. The steering wheel, like yours, wobbled in sync with the rise. crzy
1994 Ford Econoline w/302 & 4R70W
Valvoline 10W-40, Motorcraft FL1
Isotope U235
