Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
108 registered members (69Torino, 1.8Tango, advocate, 4WD, andyd, 69GTX, 12 invisible), 1,829 guests, and 32 spiders.
Topics296,898
Posts4,961,178
Members66,997
Most Online2,688
Jan 19th, 2019
Page 1 of 3 1 2 3
You be the judge.. #4759182
05/16/18 07:05 PM
05/16/18 07:05 PM
DFW
JustN89 Offline OP
JustN89  Offline OP
DFW
So I've been contemplating how to perform a drain and fill on the 2017 Elantra given the "sealed" system. It requires the car to be on level ground in order to get an accurate reading on fluid level which is a problem for me as I'm 6'4" 240lbs... I don't fit under this small car without it being elevated. The way I see it, I have four options which I'll list and I'd be happy to hear opinions on them.
First Option:
Put the front of the car on ramps and jack up each side on the rear and put it on jack stands. With the rear of the car pushed down due to the front being on ramps and being unable to get the jack to the middle of the rear suspension, I'd be placing the jacks under the springs and the stands under the pinch welds. This would give me an elevated, yet flat car which would give me an accurate reading.
Second Option:
Just jack up one side (driver front- strategically chosen), take out the drain plug, and let the car drop down again. Wait for it to drip out, jack it up, put the drain plug in and remove the fill plug. Replace fluid and wait for it to start dripping out. Jack it up once again (the level check plug is on drivers side, so jacking it up on this side would elevate it and keep the fluid from rushing out- STRATEGERY), replace the level check plug, and call it a day.
Third option:
Put the car on ramps and drain the ATF. Measure what came out and replace that much with new fluid and call it a day (easy, but requires trust that it had correct level to begin with).
Fourth option:
Call and schedule an appointment with Christian Brothers Auto, go get lunch while they do the dirty work, and live with the lingering doubt that they did things correctly. Nothing against them, I just don't know any reputable places near me (new to DFW).
What say you?
Re: You be the judge.. [Re: JustN89] #4759196
05/16/18 07:17 PM
05/16/18 07:17 PM
Basehor, KS
JayhawkRoy Online content
JayhawkRoy  Online Content
Basehor, KS
I own a Santa Fe. Christian Bros does my oil changes, but for ATF fluid change out, I voted on the Hyundai dealer. At least I knew I would get the proper fluid. My dealer did just fine with the ATF fluid exchange (189.95). No issues.
Christian Bros is a franchise operation, so YMMV as far as how they are actually operated. I think they started in the Dallas area. That said, the one I use are upfront about their pricing and abilities.
Re: You be the judge.. [Re: JustN89] #4759204
05/16/18 07:32 PM
05/16/18 07:32 PM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
Tagged for responses.
How many miles on your '17?
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: You be the judge.. [Re: JustN89] #4759210
05/16/18 07:37 PM
05/16/18 07:37 PM
Toronto
dgunay Offline
dgunay  Offline
Toronto
Third option is the easiest way.
Don't worry about the level, it won't make huge difference. You won't blow your transmission if it's slightly overfilled.
2009 Acura CSX - PUP 0w20 / Fram XG7317 / Maxlife ATF
2018 Kawasaki Z650 - Motul 4T 5100 10w40 / OEM Oil Filter
Re: You be the judge.. [Re: JustN89] #4759214
05/16/18 07:42 PM
05/16/18 07:42 PM
Omaha, NE USA
fisher83 Offline
fisher83  Offline
Omaha, NE USA
I would think draining it cold and measuring what came out and refilling with the same amount will net you more or less the same results and you wonít need to go through all the hassle of making sure the car is completely level. The procedure seems to me to be designed assuming the car is warmed up and just drove into the shop with hot ATF. There is of course the risk of it being improperly filled from the factory but I doubt that is very likely. Thatís how Iíve always done drain and fills in my vehicles.
2015 Toyota RAV4 Limited 41k
2016 Nissan Frontier Pro-4x 18k
Re: You be the judge.. [Re: JustN89] #4759217
05/16/18 07:53 PM
05/16/18 07:53 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
If I'm reading Option 2 correctly ... drain, then fill (maybe slightly over what the manual ssys for fill change capacity) ... then lower the car and let any excess drain out the level check plug while the car is level. Jack back up and install level fill plug. That would essentially give you a full level fill if the bottom of the check plug hole it considered totally full.
Re: You be the judge.. [Re: ZeeOSix] #4759225
05/16/18 07:57 PM
05/16/18 07:57 PM
DFW
JustN89 Offline OP
JustN89  Offline OP
DFW
Check hole plug is the "full" line. It's considered full when fluid starts to drip out from that hole.
Re: You be the judge.. [Re: JustN89] #4759226
05/16/18 07:57 PM
05/16/18 07:57 PM
Ohio
hallstevenson Offline
Ohio
First time I did a drain and fill on our Fusion, I replaced the same amount of fluid that came out. I then drove it, got the fluid hot, and checked the level with the 'check' plug. That way, I can feel confident that it has the "right" amount in it and that future drain and fills will be accurate.
Can you do a combination of # 2 and # 3 just once ?
Re: You be the judge.. [Re: mclasser] #4759228
05/16/18 08:00 PM
05/16/18 08:00 PM
DFW
JustN89 Offline OP
JustN89  Offline OP
DFW
22k, so not at a mileage requiring a drain and fill yet. We do, however, put a lot of miles on that car and will be putting another 4-5k miles on it in the month of July alone so I like to plan ahead. The dealership I bought it from did a drain and fill at 10k miles, and I planned on doing it again at 40k. I've heard mixed reviews on Hyundai's SP-IV fluid so I'd rather not run it too long if at all possible. I'm thinking of going either Schaeffer's or Amsoil.
Re: You be the judge.. [Re: dgunay] #4759230
05/16/18 08:00 PM
05/16/18 08:00 PM
DFW
JustN89 Offline OP
JustN89  Offline OP
DFW
Tend to agree with you. It would make my life much easier. thumbsup
Re: You be the judge.. [Re: JustN89] #4759231
05/16/18 08:01 PM
05/16/18 08:01 PM
pa
benjy Offline
benjy  Offline
pa
a DIY will only get some of the fluid, if your budget affords it a full machine change is best especially if you have higher miles on it!! sometimes the fluid level needs to be at a certain temp to check it, searching will usually find detailed info from somewhere.
Re: You be the judge.. [Re: hallstevenson] #4759232
05/16/18 08:01 PM
05/16/18 08:01 PM
DFW
JustN89 Offline OP
JustN89  Offline OP
DFW
To be honest, I'm not sure that the fill plug is accessible from the top.
Re: You be the judge.. [Re: benjy] #4759235
05/16/18 08:04 PM
05/16/18 08:04 PM
DFW
JustN89 Offline OP
JustN89  Offline OP
DFW
Doesn't have mileage on it. It should have 30k miles on the fluid when I plan on doing it.
Re: You be the judge.. [Re: JustN89] #4759236
05/16/18 08:06 PM
05/16/18 08:06 PM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
What makes 30 the magic number?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: You be the judge.. [Re: JustN89] #4759240
05/16/18 08:10 PM
05/16/18 08:10 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
I'd just slightly over-fill it, then remove the check plug with it jacked up, then lower it back to the floor and let the excess drain out. Sounds pretty much what your Option 2 is.
Page 1 of 3 1 2 3
