Originally Posted By: JustN89
Originally Posted By: NoNameJoe
103K and changing the fluid for the first time?
I would be too nervous.
Quote:
One thing I've noticed with the Honda ATF is that it has a smell like no other ATF. Must be the magic juice.....
Yup, I love the smell. I've used other ATF's like Dex/Merc and they smell so [censored] bad. Castrol Import ATF smells like fish, Valvoline MaxLife ATF smells like [censored].
I used those on Nissan cars. For Honda I only use Honda fluids.
Got some Maxlife on my favorite hat last time I serviced the transmission on the Impala. I got the stain out but the smell seemingly won't every go away.
Originally Posted By: Patman
I love how easy the trans fluid change is on an 8th gen Civic! I always do a drain and fill, drive a few miles, and then do another drain and fill, since each time you drain it only 50% of the old fluid will come out. But if you do the double drain and fill about every 30-50k that should be good enough. I always use the OEM fluid from the Honda dealer.
Yup, you don't have to go search for a socket either since the plug is just a 3/8 drive. The one thing I think would have made it even better is if the drain plug were right on the bottom facing down.
