Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
98 registered members (4WD, 69Torino, 1.8Tango, 97prizm, 53' Stude, 11 invisible), 1,788 guests, and 42 spiders.
Topics296,895
Posts4,961,137
Members66,997
Most Online2,688
Jan 19th, 2019
Page 1 of 6 1 2 6
Honda 1.5L gdi turbo #4758656
05/16/18 09:39 AM
05/16/18 09:39 AM
North Texas
ARB1977 Offline OP
ARB1977  Offline OP
North Texas
The book calls for 0W20. I was thinking Castrol Magnatec or Amsoil SS. I plan on following the olm or 10K interval. Your thoughts please. Thanks.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: Honda 1.5L gdi turbo [Re: ARB1977] #4758665
05/16/18 09:51 AM
05/16/18 09:51 AM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
Honda's GDI engines have a reputation for fuel dilution of the oil. Consequently, I would keep the OCI's short, and not spend extra money on a boutique oil. Castrol Magnatec, then. Do a few oil analyses and see if there is fuel dilution, then make a decision on perhaps going up to 30 weight to compensate.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: Honda 1.5L gdi turbo [Re: ARB1977] #4758668
05/16/18 09:54 AM
05/16/18 09:54 AM
MN
oil_film_movies Offline
MN
Your CRV is the top-rated one in it's segment! Good choice. Its not only GDI, its also turbo'ed, like my '18 Equinox 1.5L as well.
Honda is having a lot of trouble with fuel dilution in some of those engines, so I'd recommend going with 0w30 Mobil1 AFE. Its only a little bit thicker, not much, and it does give a little more margin for the fuel dilution to lower viscosity during the oil change interval.
http://www.classlawdc.com/2018/04/13/honda-cr-v-and-civic-oil-dilution-class-action-investigation/
Change the oil at 3,000 miles to get past the break-in period and satisfy Honda's recommendation to have the high-moly factory oil for a while.
Then the 3,000 mile oil change will flush out the metal wear products.
After 3,000 miles, go to a normal oil change interval according to the owner's manual using Mobil1 AFE 0w30 and a Fram Ultra oil filter.
Use the 0w30 forever until you prove to yourself that your oil level doesn't rise on the dipstick due to fuel dilution. If it does not, then go back to using 0w20, preferably a dexos1 Gen2, and if you really want the "best" oil, I think that's Ravenol 0w20 with moly+tungsten+esters for FM in a PAO/POE base (no GroupIII).
Re: Honda 1.5L gdi turbo [Re: A_Harman] #4758669
05/16/18 09:54 AM
05/16/18 09:54 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Agreed. These engines have had some oil related failures both here and overseas. I suggest no more than 5000 mile OCI's. I also suggest a slightly higher viscosity.
Interestingly, owners of 1.5t's in Arizona are having fuel dilution and wiping out camshafts due to highly diluted uber thin oil.
EDIT: Some are saying 3000 mile intervals are as long as they can go.
Re: Honda 1.5L gdi turbo [Re: ARB1977] #4758670
05/16/18 09:54 AM
05/16/18 09:54 AM
Southern VA
klt1986 Offline
klt1986  Offline
Southern VA
Mobil 1 EP, Mobil 1 AFE or Pennzoil Platinum in 0W20 would be my choice. I'd probably use the ones that have the best rebates available.
Wife: 08 Honda CR-V 4WD, M1 5W-20
Me: 11 Toyota Tundra DC 4WD 5.7L, PP 5W-30
Me Work: 06 Ford Explorer 4WD 4.0L, Pennzoil 5W-30
Son: 14 Toyota Corolla S, M1 AFE 0W-20
Re: Honda 1.5L gdi turbo [Re: ARB1977] #4758672
05/16/18 09:57 AM
05/16/18 09:57 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
0W-20 at Severe Service interval for the reasons given above.
18 Sportage 2.4L AWD:
Now: M1AP 5/20 + M1-104
Next: QSUD 5/30 + S2808XL
13 Santa Fe Sport 2.0T:
Now: PPEuroL 5/30 + OEM
Next: EDGE 5/40 + S2808XL
Re: Honda 1.5L gdi turbo [Re: A_Harman] #4758683
05/16/18 10:09 AM
05/16/18 10:09 AM
PimTac Offline
PimTac  Offline
Good advice here. I would limit the oci to 5000 miles.
Cannot see signatures any longer so it doesn’t matter.
Re: Honda 1.5L gdi turbo [Re: ARB1977] #4758689
05/16/18 10:14 AM
05/16/18 10:14 AM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
0w20 in Dexos 1 gen 2 and follow the OLM. The D1G2 should help with keeping the DI valves cleaner.
Re: Honda 1.5L gdi turbo [Re: ARB1977] #4758706
05/16/18 10:28 AM
05/16/18 10:28 AM
Canada
nap Offline
nap  Offline
Canada
UOA at 50% OLM and action accordingly.
Re: Honda 1.5L gdi turbo [Re: Cujet] #4758710
05/16/18 10:31 AM
05/16/18 10:31 AM
MN
MN
Wow, Honda has some issues (& class-action lawyers!) to deal with. That's why I say change the factory-fill out at 3k miles or 3 months and put in Mobil1 AFE 0w30. That declares it guilty of fuel dilution before being proved innocent.
If found innocent of dilution from the level not rising on the dipstick over several thousand miles, then go to 0w20, but not before. To be on the wear-safe side.
Re: Honda 1.5L gdi turbo [Re: ARB1977] #4758734
05/16/18 11:02 AM
05/16/18 11:02 AM
North Texas
ARB1977 Offline OP
ARB1977  Offline OP
North Texas
[censored] that sucks. Hopefully Honda will come up with a plan to combat the fuel related issues. Less than 500 miles and the wife gets 27 mpgs. I’ll stick to 0W20 but keep the interval to 5K. Thank god we bought the 100K warranty.
Re: Honda 1.5L gdi turbo [Re: Cujet] #4758738
05/16/18 11:06 AM
05/16/18 11:06 AM
TX
parshisa Offline
parshisa  Offline
TX
Do you have link to a real world example to support your statement?
Re: Honda 1.5L gdi turbo [Re: ARB1977] #4758745
05/16/18 11:15 AM
05/16/18 11:15 AM
Canada
nap Offline
nap  Offline
Canada
http://www.crvownersclub.com/forums/14-p...s/168018?page=5
“ I called my local Honda today and I got an answer. Due to the gasoline getting into my oil. The engine cylinders have been damaged and shavings we're found in the oil “
Re: Honda 1.5L gdi turbo [Re: ARB1977] #4758749
05/16/18 11:18 AM
05/16/18 11:18 AM
5600 feet elevation, Arizona
double vanos Offline
Castrol 0w40 until the dilution abates - if ever. With the way those engines are carrying on, 0w40 would a mid weight 30 after a few 100 miles, a 20 at 5000.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Honda 1.5L gdi turbo [Re: ARB1977] #4758750
05/16/18 11:18 AM
05/16/18 11:18 AM
DFW
JustN89 Offline
JustN89  Offline
DFW
It looks like crvownersclub.com is full of threads regarding fuel dilution causing major problems. One guy was apparently told that he is getting a new cylinder head and that he will need to get an oil change every 500 miles, while another poster reports that Honda has had his CR-V for over 80 days. Looks like the fuel dilution issue is more prevalent than I thought.
Page 1 of 6 1 2 6
