Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
124 registered members (4WD, 01rangerxl, 2015_PSD, 2010Civic, 3311, 9 invisible), 1,815 guests, and 61 spiders.
Topics286,088
Posts4,902,367
Members67,560
Most Online2,967
Mar 10th, 2019
1999 e320 aux fan wont stop running, BENZ pro #4758551
05/16/18 08:54 AM
05/16/18 08:54 AM
CA
2008wrx Offline OP
2008wrx  Offline OP
CA
i am helping a friend of mine to solve the "AUX FAN WON'T STOP" running after we shut off the engine. This unit only has 1 electrical fan set up behind the radiator.
There are 2 unique scenarios, i tried them both when engine is cold and hot.
1: After we shut off the car, fan will keep spinning till the battery die. When engine is hot like 100 degree coolant temp; it will run till the battery die.
2: When engine is cold, you manually use your hand to spin the fan, it will kick star the fan, but it will only turn at very very slow speed.
Things have been done to solve this issue: New Aux fan, new climate control panel, new coolant temp sensor, new ac pressure switch, new thermostat, new fan control module.
Please help, thanks a lot.....
Re: 1999 e320 aux fan wont stop running, BENZ pro [Re: 2008wrx] #4758620
05/16/18 10:03 AM
05/16/18 10:03 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
If the fan control module is the solid state electronic relay for the fan I would suspect it. When solid state devices fail it is usually in the on position. But it would be on as soon as you turn on the key I would think.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: 1999 e320 aux fan wont stop running, BENZ pro [Re: 2008wrx] #4763289
05/20/18 06:34 PM
05/20/18 06:34 PM
California
VeryNoisyPoet Offline
California
Sounds like some sort of short circuit in the wiring that is letting power bypass the fan controller and spin the fan, or trick the fan controller into keeping the fan on when the car is shut off.
Measure the voltage at the connector to the fan motor when the fan is stopped, and then use your hand to kick start the fan to see if anything changes.
Measure the voltage at the input signal to the fan controller to see what is happening there when fan is stopped, when fan is running normally, and when the fan turns slow after being started by hand.
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: 1999 e320 aux fan wont stop running, BENZ pro [Re: 2008wrx] #4763742
05/21/18 09:37 AM
05/21/18 09:37 AM
Connecticut, USA
bmwpowere36m3 Offline
Connecticut, USA
Do you have a wiring diagram? You threw the parts book at it...
Without a system or wiring diagram its hard to say. Does the ECU communicate with the fan module? I'd be looking at wiring personally.
