Low Ash Content
Originally Posted By: weasley
Originally Posted By: 1JZ_E46
There are very few oils that meet both LL-04/229.51 and 504/507/C30.
You missed Castrol EDGE 5W-30.
That’s an out of date formula. Current one only meets 50200/50500/50501 for VW specs.
Originally Posted By: Garak
Yes, the one I've seen on the shelf also has dexos2, as your chart indicates.
Castrol is terrible with documentation QC.
They are two different products. You quoted data for Castrol EDGE 5W-30 C3, I quoted data for Castrol EDGE 5W-30 (period).
From the Castrol USA website:
Quote:
CASTROL EDGE IS AVAILABLE IN THE FOLLOWING GRADES: 0W-20, 0W-30 A3/B4, 0W-40 A3/B4, 5W-20, 5W-30, 5W-30 A3/B4, 5W-30 C3, 5W-30 DIESEL, 5W-40, 5W-40 TURBO DIESEL, 5W-50, 10W-30, 10W-40 AND 10W-60
Castrol EDGE 5W-30 does not carry 504/507/C30 approval. I think the PDS you linked to (a C3 oil) is old and was replaced with EDGE 5W-30 C3.
Edit: Actually, I think there may be two oils. The one you listed is “EDGE 5W-30 for European Diesels,” not regular EDGE 5W-30 (a GF-5 oil). AAP carries it at $10.50 a quart lol. It’s weird because of the overlapping approvals.
Weasley, in your quote that refers to Castrol 5w-30 in list of grades, that first one you bolded would be referring to the SN/GF-5 version here (i.e. A5/B5 if it still has it). Looking closer at the quote, you perhaps should have highlighted the one after the C3. I would gather that "5w-30 DIESEL" might be it, if, indeed, it still exists, since the only other 5w-30 "diesel oil" Castrol has in North America, to my knowledge, is tiered as Elixion in E6, rather than an Edge.
You may be right, although the US-specific 5W-30 is named "Castrol EDGE 5W-30 US" on the PDS.
That said, the point remains - there is a 5W-30 version with the spec profile the OP was after.
Yes, and believe it or not, they actually have that right on the bottle, too.
