Ok I have a 2004 Buick LeSabre 100k miles. The abs light came on today so I scanned it when I got home and despite that the light is on, it showed no current codes. It is a GM tech ii scanner which can give past stored codes as well and showed two codes for the right front wheel speed sensor. The right front wheel bearing was replaced in error due to my bad diagnosis(oops, "grinding" sounds was actually low fluid) 10k miles ago. My front brakes are warn to the squeakers but I don't think that has to do with it. My brake fluid is not low.
Any ideas?
Thanks
Any ideas?
Thanks
