Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
107 registered members (69Torino, 1.8Tango, advocate, 4WD, andyd, 69GTX, 12 invisible), 1,830 guests, and 32 spiders.
Topics296,898
Posts4,961,178
Members66,997
Most Online2,688
Jan 19th, 2019
Page 1 of 3 1 2 3
2009 Honda CR-V Air Conditioning #4758027
05/15/18 03:03 PM
05/15/18 03:03 PM
New York
Recalculating Offline OP
New York
2009 Honda CR-V - 54000 miles
Air conditioning gauges are showing 72 psi on both the low side and high side with no change when vehicle is started and air conditioning put on. A 1000 rpm is noticed when the A/C is turned on. The A/C 4 pin relay in the main fuse panel is tested good by swapping out nearby relays along with the 7.5 fuse for the magnetic coil.
I have measured the air gap at the A/C clutch to be 20 and is believed to be correct. With the engine running, A/C on, I have tapped on the A/C clutch to see if it was a weak coil and it will not turn on. At this point I have assessed a bad A/C clutch and/or coil.
In 2012, I received a letter from Honda citing this problem and extending the warranty of the A/C clutch and coil for 7 years or 100,000 miles. I believe it is no longer valid. (2009)
I have the vacuum pump and the gauges. It appears there is no room for the clutch and coil to come off without pulling the compressor out from the bottom.
Questions are: (1) Am I reading this right from the tests conducted? (2) And since this will be a full compressor replacement, what have the experienced members purchased as a quality reliable replacement? (Brand name)
2009 Honda CR-V EX-L 55k
2007 Buick Lacrosse 54k
Re: 2009 Honda CR-V Air Conditioning [Re: Recalculating] #4758036
05/15/18 03:15 PM
05/15/18 03:15 PM
Canuck living in California
KrisZ Offline
KrisZ  Offline
Did you check if the coil is receiving signal to activate?
2015 Dodge Grand Caravan-30k miles.
2007 Ford Focus ZX3-110k miles
2006 Mazda 3-168k miles
Re: 2009 Honda CR-V Air Conditioning [Re: Recalculating] #4758041
05/15/18 03:30 PM
05/15/18 03:30 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
The OE coils are a known problem. Believe it or not The Chinese copy is mush better.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 2009 Honda CR-V Air Conditioning [Re: Recalculating] #4758045
05/15/18 03:36 PM
05/15/18 03:36 PM
New York
New York
I am not familiar how to test for that other than the harness plug-in that is on top of the compressor which lies under the alternator. From under the vehicle, with the plastic in the right wheel well as the plastic under the radiator housing removed, access is still very limited to the harness connection. Without pulling the power steering reservoir and some other supports, there is no other way I know how to probe that feed.
Since it appears by the rpm drop that the PCM is sending signal to the coil and the 7.5 and relay is good, the probability in a bad wire connection without a blown fuse is?
Is there is different layman's method?
Re: 2009 Honda CR-V Air Conditioning [Re: KrisZ] #4758050
05/15/18 03:44 PM
05/15/18 03:44 PM
Pittsburgh,PA U.S.A.
JimPghPA Online content
JimPghPA  Online Content
+1
72 PSI might be too low of a pressure to activate a pressure switch.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: 2009 Honda CR-V Air Conditioning [Re: Recalculating] #4758052
05/15/18 03:48 PM
05/15/18 03:48 PM
Southern VA
klt1986 Offline
klt1986  Offline
Southern VA
Curious to see some brands of compressors to use or ones to avoid as I'm getting ready to change the compressor in my 08 CR-V. I replaced the relay about a month ago but there are still times the clutch will not engage. Yesterday it stopped working while my wife was driving home on a 95 degree afternoon. However, after it sat in the shade for a couple hours it worked fine.
I thought about changing the clutch but the car is 10 years old and has 145k on it.
Looks like Rock Auto has a Denso for a little under $300. When changing the compressor, what other components should be changed?
Wife: 08 Honda CR-V 4WD, M1 5W-20
Me: 11 Toyota Tundra DC 4WD 5.7L, PP 5W-30
Me Work: 06 Ford Explorer 4WD 4.0L, Pennzoil 5W-30
Son: 14 Toyota Corolla S, M1 AFE 0W-20
Re: 2009 Honda CR-V Air Conditioning [Re: Recalculating] #4758056
05/15/18 03:58 PM
05/15/18 03:58 PM
KrisZ Offline
KrisZ  Offline
Since access is limited check if you are getting 12V at the fuse.
Re: 2009 Honda CR-V Air Conditioning [Re: Recalculating] #4758063
05/15/18 04:03 PM
05/15/18 04:03 PM
New York
New York
Since I still have static pressure with no internal compressor issues, I was just going to buy a new compressor and do the swap. After getting the new one up and running with all specs noted, I would take the original clutch and coil off and replace then store properly in case the new purchase goes belly up.
So Jim is thinking 72 psi in 70F is too low in the low side to activate the switch?
Re: 2009 Honda CR-V Air Conditioning [Re: JimPghPA] #4758064
05/15/18 04:03 PM
05/15/18 04:03 PM
Chris142 Offline
Chris142  Offline
+1
no. More like 20 psi.
Re: 2009 Honda CR-V Air Conditioning [Re: Recalculating] #4758066
05/15/18 04:05 PM
05/15/18 04:05 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
I am not sure what Honda uses, for Toyota, I used Denso Compressor.
It is about the same price as aftermarket.
The good aftermarket is Sanden original, a lot of CKO Sanden.
  • 2017 Toyota Sienna
Re: 2009 Honda CR-V Air Conditioning [Re: KrisZ] #4758067
05/15/18 04:05 PM
05/15/18 04:05 PM
New York
New York
I am getting 12v @ the fuse.
Re: 2009 Honda CR-V Air Conditioning [Re: Recalculating] #4758068
05/15/18 04:06 PM
05/15/18 04:06 PM
Chris142 Offline
Chris142  Offline
If you can see the clutch wire straighten out a coat hanger,grind a sharp point on one end and use that to pierce the wire. Then test for 12v at the wire with a voltmeter.
Re: 2009 Honda CR-V Air Conditioning [Re: klt1986] #4758089
05/15/18 04:38 PM
05/15/18 04:38 PM
New York
New York
You might want to put some gauges on it to see what the pressures are. You maybe low on R134a.
Re: 2009 Honda CR-V Air Conditioning [Re: Recalculating] #4758105
05/15/18 05:02 PM
05/15/18 05:02 PM
KrisZ Offline
KrisZ  Offline
Personally compressor replacement would be the last resort, especially since the problem most likely lies with the clutch and coil, not compressor internals. Opening the system up is always risky. It all sounds good on paper, but the reality is different.
Plus I don't think Honda AC compressors have a pressed in clutch and coil, it's just held by a bolt. Removal should be quite easy.
Re: 2009 Honda CR-V Air Conditioning [Re: Recalculating] #4758108
05/15/18 05:04 PM
05/15/18 05:04 PM
WY
sloinker Offline
sloinker  Offline
WY
Double make sure that you are getting the voltage at the compressor. If you are then you should buy a new accumulator/dryer along with the new compressor. A shop will have to vacuum out the old refrigerant and will credit it to your account. A vacuum will need to be applied to the repaired system until any moisture is boiled out before recharging. GoodLuck!
Page 1 of 3 1 2 3
