Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
112 registered members (69Torino, 1.8Tango, advocate, 4WD, andyd, 69GTX, 11 invisible), 1,821 guests, and 31 spiders.
Topics296,898
Posts4,961,183
Members66,997
Most Online2,688
Yesterday at 11:12 AM
Depressing caliper pistons #4757520
05/15/18 02:40 AM
05/15/18 02:40 AM
United States of America
mjoekingz28 Offline OP
I was wondering if it is good practice to open the brake bleed screw before compressing the piston while installing new pads.
It seems it would expel the fluid you cannot remove with a flush (as I have read on here) and also make the piston retract easier as it doesn't have to push fluid into the reservoir.
Downside though is a slight bleed is required.
Re: Depressing caliper pistons [Re: mjoekingz28] #4757548
05/15/18 04:46 AM
05/15/18 04:46 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Why is that a downside?
Admittedly a full bleed would be better, but a slight bleed seems better than none.
Re: Depressing caliper pistons [Re: mjoekingz28] #4757549
05/15/18 04:47 AM
05/15/18 04:47 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
IMO, this is the best way to depress the pistons as it doesn't push back dirty fluid into the system. Many techs don't do this and may not have any issues either way. But, I like opening the bleeder.
However, first try pushing back the piston(just a little) without opening the bleeder. If the piston doesn't move or is difficult to push back, you may have a slightly blocked hydraulic line/brake hose. If the piston is easy to push bake w/o the open bleeder, then proceed to open the bleeder and finish pushing back the piston. This is only for testing and something I like to do.
Continue to bleed the whole system as good PM.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Depressing caliper pistons [Re: mjoekingz28] #4757583
05/15/18 05:58 AM
05/15/18 05:58 AM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
I always bleed the caliper until clean fluid comes out prior to pushing the pistons back in. It just keeps junk from getting up the brake pipes.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: Depressing caliper pistons [Re: mjoekingz28] #4757613
05/15/18 06:53 AM
05/15/18 06:53 AM
hawthorne, Ca.
46Harry Offline
46Harry  Offline
hawthorne, Ca.
I always open the bleeder screw when depressing the caliper piston as it keeps the trash that has built up from being pushed back into the hydraulic system.
Re: Depressing caliper pistons [Re: mjoekingz28] #4757649
05/15/18 07:34 AM
05/15/18 07:34 AM
Michigan
ZZman Offline
ZZman  Offline
Michigan
I assume opening the bleeder makes it super easy to push the piston in?
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram Ultra
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: Depressing caliper pistons [Re: mjoekingz28] #4757658
05/15/18 07:43 AM
05/15/18 07:43 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Just use a big flat blade screwdriver and wedge it between the rotor and floating side of the caliper and lever compress. This is for the NOT RECOMMENDED quick pad slap. No fancy Clamps required.
Now, It Better and more Professional to do a complete flush all 4 corners.
If I was working on a nice car I liked; I would bleed when compressing through a rubber hose into a waste can of DOT 3. I HATE brake fluid - always have. The suff down at the business end is watery, corrosive and just plain bad.
2019 VW Jetta S,6M OCI#0 62mi-Castrol Edge Prof VW508+OE Filter; '17 Subaru Crosstrek CVT OC#5 37K mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Depressing caliper pistons [Re: mjoekingz28] #4757684
05/15/18 08:01 AM
05/15/18 08:01 AM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
If you are going to bleed anyway, what difference does it make if some dirty fluid gets pushed up the brake line? Like a foot or two?
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Depressing caliper pistons [Re: mjoekingz28] #4757737
05/15/18 08:30 AM
05/15/18 08:30 AM
Canuck living in California
KrisZ Offline
KrisZ  Offline
I don't do this.
My rationale is that, if the junk is in the piston, contacting the seals, etc. and not having negative effects, what harm will it do if it gets pushed back into the steel brake lines? It's not going to go all the way back to the master cylinder.
Also, I have never seen the "junk" people mention. Maybe few "floaters" when looking directly at a strong source of light. Otherwise the brake fluid in my vehicles looks like aged whiskey.
2015 Dodge Grand Caravan-30k miles.
2007 Ford Focus ZX3-110k miles
2006 Mazda 3-168k miles
Re: Depressing caliper pistons [Re: mjoekingz28] #4757744
05/15/18 08:38 AM
05/15/18 08:38 AM
Wisconsin
emmett442 Offline
emmett442  Offline
Wisconsin
I still think this is all a myth.
Where is the "dirt" and "junk" in the fluid coming from? The fluid in filling the caliper bore is the same fluid that's in the lines and master cyl. It's a sealed system. If air and fluid can't get passed the caliper piston, how's dirt and junk going to? There's no reason for the fluid in the caliper to be any more dirty than the rest of the system.
I prefer to compress with the bleeder closed so I can "feel" the condition of the calipers and the rest of the system. It's harder to notice a sticking caliper piston, collapsing brake hose, etc if the bleeder is open.
I do crack the bleeder loose afterwards, but that's to enure that the bleeder itself stays free and doesn't sieze in the caliper. Every time I check or replace the brakes, I remove the bleeder, anti sneeze, and reinstall.
2011 Ford Crown Victoria LX 4.6L V8 auto
2009 Chevrolet Malibu LT 2.4L I4 auto
1974 Dodge D200 360 V8 4 speed manual
Re: Depressing caliper pistons [Re: emmett442] #4757783
05/15/18 09:23 AM
05/15/18 09:23 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
I've never seen a used caliper bore without junk in it. I dunno if it's from the piston moving in/out, seal material, or the fact it's the closest area to the outside world.
Problem is, the heavy bits are going to lay and stay in the bottom no matter what you do. The bleed screw is up top. If you're confident the bleeder is going to move and re-seat, I'm all for cracking it prior to compressing the piston.
I'm hit/miss in doing this. Depends how much time I've got and how in-depth I wanna go.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Depressing caliper pistons [Re: mjoekingz28] #4757918
05/15/18 12:07 PM
05/15/18 12:07 PM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
I've the hole so packed with crud, I had to use a needle to clear it. BF attracts water, water and air cause corrosion in the cylinder bores when the water boils off.
Thick oil is better grin2
Re: Depressing caliper pistons [Re: mjoekingz28] #4758355
05/15/18 11:39 PM
05/15/18 11:39 PM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
I too have no idea where the crud comes from but I've seen it. Sometimes after doing a brake fluid change at all four wheels I'll find the jar has some kind of sediment on the bottom. The jar is capped except for a hole at the top for the tube to go through so it must have come from the fluid.
There's also some kind of sediment inside the reservoir sometimes.
As for whether I open the bleeder when I depress the piston, I like to change the fluid at the same time I do anything that involves depressing the piston. I usually change the fluid first, then depress the piston without opening the bleeder since I know I have clean fluid. I have depressed the piston with the bleeder open sometimes too though.
2015 Civic LX Coupe
Re: Depressing caliper pistons [Re: ARCOgraphite] #4758418
05/16/18 04:54 AM
05/16/18 04:54 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Originally Posted By: ARCOgraphite
J I HATE brake fluid - always have. The suff down at the business end is watery, corrosive and just plain bad.
Then someone isn't changing it often enough. Maybe me.
Re: Depressing caliper pistons [Re: emmett442] #4758428
05/16/18 05:13 AM
05/16/18 05:13 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Where is the "dirt" and "junk" in the fluid coming from?........It's a sealed system.......................................................... Every time I check or replace the brakes, I remove the bleeder, anti sneeze, and reinstall.
Maybe someone is putting anti-seize in it? Y'know, oil-based, rubber incompatible stuff?
That (fairly slim admittedly) possibility aside, if it was a completely sealed system, you'd never have to change your brake fluid.
You do.
So it isn't.
Given that it isn't, its a fair bet that it isn't uniformly permeable, so there may be local concentrations of water. I've seen it stated that water gets in via hose permeability. If that's true, it perhaps also gets in through the piston seal. This would tend to produce a higher concentration of water in and behind the pistons.
In addition, there is movement and friction in the pistons (and master cylinder) which will tend to put debris from seal and bore wear into the fluid.
I've never seen an analysis of the distribution of water and debris in the system, but anecdotally the first bit of bleed tends to be darker, which tends to confirm expectation.
So if its a myth, its at least an unusually reasonable one, as myths go.
