Brake Caliper Dampers?
by HangFire. 01/18/19 11:32 AM
Fully Formulated Coolant and old radiator
by Wheel. 01/18/19 11:27 AM
'15 6.7 Powerstroke UOA
by roadrunner1. 01/18/19 10:18 AM
Automotive Battery Voltage -What is ur reading?
by Patrick0525. 01/18/19 10:10 AM
Amsoil 0w-40 vs 5w-40
by Buddyp. 01/18/19 10:07 AM
M1 is changing their oils, site and adding a new oil
by Flashlightboy. 01/18/19 10:01 AM
Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
100 registered members (2019StingrayZ51, andyd, badtlc, Best F100, Black_Thunder, 15 invisible), 2,224 guests, and 41 spiders.
Topics296,781
Posts4,958,806
Members66,969
Most Online2,577
Jan 14th, 2019
Need advice about spark knock #4757222
05/14/18 05:29 PM
05/14/18 05:29 PM
Upstate S.C.
The_Captain Offline OP
Upstate S.C.
Fellow Oil brothers and sisters,
I have a 2017 Jeep Wrangler unlimited. It is equipped with an automatic and 3.21 rear end . The problem is I have spark knock (rattle) when I accelerate or accelerate on hill. It doesn't do it all the time but it happens fairly often. I have tried various fuel treatments and different octane fuels from different top tier stations. It seems to not do it as much when I use 89 or 93 octane. The dealership states they can't recreate the issue. The next time I go in for service I will see if I can get a tech to go along for a ride. It has not thrown any codes. The vehicle has just under 14,000 miles. It has done it the entire time I have owned it. Any thoughts? Guess on what the issue may be? I appreciate any tips or advice. Thanks
2017 Jeep Wrangler Unlimited 4x4 with Castrol Full Synthetic (gold bottle) with Fram Ultra oil filter.
Re: Need advice [Re: The_Captain] #4757245
05/14/18 05:46 PM
05/14/18 05:46 PM
TX
KJSmith Offline
KJSmith  Offline
TX
Contact whatever manufacturer that owns them this week and start a file.
They can put monitors on it and see what's happening.
Re: Need advice [Re: The_Captain] #4757265
05/14/18 06:13 PM
05/14/18 06:13 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
It's to new to have manually adjustable timing settings. But my guess is the knock sensor is not right, or the ECU is not seeing the signal, etc.
A little bit now and then is OK, and it indicates that you are running as close to the edge as possible - good for fuel economy. But if it's persistent, that is bad ...
Re: Need advice [Re: The_Captain] #4757271
05/14/18 06:17 PM
05/14/18 06:17 PM
Ontario, Canada
OVERKILL Online content
OVERKILL  Online Content
Ontario, Canada
There may be a PCM update for this to rectify it. There was for the 6.4L in the GC.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: Need advice [Re: The_Captain] #4757291
05/14/18 06:31 PM
05/14/18 06:31 PM
Cajun Country, La.
BlueOvalFitter Offline
Cajun Country, La.
WOW, what you described here in your post is exactly what happened to my current truck, in 2008.
I bought my 07 F150 new off of the lot with 6 miles on it. From about 7-8K miles the engine would knock, detonate, ping very heavily upon acceleration, or climbing hills. It sounded like 10 wood peckers on a street light! At 14K miles I brought it to the dealer. They could recreate the problem but couldn't figure out why. Finally, the shop foreman told the tech. to look at the piston crowns with a bore scope. Sure enough, HUGE amounts of carbon on the piston crowns.
They kept my truck for 2 weeks. They provided a rental, FREE of charge. A Ford engineer was called in to figure out what was wrong. The PCV system was allowing copious amounts of oil into the intake manifolds, going directly into the cylinders. The engineer figured it out and all was good. But, the WHOLE top end of my engine had to come apart to clean the piston crowns. They were cleaned with some kind of buffer wheel. The intakes were cleaned in parts tanks. They held up the intakes and oil literally poured out from them!
After physically cleaning everything, the tech. put the top end back together. He hooked up a BG Air Intake Cleaning device to my engine. The tech. then ran a few cans of BG cleaning solution thru the engine until he was satisfied EVERYTHING was clean.
My truck has run fine since. I guess you can say a catch can would have helped in this situation.
Re: Need advice [Re: The_Captain] #4757366
05/14/18 07:31 PM
05/14/18 07:31 PM
pa
benjy Offline
benjy  Offline
pa
like the girlfriends 08 suby legacy 2.5 + 4 spd auto, it pinged on any grade + got poor MPG's, easy cure was dump it after less than a year. she wanted a subie for a while but that cured her!!! VW jetta 5 cyl 2.5L 6 spd automatic replace it, a good car with great MPG's!!
Re: Need advice [Re: BlueOvalFitter] #4757511
05/15/18 01:50 AM
05/15/18 01:50 AM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
I wish we knew what the engineer figured out as being the cause.
Re: Need advice [Re: The_Captain] #4768664
05/26/18 10:18 AM
05/26/18 10:18 AM
Upstate S.C.
Upstate S.C.
Any other thoughts or suggestions?
