Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
Starter cross reference?
by dlundblad. 01/22/19 05:11 AM
Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
How cold is it? (Humor)
by StevieC. 01/21/19 07:13 PM
Slight performance decrease
by A_User55555. 01/21/19 06:54 PM
Binco, Coolbreez1973, jmcast1127, DF8005, FT86dude11
67009 Registered Users
108 registered members (53' Stude, AmoryBlaine, 4WD, 2015_PSD, AndyB, 15 invisible), 1,843 guests, and 37 spiders.
Topics296,966
Posts4,962,553
Members67,009
Most Online2,821
Jan 21st, 2019
Strange multimeter reading #4757152
05/14/18 04:29 PM
05/14/18 04:29 PM
Michigan
Loogie Offline OP
Loogie  Offline OP
Michigan
I was checking my wife's car for parasitic draw. I attached my Innova 3320 multimeter (has been very accurate so far) leads betweeen the negative cable and negative post. On the 10A scale ( 200mA to 10A) it reads .029. On the 0-200mA scale it reads 0.00. I checked everything repeatedly and have no clue what I'm seeing. 290mA should read 0.290. 29mA should show on the 0-200mA scale.
What is up?
Bob
Re: Strange multimeter reading [Re: Loogie] #4757165
05/14/18 04:40 PM
05/14/18 04:40 PM
Nokesville, VA
brianl703 Offline
brianl703  Offline
Nokesville, VA
Two possibilities:
1)You need to switch the positive meter lead to the far right jack. The far left jack is ONLY for the 10A range.
2)The fuse for the 200mA scale is blown. Replace it.
Re: Strange multimeter reading [Re: Loogie] #4757206
05/14/18 05:14 PM
05/14/18 05:14 PM
Michigan
Loogie Offline OP
Loogie  Offline OP
Michigan
The leads are in the correct jacks.
I was able to get a reading of 0.01-0.02mA on the 0-200 scale, so I think the fuses are ok.
Interestingly, when I first connect the leads on the 10A scale, it first reads .080 and after about 10 seconds it drops to .029.
I assume something is powering up and settling down (computer, stereo antitheft, etc).
I'm getting the same reading from two multimeters.
This is maddening and embarrassing because I'm a former master mechanic...yes... specialized in driveability. smile
Bob
Re: Strange multimeter reading [Re: Loogie] #4757229
05/14/18 05:36 PM
05/14/18 05:36 PM
pa
benjy Offline
benjy  Offline
pa
i am just learning about multimeters + bought an EXTECH #470 just under a buck, thought i was using it wrong + it failed to display at times, bought a Klein recently + know i know the out of warranty Extech is a piece of poop!!
Re: Strange multimeter reading [Re: Loogie] #4757235
05/14/18 05:40 PM
05/14/18 05:40 PM
Michigan
Loogie Offline OP
Loogie  Offline OP
Michigan
Yeah, I could have 2 bad multimeters.
But it is interesting that they both read the same.
Re: Strange multimeter reading [Re: Loogie] #4757273
05/14/18 06:22 PM
05/14/18 06:22 PM
Great Lakes
Quattro Pete Offline
Great Lakes
What cars is this?
When I first connect the battery on my 530i, there is several amps of current being drawn initially as all the various courtesy lights come on. If I tried that with my DMM on the mA range, it would easily blow the fuse.
Silly question, but are you using the DC range and not AC range on your DMM?
I usually prefer to use the 10A range anyway - it's more accurate on most DMMs, even if it gives you less resolution.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Strange multimeter reading [Re: Loogie] #4757285
05/14/18 06:29 PM
05/14/18 06:29 PM
Tennessee
SWS Offline
SWS  Offline
Tennessee
The meterís internal impedance is probably very different between the 2 current ranges.
I run into this weirdness even with high-end Fluke meters on various circuits.
Since you have 2 meters, as a check, here is an idea:
With one meter measure current on both ranges,
while measuring voltage drop with the other meter.
Re: Strange multimeter reading [Re: SWS] #4757296
05/14/18 06:34 PM
05/14/18 06:34 PM
Great Lakes
Great Lakes
Yup. There is something called high internal burden voltage that skews mA range results on most DMMs.
http://www.fluke.com/fluke/uses/comunidad/fluke-news-plus/articlecategories/electrical/burdenvoltage
But I don't think this alone could account for the strange results that OP is seeing. Something else is going on.
Re: Strange multimeter reading [Re: Loogie] #4757314
05/14/18 06:42 PM
05/14/18 06:42 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Put the two DMMs in series??
In ammeter mode they should read similarly.
Re: Strange multimeter reading [Re: Loogie] #4757340
05/14/18 07:03 PM
05/14/18 07:03 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Bob
Looks like your 10A scale is working, .080 amps equals 80 milliamps, .029 amps equals 29 milliamps. It you want to further test this......With the meter hooked in series, Take a incandescent test light hooked to the positive battery terminal & probe a good ground on the engine somewhere, The meter should increase to around 1/2 a amp or 500 milliamps.
I use a test light because it's a fairly known low load device for the 10a scale. IIRC some cheap multimeters are not fused on the 10a scale!
It also looks like your milliamp jack fuse is blown, VERY easy to do!!! Never complete the circuit with the 2 amp milliamp jack fuse or the 10a amp jack fuse! Use a jumper wire to do the initial hook-up....Wait a few minutes to let the modules go to sleep. Unhook the jumper wire to allow the current to flow through the meter.
29 milliamps is right where you want to be with a basic modern car. Some upscale vehicles will draw more.
2001 Chevy Camaro L92/4L80E
Re: Strange multimeter reading [Re: Loogie] #4757372
05/14/18 07:35 PM
05/14/18 07:35 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
The load the vehicles electronics is placing on the vehicles battery could include that of some type of switching voltage regulator that draws power in pulses and there is a wide range of frequencies that such switchers could operate at. When a switcher draws power in pulses it could throw off the readings that an electronic Amp/milliamp meter produces.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Strange multimeter reading [Re: Loogie] #4757378
05/14/18 07:39 PM
05/14/18 07:39 PM
JimPghPA Offline
JimPghPA  Offline
It would be interesting to put a shunt resistor in series with one of the leads to the vehicles battery and then read the voltage across the shunt resistor with a digital storage oscilloscope.
JimPghPa
Re: Strange multimeter reading [Re: Loogie] #4757494
05/14/18 11:32 PM
05/14/18 11:32 PM
Reno, NV
redbone3 Offline
redbone3  Offline
Reno, NV
The different ranges have different impedences and change the readings because the higher the impedence the lesser the current. Plus, the accuracy of a multimeter is normally a percentage of full scale, on the 10 amp range the acceptable error is probably greater than the reading!!!
2014 Passat Wolfsburg, 1995 Miata.
Re: Strange multimeter reading [Re: Loogie] #4757518
05/15/18 02:27 AM
05/15/18 02:27 AM
Michigan
Loogie Offline OP
Loogie  Offline OP
Michigan
Wow, some excellent observations and ideas, thanks!
My skills are very rusty, I haven't practiced in nearly 25 years.
The car is a 2003 CRV. It does have some type of electronic voltage or current management system. I replaced the part maybe 8 years ago.
Anyway, what was throwing me off is I thought the multimeter's scale wasn't matching the readings. I used a couple of meters at the dealer (one was a Fluke, I think) that absolutely would not give a reading unless on the proper scale.
I will assume the mA scale is goofed, and the 10A is reading correctly.
Funny, I started on the 10A scale and waited for it to settle. Only then did I switch to mA. I wonder if there is some sort of electronic switching going on that pulsed higher current, torching the mA scale.
I'll hook up a Nichia and see if the mA scale is torched.
Bob
Re: Strange multimeter reading [Re: Loogie] #4757519
05/15/18 02:36 AM
05/15/18 02:36 AM
Great Lakes
Great Lakes
Bob
Switching from 10A to mA range would require you to move the test lead from the 10A socket to the V/mA socket on your 3320. This would temporarily break the circuit and be perceived by the car as reconnecting the batterry again which may result in high initial current being pulled by the car again.
If you did not move the test lead to mA range and only shifted the range dial, then no wonder you did not get any reading. smile
