Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
2018 Silverado 6.0 Idle Stumble
by Phishin - 07/05/20 10:20 AM
U.S. Gasoline Production
by Snagglefoot - 07/05/20 07:39 AM
Trying to save an otherwise junkyard bound car
by agarb - 07/05/20 07:08 AM
Code reader advice
by 53' Stude - 07/04/20 10:05 PM
TacoFergie, electro, SilentC, paolo9fla, SunnyB
71850 Registered Users
83 registered members (4WD, andyd, BeerCan, 928, 53' Stude, barryh, 12 invisible), 2,067 guests, and 21 spiders.
Topics307,455
Posts5,311,445
Members71,850
Coolant and power steering filtration added to Vic #4753681 05/11/18 01:57 AM
Colt45ws Offline OP
Installed this a couple weekends ago. Power steering is a Wix 51269 Hydraulic filter, Coolant is a Fleetguard WF2107 non-chemical coolant filter. The Coolant filter is the Wix base, and I modified this existing bracket on the front of the engine to hold it.
The PS is a 3/4-16 remote head, I think its a Derale, but its a pretty generic part. I drilled and tapped the frame for the bolts. I just inserted it into the existing return line from the steering rack.
I still have a trans filter to install. For that I am using a 6um Donaldson filter & head. I have to finish making the bracket to hang it. Between finding motivation and being busy with other stuff I havent had time to do it. Im hoping this weekend. Look clear so far.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Coolant and power steering filtration added to Vic [Re: Colt45ws] #4753686 05/11/18 02:52 AM
Z
zorobabel Offline
Z
Nice! Going for a million miles eh?
Is the Wix filter base smaller than the Derale?
I don't think a coolant filter is really needed.
Now you just need to filter the ATF and the refrigerant smile
1997 Maxima 210k, Castrol GTX Synblend 5W-30, PL14459
2004 Corolla 211k, Valvoline SynPower 5W-30, K&N HP-1003
Re: Coolant and power steering filtration added to Vic [Re: Colt45ws] #4753751 05/11/18 05:48 AM
J
JC1 Offline
J
Nice job. What did it cost parts wise for everything?
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Coolant and power steering filtration added to Vic [Re: Colt45ws] #4753777 05/11/18 06:25 AM
SubieRubyRoo Offline
Love it! But... there's a zero chance for ROI on these filter systems. Especially on a car that's 15 years old. If cars truly needed systems like these they'd be available from the factory.
But great show of ingenuity and determination! Thanks for the pics.
De omnibus dubitandum.
Re: Coolant and power steering filtration added to Vic [Re: Colt45ws] #4753811 05/11/18 07:06 AM
AZjeff Offline
What are the odds of failure causing contamination in these systems? Do CVs have problems?
Props for tidy installs regardless.
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, 0W-20 QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Coolant and power steering filtration added to Vic [Re: Colt45ws] #4754179 05/11/18 12:27 PM
dogememe Offline
lolwut. filter for atf i understand but for power steering or coolant? waste of time and money
Originally Posted By: AZjeff
Do CVs have problems?.
nope, no known/common issues due to fluid filtration or lack thereof.
2010 Ford Escape 2.5 ~104K Miles: AMSOIL Signature Series 0W-30, Wix Filter.
2001 Chevy Suburban 5.3 ~293K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: Coolant and power steering filtration added to Vic [Re: JC1] #4754429 05/11/18 06:27 PM
Colt45ws Offline OP
Because I can.
For all three filter (ATF not installed but waiting) setups, fittings, hoses Im into it about $250 or so.
-Colton
Re: Coolant and power steering filtration added to Vic [Re: Colt45ws] #4754818 05/12/18 08:01 AM
53' Stude Online Content
Online Content
Colton: i dont care what others think or say. I say great job on install smile
2009 Toyota Camry LE
Re: Coolant and power steering filtration added to Vic [Re: 53' Stude] #4755442 05/12/18 10:04 PM
AZjeff Offline
Absolutely. Good looking work. Just changing fluids would be more cost effective but not nearly as interesting.
What's next?
Re: Coolant and power steering filtration added to Vic [Re: Colt45ws] #4755480 05/12/18 11:25 PM
Colt45ws Offline OP
For power steering, yeah probably. But my experience with older mistreated cooling systems is you can flush and flush and flush and flush some more and never get it clean. Then you have gallons upon gallons of used coolant to somehow dispose of. For me I have to drive 18 miles north to the county dump to get rid of it, and only during business hours M-F, while Im working.
When I change the filter, I lose like a quart of coolant, and thats it.
For PS it also adds a convenient drain plug of sorts. When you remove the filter, all the fluid above that level will drain out, leaving only what is in the rack. Bad part is you have to fill the filter before installing it or it will take the entire reservoir capacity and the pump will end up sucking air.
This is a hobby like anything else. Heck, I just committed to buying $900 worth of high power trunk mount Motorola radios to get on the 2m and 70cm ham bands. By the time I get finished with those and my stereo and amps Ill have more electronics in my trunk than the car is worth.
-Colton
Re: Coolant and power steering filtration added to Vic [Re: Colt45ws] #4756760 05/14/18 10:03 AM
Z
zorobabel Offline
Z
There is the option of refilling the PS reservoir as the car is started, or better, refilling while turning the steering wheel from lock to lock, with engine stopped and wheels off the ground.
Re: Coolant and power steering filtration added to Vic [Re: Colt45ws] #4760357 05/17/18 08:44 PM
Colt45ws Offline OP
When I installed the transmission filter, I went back into this and sleeved the hoses to protect them from being rubbed and damaged.
Pic of the final install, now.
I also changed the filter, so I could see what accumulated after 1k miles. But I cannot find where my filter cutter went. We recently cleaned the garage out and that was one of the things I found a new home for, but now I dont remember where that is. Hopefully Ill find it sometime soon and be able to cut it.
-Colton
Re: Coolant and power steering filtration added to Vic [Re: SubieRubyRoo] #4767207 05/24/18 06:32 PM
O
OilFilters Offline
O
LOL!
Only if the lawyers/bean counters/EPA had a need for it. They prefer your car wear out at 100-200k so you turn it in and buy a new one. All manufacturer support is long over at 100k, but most reasonable people expect their cars to last at least 3 times that.
Smoking since the age of 12 won't cause caner...if you shoot yourself before 30.
Re: Coolant and power steering filtration added to Vic [Re: Colt45ws] #4812856 07/13/18 02:42 AM
DoubleWasp Offline
Coolant filters are good to have on a system that has previously been contaminated. The cat can come back, and the heater core is usually the victim.
Re: Coolant and power steering filtration added to Vic [Re: Colt45ws] #4812878 07/13/18 04:50 AM
DoubleWasp Offline
Almost forgot to add: In independent fleet testing, water pumps last 3 times longer with a coolant filter than without.
OEM could care less about the water pump lasting any longer than warranty, if even that. Power steering filter will help the pump and rack go the distance as well.
