Walmart and Valvoline
by Bullwinkle007. 01/22/19 09:10 PM
Getting Our Kicks On Route 66
by 2015_PSD. 01/22/19 08:40 PM
Uploading a short film clip from an IPhone.
by Snagglefoot. 01/22/19 07:52 PM
Purolator L34631 (torn media)
by LDM. 01/22/19 07:51 PM
THIS close to getting a VDB today at TPA
by 14Accent. 01/22/19 07:48 PM
Supco Appliance Parts.
by George7941. 01/22/19 07:36 PM
Unusual Jury summons.
by Chris142. 01/22/19 06:31 PM
Vibration feeling after new tires installed?
by MONKEYMAN. 01/22/19 05:51 PM
Sudden Shake - ‘18 Accord
by Throt. 01/22/19 05:43 PM
05 Ford 500 Intake hole - melted
by Geauxtiger. 01/22/19 05:41 PM
How's K&N 1004 on Kia/Hyundai GDI
by SlavaB. 01/22/19 05:18 PM
more PSD woes with cold weather
by Donald. 01/22/19 05:10 PM
Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
70 registered members (209paulc, AdRock, 69GTX, askani79705, 10 invisible), 1,156 guests, and 42 spiders.
Topics297,006
Posts4,963,331
Members67,013
Most Online2,821
Jan 21st, 2019
Battery relocation wiring #4756722
05/14/18 08:35 AM
05/14/18 08:35 AM
Australia
Spetz Offline OP
Spetz  Offline OP
Australia
Hi everyone,
I want to move my batter to the trunk.
Can the wiring be as simple as basically extending the +ive wiring and then grounding the battery in the trunk somewhere?
Can I use whatever gauge the +ive wiring at the battery terminal is?
Would the negative wire in the engine bay just be deleted or do I need to ground that as well?
The car is used for track so power load is low and I am doing this for weight distribution reasons
2003 Mitsubishi Diamante 6G74 3.5L. 5 Speed auto. 155,000 miles. Shell Helix Ultra 5W40 at 6k OCI
Re: Battery relocation wiring [Re: Spetz] #4756776
05/14/18 09:16 AM
05/14/18 09:16 AM
California
VeryNoisyPoet Offline
California
You will want to go up a few sizes on the wire gauge for the positive, since long run of wire = more resistance = less power to starter. Perhaps a 1 AWG (42mm^2) or larger. Use heavy duty terminals that crimp to the wire and attach with a big bolt.
Ground the battery in the trunk. Use the shortest cable you can get away with, though this doesn't need to be as huge as the positive cable. Size it the same as the original battery negative cable. Select a beefy bolt and use fine grit sandpaper to strip the contact area down to bare metal for good connection. You can delete the stretch of negative wire that used to connect directly to the battery up front, but make sure that the engine still has a proper ground wire connected to the frame.
Get enough plastic split loom to protect the positive cable all the way up through the car. This stuff is cheap on amazon.
Follow the factory wire harness if you can, using grommets and cable ties to hold the wire firmly in place so the it can't rub on anything sharp. There's no fuse and if that wire shorts to the frame, it will ruin your day.
Consider a battery disconnect switch that can quickly be used to kill power to the whole car in the event of a wreck or fire.
Get a properly sized battery box that bolts to the floor so there's no way for the battery to come loose. Drill a small hole in the trunk floor and get a tube for the battery vent so any gases or acid boil over is directed safely outside the car.
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Battery relocation wiring [Re: Spetz] #4756924
05/14/18 11:30 AM
05/14/18 11:30 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Id get a clamp on meter and get a read for what is max cranking current.
Multiply that by 2.
Find a cable that gives you optimally <5%, but absolutely less than 10% voltage drop for its length at that current.
Ground to a well-welded body point near the battery.
You're probably talking 0-0000 ga cable, depending upon length of run, engine size, etc.
What's the rating of your starter? Another calculation would be starter power rating divided by 10V to give current; then add a bit of extra current as margin, and then calculate voltage drop on the line.
IIRC my 1991 BMW 318i had 00 for the run from battery to starter, and 0 for the body ground in the trunk.
Re: Battery relocation wiring [Re: Spetz] #4757203
05/14/18 05:13 PM
05/14/18 05:13 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Some people buy welding cable to use. I would not suggest you do it. Wiring chafe. Voltage drop. Venting.
I suppose it will stay cooler. But a wiring issue with no fuse on the main wires going to the starter.
Let me know when the vehicle burns from an electrical fire.
If the car manufacturer did it they would route it and protect it properly.
2015 Ford F250 w/Powerstroke
Re: Battery relocation wiring [Re: Spetz] #4757598
05/15/18 06:31 AM
05/15/18 06:31 AM
Australia
Spetz Offline OP
Spetz  Offline OP
Australia
Thanks everyone.
Should I add a big fuse right at the battery in case it shorts between the battery and the front of the car?
Also do I need to vent it as the battery is a sealed type AGM battery?
Re: Battery relocation wiring [Re: Spetz] #4773014
05/31/18 06:39 AM
05/31/18 06:39 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I've put a battery in the trunk on two cars. I just use THHW (water resistant) building wire. 3ga currently on my Gen Coupe, 2 gauge on my old Taurus V8. Starter draw is only 40 amps continuous on the Gen Coupe.
I use the split loom and snake it through the sill channel to the back seat.
I have a 150A 32V fuse at the battery. I also add a ground buss like used in a circuit breaker panel. The main ground I run back to the transmission. This worked noticeably better than the seat belt anchor bolt I was using as the starter spins faster grounded to the aluminum trans bolted to the aluminum engine block.
This picture does not show the ground running from the ground bus to the transmission.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
