(NEW) Wix 51522 Cut Open
by rooflessVW. 01/15/19 10:23 PM
Is this guy for real? (HUMOR)
by StevieC. 01/15/19 10:18 PM
Elf 4T moto tech 10w50 is good?
by firstime911. 01/15/19 09:25 PM
New Champ Filter
by CapitalTruck. 01/15/19 08:30 PM
19 Elantra vs corolla vs civic vs 18 Mazda 3
by wolf_06. 01/15/19 07:28 PM
New guage cluster need to be programed?
by callbay. 01/15/19 07:28 PM
good brand of inner tie rod?
by motor_oil_madman. 01/15/19 07:27 PM
Look at this blast from the past!
by SubieRubyRoo. 01/15/19 05:50 PM
Factory service manuals?
by buck91. 01/15/19 05:49 PM
Road Trip - Drive My Own Car or Rent?
by The Critic. 01/15/19 05:23 PM
‘19 GTI specs 0w-20 508 00
by LotI. 01/15/19 05:22 PM
Fram TG11955
by advocate. 01/15/19 03:03 PM
Bosch Steeltech = Wix?
by Black_Thunder. 01/15/19 02:44 PM
CVT and 6 speed automatic
by jerseyguy123. 01/15/19 01:56 PM
Hypothetical - X6M vs X5M vs AMG GLE63
by OVERKILL. 01/15/19 01:48 PM
2001 dodge neon coolant reservoir
by mobilaltima. 01/15/19 01:38 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
101 registered members (1.8Tango, 2003f7, 71Chevyguy, 97f150, 2015_PSD, 11 invisible), 1,599 guests, and 32 spiders.
Topics296,613
Posts4,955,838
Members66,950
Most Online2,577
Jan 14th, 2019
Napa MaxDrive (Cardone Select) NEW CV Axles #4756089
05/13/18 03:43 PM
05/13/18 03:43 PM
CA
The Critic Offline OP
CA
From my research, I learned that NAPA MaxDrive NEW CV axles are reboxed Cardone Select CV Axles. This was confirmed by the NAPA MaxDrive warranty document which listed Cardone Industries as the company warrantying their product.
The "big 3" manufacturers of NEW CV axles appear to be Cardone, GSP and Surtrack/Trakmotive. From what I have read online and thru various professional groups, the NAPA MaxDrive units (and presumably Cardone Select) seem to have somewhat more favorable reviews than the others.
I recognize that NEW CV axles are problematic compared to OE, which is why I try to reboot OE axles whenever possible. But there are situations where a NEW CV axle is needed and new (or even used) OE is not an economically feasible option.
Does anyone on here have feedback they can share, on the NAPA MaxDrive and/or Cardone Select NEW CV axles?
2011 Toyota Prius - 181k - M1 EP/EP HM Mix 0W-20
2007 Honda Accord 2.4 - 134K - Mobil 1 EP HM 5W-30
Re: Napa MaxDrive (Cardone Select) NEW CV Axles [Re: The Critic] #4756132
05/13/18 04:30 PM
05/13/18 04:30 PM
USA
NHGUY Offline
NHGUY  Offline
USA
The TrackMotive shafts are the old EMPI shafts.For whatever that's worth.
Re: Napa MaxDrive (Cardone Select) NEW CV Axles [Re: The Critic] #4756926
05/14/18 11:31 AM
05/14/18 11:31 AM
Minnesota
Huie83 Offline
Huie83  Offline
Minnesota
I used them in the front of my 99 Subaru Outback with no issues. Anyone who knows Subaru's knows they are very picky with axles.
I only drove it for about a year or 5K miles but it was fine the whole time. No wiggle, play or weird noises.
Re: Napa MaxDrive (Cardone Select) NEW CV Axles [Re: Huie83] #4757066
05/14/18 01:58 PM
05/14/18 01:58 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
The couple of times I have used them from Car quest when new was not available and I needed them yesterday were okay, long term I cant say.
I do know the boots were neoprene so they are garbage right of the hop.
Re: Napa MaxDrive (Cardone Select) NEW CV Axles [Re: The Critic] #4759211
05/16/18 07:38 PM
05/16/18 07:38 PM
CA
CA
Received them today. The boots are definitely neoprene. Will install soon.
Re: Napa MaxDrive (Cardone Select) NEW CV Axles [Re: The Critic] #4759381
05/17/18 12:07 AM
05/17/18 12:07 AM
Alabama
ron350 Offline
ron350  Offline
Alabama
If Neoprene is bad what is the preferred boot material?
ron350
Re: Napa MaxDrive (Cardone Select) NEW CV Axles [Re: ron350] #4759425
05/17/18 04:31 AM
05/17/18 04:31 AM
CA
CA
Most OE axles use thermoplastic boots.
Re: Napa MaxDrive (Cardone Select) NEW CV Axles [Re: The Critic] #4759807
05/17/18 11:04 AM
05/17/18 11:04 AM
California
nthach Offline
nthach  Offline
California
I have a Cardone Select in a friend's beater Chevy Tahoe, it seemed decently made but the diff end had a loose cap. The grease looked like cheap Chinese "moly" stuff.
I packed in some Molygraph grease and tapped in the cap with a dead-blow. The OEM shaft didn't have a cap on the inner joint. I know VWs and RWD Lexus use a cap on the inner joint.
If the passenger side joint goes out, I'm gonna find a OEM Delphi shaft from the junkyard and reboot it.
Re: Napa MaxDrive (Cardone Select) NEW CV Axles [Re: The Critic] #4760476
05/17/18 09:57 PM
05/17/18 09:57 PM
MA
Wolf359 Online content
Wolf359  Online Content
MA
Anyone know who does a good job rebuilding CV axles at a good price? I have the old one out of my MB and it had a leaking boot. I think I caught it early enough. Used a new Cardone select from Rockauto and it's junk. I found a few places online but they want over $200 to rebuild a CV axle. The OE was about 1k so I figured I'd roll the dice and try a new aftermarket Cardone one at $65. They also sell a remanufactured one for about the same price, do you think that is OE or did they just do that to an aftermarket one? Car will need ball joints soon so I'll just have the indy swap the axle when he does the ball joints.
Re: Napa MaxDrive (Cardone Select) NEW CV Axles [Re: Wolf359] #4760541
05/18/18 03:20 AM
05/18/18 03:20 AM
CA
CA
I have heard good things about CVJ Axles in Colorado, but I have not personally used them.
Re: Napa MaxDrive (Cardone Select) NEW CV Axles [Re: ron350] #4760605
05/18/18 05:46 AM
05/18/18 05:46 AM
Trav Offline
Trav  Offline
Thermoplastic or poly. I still get boots for some applications from Rockford and poly from the UK among others
http://www.rockfordcv.com/rcvboot.htm
http://www.duraflexpubushes.com/cv-boots-6-c.asp
Re: Napa MaxDrive (Cardone Select) NEW CV Axles [Re: The Critic] #4760726
05/18/18 07:48 AM
05/18/18 07:48 AM
USA
853okg Offline
853okg  Offline
USA
I have a 98 Acura TL 3.2 and about a year ago I replaced the CV axles with NAPA/Cardones. Truthfully, I was a little leery. But they have worked very well.
I measured them before the install and they looked identical to OEM. They went in easily and have worked perfectly so far (20K).
I've heard good things about RAXLES, but I was in a hurry and didn't have time to wait for them.
Re: Napa MaxDrive (Cardone Select) NEW CV Axles [Re: The Critic] #4760768
05/18/18 08:16 AM
05/18/18 08:16 AM
North Carolina
Urshurak776 Offline
Urshurak776  Offline
North Carolina
I used Cardone select CV joints in my wife's Santa Fe. I had a good alignment done right afterwards. It has been probably 25-30K since we had it done. I always do a good check underneath when I change the oil. No issues to report. Any issues we seem to have are directly related to the absolutely ABYSMAL Firestone Affinity tires we put on there.
2012 Hyundai Santa Fe, 138,000 miles, Havoline Pro DS Full Syn 5W-30, WIX Filter.
2014 Kia Rio, 80,000 miles, Havoline Pro DS Syn 5W-30, WIX Filter.
Re: Napa MaxDrive (Cardone Select) NEW CV Axles [Re: The Critic] #4760817
05/18/18 09:21 AM
05/18/18 09:21 AM
MA
MA
Yeah, I think that's the one that was around $200 an axle.
Re: Napa MaxDrive (Cardone Select) NEW CV Axles [Re: Wolf359] #4761660
05/19/18 05:43 AM
05/19/18 05:43 AM
Watertown, New York
cronk Online content
cronk  Online Content
Watertown, New York
I got a set of rebuilt cv shafts from "Raxles" and they were good quality. Had the vehicle about 5 years after installing them and never any issues.
https://www.raxles.com/
You may be able to send in your original and have it rebuilt.
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
