Supertech Heavy Duty 15W40 ...$9.64
by dblshock. 01/22/19 08:53 AM
Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
Starter cross reference?
by dlundblad. 01/22/19 05:11 AM
Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
How cold is it? (Humor)
by StevieC. 01/21/19 07:13 PM
Binco, Coolbreez1973, jmcast1127, DF8005, FT86dude11
67009 Registered Users
105 registered members (Ag76, 53' Stude, AmoryBlaine, 4WD, 2015_PSD, 16 invisible), 1,856 guests, and 32 spiders.
Topics296,968
Posts4,962,580
Members67,009
Most Online2,821
Jan 21st, 2019
Oil Consumption by Design #4756015
05/13/18 02:03 PM
05/13/18 02:03 PM
Azerbaijan
NICAT Offline OP
NICAT  Offline OP
Azerbaijan
Some engines, such as volkswagen engines, are famous for consuming oil by design. As much as 1 liter per 1000 mile smile
My question is, does this theoretically mean less ring tension, thicker oil film at the cylinder wall, thus less wall and piston rings wear ?
Re: Oil Consumption by Design [Re: NICAT] #4756070
05/13/18 03:25 PM
05/13/18 03:25 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
Ive seen some high mileage engines with the original hone marks still in the cylinder walls. I dont piston wear is not a problem within warranty period. There must be another reason. The race community burns some oil to make more hp. I wonder if this is what they are doing.
Re: Oil Consumption by Design [Re: NICAT] #4756147
05/13/18 04:48 PM
05/13/18 04:48 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
My wife owns an Audi and I own a VW Golf GTI. I need to add 1/2 a quart at the 4K mile mark and I change the oil every 5K miles.
My wifes Audi doesn't consume enough oil to make it worth adding.
I have heard some engines consume oil by design. Sounds silly but who knows?
I'm a semi mechanic and another much older mechanic told me some engines have soft piston rings that seal great
but wear out faster and some engines have harder piston rings that last longer but don't seal as well.
Years ago when I was building a small block Chevy, he told me the cheap Hastings piston rings are great for 60K! thousand miles
and the engine will start burning oil.
Click on the piston rings and learn something:
https://www.hastingspistonrings.com/aftermarket
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: Oil Consumption by Design [Re: NICAT] #4756503
05/14/18 04:50 AM
05/14/18 04:50 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
I think pretty much every modern (post emissions-era) engine burn oil "by design" because it's mandated that oil blow-by can't vent to the atmosphere. A typical emissions setup has the PCV valve connected by a hose to the intake, where blow-by gas (oil vapour from the bottom of the crankcase) burns with the intake charge.
As any internal combustion engine will have pressure and temperature variations that are going to create blow-by gases; something has to be there to take care of it. Pre-emissions engines just vented it to the atmosphere (oil "breathers" on the intake valve cover(s) ) or going back to the 50's and earlier just let it drip onto the ground.
You can alternately vent the blow-by gas to a catch can, racers do this, but that means emptying the catch can periodically. No OEM is going to make owners do that.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Oil Consumption by Design [Re: NICAT] #4756506
05/14/18 04:58 AM
05/14/18 04:58 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Cart horse inversion...
Low tension rings are to reduce drag, not wear, and oil consumption is (often) a result...which manufacturers then try to pass off 1qt/1,000 miles as "normal"...then when it's too bad, they add a dipstick with an altered "normal range" so it doesn't look so bad...then mandate lower P to protect emissions control devices on the ones that are bad, but now "normal".
No-one is purposely designing oil consumption IN to an engine (except for e.g. Mazda Rotaries). Their designs are causing increased oil consumption for other factors.
Re: Oil Consumption by Design [Re: NICAT] #4756517
05/14/18 05:23 AM
05/14/18 05:23 AM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
My last 6 engines which were sold at 100,000 + miles never used more than 4 oz of oil in a 6,000 mile OC. Saab 2.0/Jeep 4.0/Subaru 2.5L/ Mazda CX7 and now my Mazda 2.5 at 42,000 miles. I think those engines were better engineered. Ed
CX5 Touring 2.5L :-)
Re: Oil Consumption by Design [Re: Eddie] #4756522
05/14/18 05:28 AM
05/14/18 05:28 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Better broken in I think.
Modern designs are all standard out of the box fit, not select fit like a '57 Chev was, or a 1970s Rolls Royce.
As a result, every engine is on average...well average in the fleet.
You can get an engine with tolerance stack up that makes it a burner, or marginally too tight (friction wise).
Only variable that you have in an "average" engine is to break it in properly.
Re: Oil Consumption by Design [Re: NICAT] #4756535
05/14/18 05:39 AM
05/14/18 05:39 AM
Ne
ShieldArc Offline
ShieldArc  Offline
Ne
I'm still wondering why the 8.1 in my 2001 3500HD has used 1qt every 750 mi since new no matter what oil I put in it.
Re: Oil Consumption by Design [Re: ShieldArc] #4756569
05/14/18 06:11 AM
05/14/18 06:11 AM
NH
supton Offline
supton  Offline
NH
Why bother adding? Is it at the add level, or will be soon at the add level? not saying it's a waste of oil, just not sure it's worth the effort. [I used to have a Saturn, got to the point where I'd add a qt around 2k, then at 3k it was a qt low again--so I'd just have it changed. I tried to time it to save on oil. But perhaps not the best automotive example.]
Seems high, but, those were big cylinders. Lots of surface area for those rings to scrape. Not sure it's linear, but at 8.1L it's four times the size of the "standard" 2L I4. So, waving my hands a bit, 4x the oil consumption seems plausible. If so, be glad that a qt every 400 miles wasn't deemed acceptable by the OEM!
2011 Toyota Camry, base, 2.5L/6MT, 176k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 145k, ours
1999 Toyota Camry LE, 2.2L/4AT, 199k, his
Re: Oil Consumption by Design [Re: NICAT] #4756589
05/14/18 06:25 AM
05/14/18 06:25 AM
Europe
SonofJoe Offline
SonofJoe  Offline
Europe
IMO, the 'all engines consume oil' thing is a fraud practiced by certain OEMs. They figured out decades ago how to adequately seal the combustion chambers from the rest of the crankcase (and by 'adequately', I do not mean completely). The problem is that that level of sealing comes at the cost of fuel economy. As Shannow said above, one of the easiest & cheapest things an OEM can do to improve fuel economy is move to thinner, low tension rings. I don't know for sure but I suspect some have also been increasing the bore to piston side clearance. Of course all of this 'removal of resistance to flow' makes it easier for blow-by gas to get passed the pistons.
Now superimpose on this to a shift to higher compression ratios (for fuel economy or in the case of Turbochargers, performance), higher Noack oils (as a result to moving to thinner, fuel economy oils) and you get the potential for more engine oil to be routed around the PCV system and burnt. The effects of this progressively worsen as the engine ages. So it's a case of OEMs trading (on your behalf) short-term economy & performance credits with medium term engine problems (which might not surface until you're out of warranty). Unsurprisingly, they are somewhat coy about fessing up to this but it is definitely the game that's being played here.
Re: Oil Consumption by Design [Re: NICAT] #4756592
05/14/18 06:29 AM
05/14/18 06:29 AM
Ontario, Canada
OVERKILL Online content
OVERKILL  Online Content
Ontario, Canada
BMW went through this with the S62 and that was part of the reason for the spec for 10w-60, to help control consumption. The pre 03/00 engines could consume obscene amounts of oil and it was "par for the course" as per BMW. The post 03/00 engines had greatly reduced consumption due to updated rings, mine was reasonably good, only consuming ~1L/8000Km IIRC. One of the cars I looked at when I was shopping was a '99 that drank 1L/1000Km.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: Oil Consumption by Design [Re: NICAT] #4756655
05/14/18 07:28 AM
05/14/18 07:28 AM
Canuck living in California
KrisZ Online content
KrisZ  Online Content
If this continues I see people believing more and more that oil consumption where you need to add oil between OCIs is normal. After all the engineers know best.
2015 Dodge Grand Caravan-30k miles.
2007 Ford Focus ZX3-110k miles
2006 Mazda 3-168k miles
Re: Oil Consumption by Design [Re: NICAT] #4756748
05/14/18 08:58 AM
05/14/18 08:58 AM
The Garden State
Whimsey Offline
Whimsey  Offline
The Garden State
I guess I got lucky. Our 1996 Zetec 2L Contour even at 115,000 mi still doesn't use any really measurable amount of oil in even a 8,800 mi OCI. Our 195,000 mi 2005 4.6 V-8 Explorer again doesn't use any really measurable oil in a 9,000 mi OCI. Even our 2017 Explorer with the 2.3 EB doesn't use any really measurable amount of oil in even a 7,000 mi OCI. Low tension piston rings are suppose to help with gas mileage but increase oil usage I heard. And with our 2017 Explorer there doesn't appear to be enough measurable fuel diluting to the oil to keep the dip stick level up per my two UOA's.
Whimsey
Re: Oil Consumption by Design [Re: NICAT] #4756810
05/14/18 09:50 AM
05/14/18 09:50 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Only engine I've heard of that was designed to burn oil were the Mazda Wankel. They have an oil injection pump that takes oil out of the sump and injects it into the rotor chamber for lubrication of all the side and rotor tip seals. I had two RX-7s and they used about a quart every 3000 miles, by design.
Re: Oil Consumption by Design [Re: NICAT] #4756912
05/14/18 11:22 AM
05/14/18 11:22 AM
All engines have to consume oil, all of them, but the normal amount, on a healthy engine with properly broken in and not stuck piston rings, will not be noticeable on the dipstick or the change in the level should be minimal.
For engines over 100k miles, if the oil level stays between the min and max lines for the entire OCI, I would consider that normal as well.
And low tension piston rings are nothing new, it's just something people like to repeat to convince themselves and others that it is normal. You repeat it enough times and it becomes the truth.
