New Champ Filter
by CapitalTruck. 01/15/19 08:30 PM
19 Elantra vs corolla vs civic vs 18 Mazda 3
by wolf_06. 01/15/19 07:28 PM
New guage cluster need to be programed?
by callbay. 01/15/19 07:28 PM
good brand of inner tie rod?
by motor_oil_madman. 01/15/19 07:27 PM
Look at this blast from the past!
by SubieRubyRoo. 01/15/19 05:50 PM
Factory service manuals?
by buck91. 01/15/19 05:49 PM
Road Trip - Drive My Own Car or Rent?
by The Critic. 01/15/19 05:23 PM
‘19 GTI specs 0w-20 508 00
by LotI. 01/15/19 05:22 PM
Fram TG11955
by advocate. 01/15/19 03:03 PM
Bosch Steeltech = Wix?
by Black_Thunder. 01/15/19 02:44 PM
CVT and 6 speed automatic
by jerseyguy123. 01/15/19 01:56 PM
Hypothetical - X6M vs X5M vs AMG GLE63
by OVERKILL. 01/15/19 01:48 PM
2001 dodge neon coolant reservoir
by mobilaltima. 01/15/19 01:38 PM
Washing under car at self-service wash (salt)
by TmanP. 01/15/19 01:19 PM
Full Synthetic High Mileage in 40w range.
by FlyPenFly. 01/15/19 12:41 PM
2018 Silverado 3500HD TPMS Re-Learn
by Phishin. 01/15/19 12:36 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
142 registered members (92saturnsl2, 97prizm, AdRock, 28oz, AdditiveOCD, 15 invisible), 1,971 guests, and 35 spiders.
Topics296,608
Posts4,955,759
Members66,950
Most Online2,577
Jan 14th, 2019
2004 Jeep Loberty 3.7L PO302 Code #4755900
05/13/18 11:36 AM
05/13/18 11:36 AM
TN
tnt31 Offline OP
tnt31  Offline OP
TN
Check engine light just activated Saturday on a 2004 Jeep Liberty 3.7L we bought a couple of months ago. Jeep has 205K miles on it. It appears to be running ok but my wife does indicate a little while prior to the light coming on it did seem to stumble a little bit at idle.
When I first tried scanning it with my Actron CP9410 Pocket Scan Plus code reader I got a link error. Tried again, same result. I then started the engine and got a connection and it shows the PO302 code. (Misfire detected cylinder 2). I then tried to erase the code and the scanner indicates it does erase it but the check engine light stays one and the code reader re-scans and shows the PO302 code. I am guessing it may have something to do with whatever is causing the link error that it does not erase but that is a pure guess. I have tried the scanner on two other vehicles this morning and I do not get the link error.I have visually checked the ODB II port and it appears to look OK.
I guess most important does anyone have experience with these Dodge 3.7Ls and the PO302 codes? Also if any idea why the link error until I actually start the engine and if that is related to why it will not clear? I have the battery disconnected now to see if it will clear the CEL. Leaving it disconnected for 3 to 4 hours.
Re: 2004 Jeep Loberty 3.7L PO302 Code [Re: tnt31] #4755905
05/13/18 11:45 AM
05/13/18 11:45 AM
Michigan
khittner Offline
khittner  Offline
Michigan
No experience with a Chrysler 3.7, but did you pull the #2 plug to see what kind of shape it's in? At 12 years and 205K miles, its hopefully not running its OEM plugs, but who knows?
Re: 2004 Jeep Loberty 3.7L PO302 Code [Re: khittner] #4755919
05/13/18 11:56 AM
05/13/18 11:56 AM
TN
tnt31 Offline OP
tnt31  Offline OP
TN
I have not yet. The person who owned this previously was the original owner and gave us a folder of all maintenance records on the vehicle. Seems like there are invoices for three of four spark plug changes. I will re-check that later.
I looked at where the plugs appear to to be and not sure I have the time to tackle it. Will probably have to take to a local mechanic I use and trust. Would like to hear others experiences if they have had this code with this engine.
Re: 2004 Jeep Loberty 3.7L PO302 Code [Re: tnt31] #4755921
05/13/18 11:58 AM
05/13/18 11:58 AM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
Ya plugs first. You do know that you don't need a scanner to pull codes on that jeep?
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 2004 Jeep Loberty 3.7L PO302 Code [Re: tnt31] #4755926
05/13/18 12:11 PM
05/13/18 12:11 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I don't get it. Whats the point of clearing a misfire code unless its been repaired? Its a hard fault and will come back as soon as the misfire occurs again.
Plugs, coil or injector usually. Start with the plug, check and replace the coil (COP) if defective.
A noid light will tell you you have current going to the injector and at least indicate the ECM driver is okay. You can Ohm the injectors but that wont tell you much other than if was a dead short or open but that's only part of the diagnosis.
Re: 2004 Jeep Loberty 3.7L PO302 Code [Re: tnt31] #4755957
05/13/18 12:53 PM
05/13/18 12:53 PM
Georgia
AVB Offline
AVB  Offline
Georgia
Typically PCM codes can't be cleared on Chryslers with the engine running. I don't know why you are having issues connecting with the KOEO.
Re: 2004 Jeep Loberty 3.7L PO302 Code [Re: tnt31] #4756067
05/13/18 03:22 PM
05/13/18 03:22 PM
Saint John,IN
Highboy Offline
Highboy  Offline
Saint John,IN
I had a 2002 Liberty and they use copper plugs from the factory. They’re to to changed at 30k miles. Mine where shot at 30k. I would change out the plugs, very easy to do.
2006 Scion tC PP/Denso
2008 Scion tC MaxLife/Fu
2008 Toyota Highlander Pennzoil Ultra/ Oem filter
2012 Hyundai Sonata Castrol Magnatec 5w30 /Oem filter
Re: 2004 Jeep Loberty 3.7L PO302 Code [Re: tnt31] #4756073
05/13/18 03:26 PM
05/13/18 03:26 PM
USA
mk378 Offline
mk378  Offline
USA
If one or more of the plugs is a real bear to R&R, a lot of times that one doesn't get changed even though the receipt says it did.
Re: 2004 Jeep Loberty 3.7L PO302 Code [Re: tnt31] #4756152
05/13/18 04:53 PM
05/13/18 04:53 PM
NY
Kage860 Offline
Kage860  Offline
NY
Yep, I have a Liberty and those copper plugs don't last long. They're actually very easy to change though. I replaced with denso long life iridium 40k ago and have not had any engine issues or codes since. You might want to swap coils with another cylinder to see if the code moves. Maybe run some injector cleaner through the fuel. Hopefully not something expensive to fix.
2007 Jeep Liberty PP 0w-20 / Carquest Blue, 6k oci
2015 Nissan Rogue PP 0w-20 / Pronto, 5k oci
Re: 2004 Jeep Loberty 3.7L PO302 Code [Re: tnt31] #4756265
05/13/18 07:12 PM
05/13/18 07:12 PM
TN
tnt31 Offline OP
tnt31  Offline OP
TN
Thanks for the replies so far. If the code comes back I will give changing the plugs a try. If that does not fix it then with either change the COP of move the COP to a different cylinder. Rock Auto indicates the OE plug is a NGK V-Power. May try the iridium as kage860 suggest.
Vehicle has an aftermarket Pioneer radio. I have read a few comments that aftermarket radios can at times cause a link error. Still not sure why if the engine is running though it can connect.
Chris142 - I did not know that. Will have to look into it. Thanks
Re: 2004 Jeep Loberty 3.7L PO302 Code [Re: tnt31] #4756314
05/13/18 07:56 PM
05/13/18 07:56 PM
NY
Kage860 Offline
Kage860  Offline
NY
The ngk copper plugs are probably the best if you change them often. The ones I got are just quality long life plugs if you only want to do it once. Most people say to stick with the original plugs.
Re: 2004 Jeep Loberty 3.7L PO302 Code [Re: tnt31] #4756637
05/14/18 07:12 AM
05/14/18 07:12 AM
Texas
wag123 Online content
wag123  Online Content
Texas
Heavy combustion chamber carbon deposits are a common problem on that engine and will cause a misfire. Many people claim that it is caused by the use of E10 gas, but I have doubts about that because E10 should actually burn cleaner.
That engine is also known to have problems with bad valves (and valve springs). Before you blow a bunch of money on it you should do a compression test to find out if you have a bad valve. If you find a bad valve, at 205k miles the Jeep is toast (don't throw good money at it). Reset the CEL and sell it, that is what the previous owner probably did to you.
