(NEW) Wix 51522 Cut Open
by rooflessVW. 01/15/19 10:23 PM
Is this guy for real? (HUMOR)
by StevieC. 01/15/19 10:18 PM
Elf 4T moto tech 10w50 is good?
by firstime911. 01/15/19 09:25 PM
New Champ Filter
by CapitalTruck. 01/15/19 08:30 PM
19 Elantra vs corolla vs civic vs 18 Mazda 3
by wolf_06. 01/15/19 07:28 PM
New guage cluster need to be programed?
by callbay. 01/15/19 07:28 PM
good brand of inner tie rod?
by motor_oil_madman. 01/15/19 07:27 PM
Look at this blast from the past!
by SubieRubyRoo. 01/15/19 05:50 PM
Factory service manuals?
by buck91. 01/15/19 05:49 PM
Road Trip - Drive My Own Car or Rent?
by The Critic. 01/15/19 05:23 PM
‘19 GTI specs 0w-20 508 00
by LotI. 01/15/19 05:22 PM
Fram TG11955
by advocate. 01/15/19 03:03 PM
Bosch Steeltech = Wix?
by Black_Thunder. 01/15/19 02:44 PM
CVT and 6 speed automatic
by jerseyguy123. 01/15/19 01:56 PM
Hypothetical - X6M vs X5M vs AMG GLE63
by OVERKILL. 01/15/19 01:48 PM
2001 dodge neon coolant reservoir
by mobilaltima. 01/15/19 01:38 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
105 registered members (1.8Tango, 71Chevyguy, 2003f7, 2015_PSD, 13 invisible), 1,605 guests, and 34 spiders.
Topics296,613
Posts4,955,838
Members66,950
Most Online2,577
Jan 14th, 2019
Just picked up a 1998 ford expedition #4755850
05/13/18 11:01 AM
05/13/18 11:01 AM
Washington
Dylan1303 Online content OP
Dylan1303  Online Content OP
Washington
Got it for $1300. Eddie bauer edition. 188k 5.4l 4wd 3rd row. The works lol. So the tires are shot and ones a differant size. I can fix that issue right away at my work. The shifter has a ton of play. Putting it in 2 is acutally drive. I read theres a plate i can tighten under the dash is the first thing to try. It had no oil on the stick when i got it so i did a oil change and about 4 qts of black came out. They said they changed it about 10-15k ago. Put in 5 qts of valv hm full syn 5w30 and 1.5 qts of m1 0w40. Thats just what i had laying around and a motocraft 820. Air filter was fine. Power steering took a few ounces to top off. Tranny was about 1/4 qt low. Tranny does weep i noticed. All the boxes underneth are full and dont seem to bad. It does have the famous 5.4 header leak. Replaced the pcv stuff. Had a bad coil at cyl 8, what a B to change. Was gonna do plugs and all coils next check. What do you guys think did i miss anything? And body is straight 6.5/10 clean and its dark green
12 cruze rs 1.4t 6spd pp 5w30 tuned on 22psi
13 equinox 2.4 awd pp 5w30
Re: Just picked up a 1998 ford expedition [Re: Dylan1303] #4755865
05/13/18 11:10 AM
05/13/18 11:10 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
All I can say is good luck to you and the Red Sox.
JK When I feel like writing a long story I will post later, I had a 99 with very few miles and it was like living with an evil entity.
Re: Just picked up a 1998 ford expedition [Re: Dylan1303] #4755871
05/13/18 11:13 AM
05/13/18 11:13 AM
Washington
Washington
We only need it for less than a year. Wife is watching 2 more kids and in the am and they go to school. Next tax time we plan for a newer acadia with 3rd row
Re: Just picked up a 1998 ford expedition [Re: Dylan1303] #4755967
05/13/18 01:12 PM
05/13/18 01:12 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Nice find. How’s the coolant?
If you want the job done right......do it yourself.
Re: Just picked up a 1998 ford expedition [Re: Dylan1303] #4755976
05/13/18 01:21 PM
05/13/18 01:21 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
Re: What do you guys think did i miss anything?
You might change the other fluids. Brake, PS, antifreeze.
If it were mine I would NOT change the trany fluid because sometimes a trany with old fluid that has not been changed for quite a while will slip if you change the fluid.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Just picked up a 1998 ford expedition [Re: Dylan1303] #4755986
05/13/18 01:27 PM
05/13/18 01:27 PM
USA
NHGUY Offline
NHGUY  Offline
USA
I believe Dorman has a upgraded shifter tube that fails often on F150s/Expeditions.
Re: Just picked up a 1998 ford expedition [Re: Dylan1303] #4755987
05/13/18 01:28 PM
05/13/18 01:28 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Just before the next oil change, I'd put 6 oz of SeaFoam in the crankcase and drive it around the block, then change. Do that a few times and it'll settle right down.
Good family hauler. The EB package is very nice smile
Re: Just picked up a 1998 ford expedition [Re: Dylan1303] #4755988
05/13/18 01:28 PM
05/13/18 01:28 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
It sounds like you've addressed everything you can.
I wouldn't be afraid to refresh the ATF. To me, if the trans is so bad that a fluid refresh will kill it, you won't want your wife driving it as is anyway.
I have some friends that own early 2000s versions of these. One is the dark green, the other kind of a goldish color. No major issues aside from normal high mileage things like caliper and wheel bearings. They still look surprisingly good for that many years in the rust belt. No real visible rust from the outside.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Just picked up a 1998 ford expedition [Re: Dylan1303] #4756024
05/13/18 02:21 PM
05/13/18 02:21 PM
Santa Barbara, CA
bdcardinal Online content
bdcardinal  Online Content
Santa Barbara, CA
The sloppy shifter can also be caused by the shifter shaft and bushings in the column being worn, its a common thing on any Ford with a column shifter.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Just picked up a 1998 ford expedition [Re: bdcardinal] #4756066
05/13/18 03:20 PM
05/13/18 03:20 PM
PA
123Saab Offline
123Saab  Offline
PA
+1
My 03 Ranger had the same issue.
Anything can happen
The tallest towers be overturned
Those in high places be daunted
Those overlooked regarded
- Seamus Heaney
Re: Just picked up a 1998 ford expedition [Re: Dylan1303] #4756095
05/13/18 03:51 PM
05/13/18 03:51 PM
Tn.
CourierDriver Offline
Tn.
For 1300 and it runs,,,good deal, sounds like it will make a year or 2, maybe more, run her till she breaks,,,imho
turn in your old jackets, shirts and other clothes to a Salvation Army or any homeless shelter this year...
Re: Just picked up a 1998 ford expedition [Re: Dylan1303] #4756116
05/13/18 04:14 PM
05/13/18 04:14 PM
Ontario, Canada
OVERKILL Online content
OVERKILL  Online Content
Ontario, Canada
We had an '02 and my parents still have a 2000. Prior to the 2000, they had a '98. They are great vehicles mechanically, however they do have some issues, many of which are shared with the same vintage F-150 upon which they are mostly based:
1. Front suspension bits. They are hard on tie-rod ends and upper/lower balljoints. The Moog replacements seem to hold up well.
2. Exhaust manifold studs breaking off and leaking. Sounds like you've already got this going on. There are updated stainless studs available. It is usually the right side that fails.
3. The PI-headed versions of the 4.6L/5.4L had a tendency to launch spark plugs, particularly after the threads were damaged by the plugs being changed. This is not an issue with yours IIRC.
4. Rear axle seals on the 9.75" rear-end once the miles get on it. Both the '02 and the '00 have had these replaced.
5. The rear trailing arms can, in areas of heavy road salt usage, rot out.
6. The trans cooler lines can rot out (this happened to the '02)
7. The sunroof drains will back up and rot out the rockers (happened to the '02) from the inside
8. The rear parking brake cables will seize. So will the integrated rotor/drum parking brake assembly
9. The ABS controller dying, causing the pump to run constantly and killing the battery
10. The main power lead for the starter, the end will rot off.
And of course minor stuff:
- Coils failing but not setting a fault code
- The DTRL resister pooping the bed
- The heated drivers seat will fail
As you noticed, with rear HVAC, some of the coils are a monumental PITA to change. The plugs are worse. they 6" down the tube and on an angle. Take your time.
If the power steering is groaning a few drain/fills with M1 ATF or AMSOIL ATF will greatly reduce it or eliminate it.
The 4R100 transmission is close to invincible in this application (was designed to be behind the 7.3L PSD), as is the 9.75" rear-end. The front is also a very robust 8.8". We never had any drivetrain problems with either of them. Both are still on the road, I sold the '02 a couple of years back and the guy was going to drive it for the winter. Found out how good it was and it has been his DD since. Likely has around 200K miles on it now, as it had over 180K when I sold it. The 2000 has similar mileage.
They are pigs on gas and there's no way of helping that. It's a 240HP (in your case) V8 moving a 6,000lb behemoth mated to a massive antiquated 4-speed, which is in turn mated to a large BW transfer case with a clutched engagement mechanism for the front wheels, with two driveshafts that are always turning. It will pull the proverbial pooper out of the world in 4-LO and we had no issues doing extensive towing with both of them.
All-in-all, it got us through numerous ice storms, deep snow, pulled guys out that got stuck and generally was just a fantastic vehicle that really liked fuel. I was not easy on it, and it never left us stranded.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: Just picked up a 1998 ford expedition [Re: Dylan1303] #4756126
05/13/18 04:25 PM
05/13/18 04:25 PM
Boston
My442 Offline
My442  Offline
Boston
Other areas to look at: rusty brake lines, rotted exhaust manifolds, rotten A/C lines
Re: Just picked up a 1998 ford expedition [Re: Dylan1303] #4756212
05/13/18 06:19 PM
05/13/18 06:19 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
It wouldn’t happen to have the right rear tire blow out, driven on the wheel so long that the wheel exploded right?
crackmeup Oh GHT...
2015 Hyundai Sonata 2.4L 89k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 232k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Just picked up a 1998 ford expedition [Re: Nick1994] #4756262
05/13/18 07:12 PM
05/13/18 07:12 PM
Ontario, Canada
Ontario, Canada
crackmeup Oh GHT...
Thanks for dragging that back up, I had all but forgot about it! smirk
