Elf 4T moto tech 10w50 is good?
by firstime911. 01/15/19 09:25 PM
New Champ Filter
by CapitalTruck. 01/15/19 08:30 PM
19 Elantra vs corolla vs civic vs 18 Mazda 3
by wolf_06. 01/15/19 07:28 PM
New guage cluster need to be programed?
by callbay. 01/15/19 07:28 PM
good brand of inner tie rod?
by motor_oil_madman. 01/15/19 07:27 PM
Look at this blast from the past!
by SubieRubyRoo. 01/15/19 05:50 PM
Factory service manuals?
by buck91. 01/15/19 05:49 PM
Road Trip - Drive My Own Car or Rent?
by The Critic. 01/15/19 05:23 PM
‘19 GTI specs 0w-20 508 00
by LotI. 01/15/19 05:22 PM
Fram TG11955
by advocate. 01/15/19 03:03 PM
Bosch Steeltech = Wix?
by Black_Thunder. 01/15/19 02:44 PM
CVT and 6 speed automatic
by jerseyguy123. 01/15/19 01:56 PM
Hypothetical - X6M vs X5M vs AMG GLE63
by OVERKILL. 01/15/19 01:48 PM
2001 dodge neon coolant reservoir
by mobilaltima. 01/15/19 01:38 PM
Washing under car at self-service wash (salt)
by TmanP. 01/15/19 01:19 PM
Full Synthetic High Mileage in 40w range.
by FlyPenFly. 01/15/19 12:41 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
97 registered members (2015_PSD, 97prizm, Aero540T, 2003f7, 1.8Tango, 13 invisible), 1,662 guests, and 35 spiders.
Topics296,611
Posts4,955,827
Members66,950
Most Online2,577
Jan 14th, 2019
Nissian Matic J ATF*3 #4755788
05/13/18 09:48 AM
05/13/18 09:48 AM
Texas
mrnkc130 Offline OP
mrnkc130  Offline OP
Texas
Friend of mine has a 2008 2wd v6 Nissian pathfinder with 180K on it thats needing a trans fluid change in the near future. After some research it appears this fluid is the only OE recommended fluid, but is super expensive. Looking for suggestions for an alternative. Any old full synthetic trans fluid work?
Its not under warranty or anything but I'd like to make sure I'm not doing her a disservice by putting something other than optimal in her car.
Thanks in advance!
2017 Suburban LT
2016 Hyundai Accent
1946 Chevrolet 2-ton
2017 Kawasaki Ultra LX Ski
Re: Nissian Matic J ATF*3 [Re: mrnkc130] #4755794
05/13/18 09:56 AM
05/13/18 09:56 AM
Michigan
khittner Offline
khittner  Offline
Michigan
Valvoline MaxLife ATF is recommended for Nissan Matic-J applications. MaxLife ATF Applications List Few, if any, better---and at least as good as any OEM ATF--and $17/gallon at Walmart and other fine retailers.
Re: Nissian Matic J ATF*3 [Re: mrnkc130] #4755800
05/13/18 10:04 AM
05/13/18 10:04 AM
Texas
mrnkc130 Offline OP
mrnkc130  Offline OP
Texas
Thanks! I noticed most of the major brands say "suitable for use"
Anything make this Nissan fluid so special? Any Nissan owners not use it? I'm not well versed in Auto transmissions, never had one up until a few years ago.
2017 Suburban LT
2016 Hyundai Accent
Re: Nissian Matic J ATF*3 [Re: mrnkc130] #4755802
05/13/18 10:05 AM
05/13/18 10:05 AM
Southern Jersey
sjstangman Offline
sjstangman  Offline
Southern Jersey
Idemistu makes a matic j. Used it in the transfer case of my g37x.
You can find it on eBay cheap
https://www.idemitsulubricants.com/idemitsu/atf/type-j
Re: Nissian Matic J ATF*3 [Re: mrnkc130] #4755807
05/13/18 10:09 AM
05/13/18 10:09 AM
Massachusetts
VeryNoisyPoet Offline
Massachusetts
I'd second the recommendation for Maxlife ATF. Valvoline does not put those recommendations on there without thorough testing because of how much $$ rides on getting it right.
Two vehicles is just a shred of anecdotal evidence, but Maxlife cured an occasional harsh shift in my car (over the course of 5k miles), and completely solved a shift flare on my mom's '04 XC70 (as soon as it was changed).
1998 V70 GLT / 195k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Nissian Matic J ATF*3 [Re: mrnkc130] #4755810
05/13/18 10:13 AM
05/13/18 10:13 AM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
The word "Nissan" on the label and not much else IMO.
A friend had a 93 nissan sentra which called for "Matic D"; it was $$$ at the dealer where he was helping out; the service guy told him to 'just use dexron'
2004 Prius; 102K; ASL
2007 Yaris 78K 0w-40 Castrol
2006 B2300;132K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Nissian Matic J ATF*3 [Re: mrnkc130] #4755827
05/13/18 10:33 AM
05/13/18 10:33 AM
Ohio
hallstevenson Offline
Ohio
I've said this a few times before, but I don't believe it's very likely that Nissan develops or has developed a "special" ATF just to their specs. They do have specs that they want to meet for their transmissions and submit these to the fluid manufacturers. Companies like Castrol, Valvoline, Idemitsu, etc can come back to Nissan and say "sorry, we can't meet that without creating a special blend" or more likely, they come back and say "our fluid 'A' meets or exceeds all of your specs".
The fluid manufacturers have multiple blends so they aren't pretending to have a one-size-fits-all fluid either. They also aren't going to risk claiming compatibility and then cause issues with transmissions.
Lastly, a few years after 2008 (I have an '08 Infiniti), Nissan/Infiniti apparently changed the wording in their manuals to read something more like "use a fluid that meets the Matic ? spec" and no longer say you have to use only Matic ?.
Re: Nissian Matic J ATF*3 [Re: mrnkc130] #4755830
05/13/18 10:37 AM
05/13/18 10:37 AM
texas
kpatter Offline
kpatter  Offline
texas
What about walmarts supertech atf? I know it is not synthetic but it is cheap..
Re: Nissian Matic J ATF*3 [Re: mrnkc130] #4755837
05/13/18 10:52 AM
05/13/18 10:52 AM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
Maxlife + Lubegard Red
BITOG cocktail.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Nissian Matic J ATF*3 [Re: VeryNoisyPoet] #4756064
05/13/18 03:18 PM
05/13/18 03:18 PM
CA
The Critic Offline
The Critic  Offline
CA
None of these manufacturers actually develop their own universal ATF from the ground up. The blender (valvoline) purchases an additive package from a supplier (Lubrizol, Afton, Infineum, etc) who has already performed testing to confirm "compatibility" with certain applications. The blender then purchases a compatible base oil mix and together, is the end product that is sold to the consumer. Valvoline may do some of their own testing, but most of the R&D work was done by the additive supplier. It is very unlikely that the amount of testing done in the aftermarket, is equivalent to the testing done at the OE level.
2011 Toyota Prius - 181k - M1 EP/EP HM Mix 0W-20
2007 Honda Accord 2.4 - 134K - Mobil 1 EP HM 5W-30
Re: Nissian Matic J ATF*3 [Re: mrnkc130] #4756153
05/13/18 04:53 PM
05/13/18 04:53 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
I believe that the Castrol Import Vehicle ATF also claims suitability.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Nissian Matic J ATF*3 [Re: mrnkc130] #4756157
05/13/18 04:57 PM
05/13/18 04:57 PM
Los Gatos, CA
JeffKeryk Online content
JeffKeryk  Online Content
Los Gatos, CA
I have used MaxLife in several Nissans, Hondas, Acuras and my old Tundra. You will be happy.
Do a couple of spill and fills.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Nissian Matic J ATF*3 [Re: mrnkc130] #4756171
05/13/18 05:28 PM
05/13/18 05:28 PM
Pennsylvania
Boomer Offline
Boomer  Offline
Pennsylvania
I think Matic J has been superseded by Matic S.
2013 VW Passat TDI SE, 61,200 miles Castrol Professional VW507 5W-30
2017 VW Golf All Track 18,370 miles Castrol Professional VW505 5W-40
Re: Nissian Matic J ATF*3 [Re: mrnkc130] #4756172
05/13/18 05:28 PM
05/13/18 05:28 PM
Pennsylvania
Boomer Offline
Boomer  Offline
Pennsylvania
Re: Nissian Matic J ATF*3 [Re: Garak] #4756299
05/13/18 07:46 PM
05/13/18 07:46 PM
Ohio
Ohio
It does (I use it).
Castrol has another ATF that meets Matic-S as well. It's this one - TRANSMAX™ FULL SYNTHETIC MULTI-VEHICLE. They don't even list the different specs for most automakers, they just say this, "All applications that require automatic transmission fluid". If you use their "Oil Selector" though, I don't see it listing this fluid for newer Infinitis.
