Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
92 registered members (69Torino, 69GTX, ammolab, A310, 4WD, 1.8Tango, 10 invisible), 1,804 guests, and 44 spiders.
Topics296,895
Posts4,961,144
Members66,997
Most Online2,688
Jan 19th, 2019
Is There Such a Thing as Freon w/ Sealant in It? #4755580
05/13/18 05:12 AM
05/13/18 05:12 AM
Midwest USA
LoneRanger Offline OP
Midwest USA
Is there a sealant that can be shot into the suction line and can it seal micro leaks in the evaporator coil? Sort of like Fix-a-Flat but for air conditioners. I was told that it can buy a couple more years service out of an aging evaporator coil. I've only lost about 5 degrees of temperature drop across the coil from last year when the hvac tech fully charged the unit. It uses the old refrigerant, R100 I think.
'09 Subaru Forester ...................(QS HM 5W30)
'16 Moto Guzzi Stelvio 1200 .....(ENI i-Ride PG 10W60)
Re: Is There Such a Thing as Freon w/ Sealant in It? [Re: LoneRanger] #4755595
05/13/18 05:54 AM
05/13/18 05:54 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Not sure what R100 is. But every auto parts store sells a stopleak product. Its great for plugging up condensers,orifice tubes and my AC machine. renders the entire system junk in short order.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Is There Such a Thing as Freon w/ Sealant in It? [Re: LoneRanger] #4755598
05/13/18 05:58 AM
05/13/18 05:58 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
If you are talking about R-134a then, yes! But, IDK if it's a AC fix everything except some seals.
If you are speaking about R-12, well, IDK!
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Is There Such a Thing as Freon w/ Sealant in It? [Re: Chris142] #4755654
05/13/18 07:18 AM
05/13/18 07:18 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: Chris142
every auto parts store sells a "stop leak" product.
Its great for plugging up condensers, orifice tubes and my A/C machine.
Renders the entire system junk in short order.
Quoted for truth.
Re: Is There Such a Thing as Freon w/ Sealant in It? [Re: LoneRanger] #4755686
05/13/18 07:59 AM
05/13/18 07:59 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
So , your A/C needs re-charging every year ? If so , what I would do , If I was you .
Buy a can of refrigerant that has the yellow - green florescent die . And the kit with the UV flashlight & yellow plastic glasses . Shoot the dye into the system . About a week latter , check Evey part of the A/C system you can get to , with the UV flashlight & yellow glasses . The leaks show up better , to me , after dark . You may be surprised what you may find .
I change out the Schrader valves as preventive maintenance , if I start to have problems . If they are serviceable .
But , back to your question . Yes , they make refrigerant with stop leak . No , I no longer use it .
If it only leaks enough to require servicing once a year . That is what I would do and not mess with it further .
I do all my own A/C work myself . And , yes , I have an EPA card in my back pocket .
Wyr
God bless
Re: Is There Such a Thing as Freon w/ Sealant in It? [Re: LoneRanger] #4755727
05/13/18 08:48 AM
05/13/18 08:48 AM
IL
Vern_in_IL Offline
Vern_in_IL  Offline
IL
As of the year 2020, or 2021 model year, light duty vehicle manufacturers will no longer be able to use R-134a in their new automobiles. The mandate does not say what they have to use instead but there are very little choices to choose from. Most manufacturers will end up going with the HFO refrigerant known as 1234YF. This new refrigerant runs very high in price at about $700 per ten pound cylinder compared to the $120 for a thirty pound cylinder of 134a. My recommendation is just keep recharging and pocket the savings.
Re: Is There Such a Thing as Freon w/ Sealant in It? [Re: Linctex] #4755762
05/13/18 09:29 AM
05/13/18 09:29 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Quoted for truth.
+1.
The CAA says that you have to fix a leak before refilling.
The CAA in that regard, amongst others, is in YOUR best interest.
A band aid fix will ruin other stuff in short order.
Re: Is There Such a Thing as Freon w/ Sealant in It? [Re: LoneRanger] #4755763
05/13/18 09:30 AM
05/13/18 09:30 AM
Midwest USA
Midwest USA
Early morning brain cramp. R22, the old stuff, is what it uses. I'll have to pull the service cover again to be sure.
Tech that serviced it last year said pretty much time to consider a new unit. I get it, it's just that it chaps me the way things are built to fail within a certain time frame anymore. This unit was manufactured in late 2004, installed in Fall 2005 when house was built, and put into regular service in February 2006 when we bought the place as first owners.
I remember in the 1980's I'd help my dad in his hvac business (sole propreitorship). He serviced 20 yr old Carrier residential units that still ran like Swiss watches. Never find that today. 15 yrs max. Sad.
I may be starting another post soon, "What's the best brand of residential hvac these days."
I used to like Trane not too long ago, but don't know if their quality has remained as good as it was... hopefully so.
Re: Is There Such a Thing as Freon w/ Sealant in It? [Re: LoneRanger] #4755782
05/13/18 09:42 AM
05/13/18 09:42 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
You mean R-12?
"Retired"
'15 Honda Civic LX
Re: Is There Such a Thing as Freon w/ Sealant in It? [Re: LoneRanger] #4755790
05/13/18 09:49 AM
05/13/18 09:49 AM
Midwest USA
Midwest USA
Maybe I shoot some of this [censored] in myself?
http://www.redtek.com/win_proseal_prod.html
Re: Is There Such a Thing as Freon w/ Sealant in It? [Re: LoneRanger] #4755803
05/13/18 10:06 AM
05/13/18 10:06 AM
Michigan
khittner Offline
khittner  Offline
Michigan
4 out 5 gastroenterologists agree . . .
Re: Is There Such a Thing as Freon w/ Sealant in It? [Re: LoneRanger] #4755809
05/13/18 10:12 AM
05/13/18 10:12 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Evaporator coils can some times be repaired , if not , they can be replaced . I would try to keep the system in operation .
CAA ? Who / What is / are they ? I thought EPA had jurisdiction over refrigerants ?
Wyr
God bless
Re: Is There Such a Thing as Freon w/ Sealant in It? [Re: LoneRanger] #4755816
05/13/18 10:19 AM
05/13/18 10:19 AM
TX
KJSmith Offline
KJSmith  Offline
TX
https://www.bakerdist.com/nu-calgon-4050...-nu405008-78739
I have had some success with this product.
Re: Is There Such a Thing as Freon w/ Sealant in It? [Re: LoneRanger] #4759805
05/17/18 11:01 AM
05/17/18 11:01 AM
Florida
artificialist Offline
Florida
Red Angel sealant might keep you going for a little while.
Many tools exist to detect sealants used in an air conditioning system. It tends to harm A/C service equipment.
2010 Lancer Ralliart Sportback
Re: Is There Such a Thing as Freon w/ Sealant in It? [Re: LoneRanger] #4760003
05/17/18 01:53 PM
05/17/18 01:53 PM
California
nthach Offline
nthach  Offline
California
They do make HVACR sealants, I've seen it being injected into our packaged unit at work in the server room but many techs also don't like it use it unless it's a last resort.
https://www.diversitech.com/en-US/category/cat_id/400
