Fully Formulated Coolant and old radiator
by Wheel. 01/18/19 11:27 AM
'15 6.7 Powerstroke UOA
by roadrunner1. 01/18/19 10:18 AM
Automotive Battery Voltage -What is ur reading?
by Patrick0525. 01/18/19 10:10 AM
Amsoil 0w-40 vs 5w-40
by Buddyp. 01/18/19 10:07 AM
M1 is changing their oils, site and adding a new oil
by Flashlightboy. 01/18/19 10:01 AM
Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
101 registered members (aircooled, Astro14, 2K2AcuraTL, Al, aquariuscsm, Astro_Guy, 15 invisible), 2,185 guests, and 53 spiders.
Topics296,780
Posts4,958,766
Members66,969
Most Online2,577
Jan 14th, 2019
Testing Clutch Drag #4755538
05/13/18 02:44 AM
05/13/18 02:44 AM
Azerbaijan
NICAT Offline OP
NICAT  Offline OP
Azerbaijan
Hi.
I sometimes have difficulty in shifting to a gear while the car is moving. Even shifting to neutral is sometime hard. But not as hard as shifting to a gear. (Not to the first gear only, but to all gears)
Some told that it can be a clutch drag. it is the cause is clutch drag, how can i test it ?
I lifted front of the car so that the front wheel can spin freely.
Then in first gear, i depressed the clutch pedal, front wheel stopped spinning.
Does this mean that there is no drag ?
I have retrofitted an adjustable slave cylinder pin and have lengthened the pin to a level, so if i do it a little bit more, the clutch will slip. Does this guarantee that there can't be any drag ?
The gearbox is, Opel's F16 5 Speed Synchronized.
Regards
Re: Testing Clutch Drag [Re: NICAT] #4755542
05/13/18 03:23 AM
05/13/18 03:23 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
I don't know anything about clutches so, I bring this up as a basic and fundamental test.
How is the clutch fluid?
Again, because I don't know however what I do know is that most clutches use regular brake fluid.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Testing Clutch Drag [Re: NICAT] #4755586
05/13/18 05:22 AM
05/13/18 05:22 AM
Frogland / Brittany / Canada
Popsy Offline
Popsy  Offline
As you were told in the other thread, first be sure that the right oil is in the gearbox, then replace "clutch fluid" (generally brake fluid too) and be sure it's correctly bleeded.
These two things done, then by adjustable slave cylinder pin you mean you can adjust the travel of the pins that actuates the clutch? If yes, adjust it for the longest travel possible for the clutch not to slip (you can test that old school by putting handbrake in a slope and trying to do a fast start in 3rd gear, the engine should stall right away).
But really, first right fluid in the gearbox, cause believe me, that makes a BIG difference, even the right specification fluid between brands can make a difference.
If you listen carefully (engine off) you should be able to hear the clutch being actuated while slowly depressing the clutch pedal). Perhaps you can even adjust the pedal height and travel, it depends on cars (I don't know this specific model), but if it's possible you should have the recommended settings in the manual. Most of the time it's for car with cable actuated clutch though.
96 Barchetta, 300V 5W40 | Forfour 95, SHU 0W40
Mazda 6 2.3, M1 0W40 | Colt Ralliart, 300V 0W40
Re: Testing Clutch Drag [Re: Popsy] #4755600
05/13/18 06:01 AM
05/13/18 06:01 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Yes, check for the correct gearbox fluid along with the clutch fluid.
"Retired"
'15 Honda Civic LX
Re: Testing Clutch Drag [Re: NICAT] #4755618
05/13/18 06:42 AM
05/13/18 06:42 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
If the wheel stopped spinning, then if there is any drag, it should not affect drivability.
Re: Testing Clutch Drag [Re: NICAT] #4756440
05/13/18 11:50 PM
05/13/18 11:50 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
The usual test is 2500rpm in neutral, push your foot on the clutch, wait 5 seconds and engage gear...if it won't go in then the clutch is dragging. I like to use reverse...it makes a better noise.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - Gulf Western 10W-40
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Testing Clutch Drag [Re: NICAT] #4756445
05/14/18 12:00 AM
05/14/18 12:00 AM
Azerbaijan
NICAT Offline OP
NICAT  Offline OP
Azerbaijan
Thanks for replies. smile
