Fiat 9.55535-GS1 Certification - Ravenol
by RamFan. 01/17/19 08:35 AM
EV Future
by Danno. 01/17/19 08:11 AM
Sayings that people told you...
by Char Baby. 01/17/19 08:04 AM
Certified oils
by waltywalt. 01/17/19 07:55 AM
Favorite Movie Lines And Scenes
by billt460. 01/17/19 07:14 AM
Suzuki Jimny
by ridgerunner. 01/17/19 06:52 AM
Amsoil SSO 5w50
by Vspec. 01/17/19 06:36 AM
Dodge truck question - gear shift
by gfh77665. 01/17/19 06:22 AM
GAC may be coming to America?
by Char Baby. 01/17/19 06:03 AM
Another favorite video
by Char Baby. 01/17/19 04:59 AM
Detail a 2012 Kia Soul
by jerseyguy123. 01/17/19 02:23 AM
Can top end cleaners damage engine?
by avacado11. 01/17/19 01:40 AM
Where are Fram Oil and Air filters made ?
by rubberchicken. 01/17/19 12:42 AM
Based on these specs, which oil is better?
by SlavaB. 01/17/19 12:42 AM
Fram FPS9688 from ebay (Ultra XG9688)
by SlavaB. 01/16/19 11:12 PM
Pick my filter—
by lukejo. 01/16/19 10:41 PM
2007 Camry V6 feedback......
by kenwin30. 01/16/19 10:41 PM
Pioneer SW-8MK2 Subwoofer
by webfors. 01/16/19 10:39 PM
Hallelujah Toyota -- The Spin-Ons are Back!
by ekpolk. 01/16/19 10:37 PM
Ford F-150 EV Confirmed
by E365. 01/16/19 10:19 PM
neiltt, Drspel, wwalrus, fedorqwe, Terand_1
66957 Registered Users
100 registered members (aquariuscsm, andyd, bbslider001, 2K2AcuraTL, atikovi, badtlc, 9 invisible), 1,738 guests, and 51 spiders.
Topics296,709
Posts4,957,354
Members66,956
Most Online2,577
Jan 14th, 2019
Heatpump thermostat replacement #4755320
05/12/18 06:53 PM
05/12/18 06:53 PM
Ohio
fonecord2 Offline OP
Ohio
I bought this thinking that it would be a direct replacement. The letters are different. Does anyone know if there is a good cross reference for the connections?
2006 CTS
2003 Harley Davidson Road King
Re: Heatpump thermostat replacement [Re: fonecord2] #4755355
05/12/18 07:37 PM
05/12/18 07:37 PM
Maryland
chemman Offline
chemman  Offline
Maryland
Get the part number off the Lennox thermostat (you'll need to move the wire going to the R terminal in order to get all the numbers), then google it for the installation/wiring manual/diagram. Do the same for the Rudd thermostat (if you don not already have it) and then compare the descriptions of the terminals between the two thermostats. They are likely quite similar.
Do you have the installation manual for the heat pump? That might help also.
92 Olds 88 Hav 5w30 PL/L24011
99 Buick Century Hav 5w30 PL/L24011
99 Silverado 5.3L Hav 5w30 PL/L25288
04 TrailBlazer 4.2L Hav 5w30 PL/L25288
Re: Heatpump thermostat replacement [Re: fonecord2] #4755403
05/12/18 08:22 PM
05/12/18 08:22 PM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
Looks like Lennox wanted to confuse consumers who wanted to replace their own t-stat. Didn't realize you could still buy mercury bulb t-stats either! Why the new t-stat?
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Heatpump thermostat replacement [Re: fonecord2] #4755450
05/12/18 09:22 PM
05/12/18 09:22 PM
USA
mk378 Offline
mk378  Offline
USA
Yeah we're did you get that "new" mercury thermostat? They've been banned for years.
Re: Heatpump thermostat replacement [Re: fonecord2] #4755455
05/12/18 09:41 PM
05/12/18 09:41 PM
Ohio
Ohio
I bought it on Amazon. I damaged the old one when I was moving furniture. I'm thinking about going digital since it's not a easy swap.I appreciate all of the help.
2006 CTS
Re: Heatpump thermostat replacement [Re: fonecord2] #4755690
05/13/18 08:03 AM
05/13/18 08:03 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Go to the furnace & find where the tstat wires connect to the furnace . Take a photo and post that , as well as a color for color chart . And any description that you may fine , of what wire is what .
Post the photo .
Wyr
God bless
Re: Heatpump thermostat replacement [Re: fonecord2] #4755702
05/13/18 08:25 AM
05/13/18 08:25 AM
USA
mk378 Offline
mk378  Offline
USA
The replacement unit is actually a lot closer to the standard designations, which are:
R = common live wire-- switch to G, Y, W etc. to make things happen.
X = neutral return wire (used for the lights on the thermostat)
G = starts the inside fan
Y = starts the outdoor unit compressor
O = sets the reversing valve for cooling
B = sets the reversing valve for heating
W / W2 = turns on electric heaters / emergency heaters
Go to the other end of the thermostat cable, which is inside the interior unit, and see what wire colors are connected to which terminal names.
Re: Heatpump thermostat replacement [Re: fonecord2] #4755734
05/13/18 08:54 AM
05/13/18 08:54 AM
texas
danez_yoda Offline
danez_yoda  Offline
texas
whats wrong with the original Tstat? I thought mercury switches lasted forever? looking at the old vs new the mercury bulbs looks to be angled differently on the old one vs nearly parallel on the new one. Could that be the problem?
These things work of gravity and angle is important.
Maybe a tweek with needle nose pliers is all you need.
Re: Heatpump thermostat replacement [Re: mk378] #4756244
05/13/18 06:47 PM
05/13/18 06:47 PM
Nokesville, VA
brianl703 Offline
brianl703  Offline
Nokesville, VA
Normally, only one of O or B is connected, depending on whether the reversing valve is energized for heating or for cooling.
O is used if the reversing valve defaults to heating and must be energized for cooling. This is most common.
B is used if the reversing valve defaults to cooling and must be energized for heating.
https://yourhome.honeywell.com/en/questions/wireless-5-1-1-day-programmable-thermostat-9
Re: Heatpump thermostat replacement [Re: fonecord2] #4756247
05/13/18 06:52 PM
05/13/18 06:52 PM
Nokesville, VA
brianl703 Offline
brianl703  Offline
Nokesville, VA
This might be helpful:
Re: Heatpump thermostat replacement [Re: fonecord2] #4756266
05/13/18 07:13 PM
05/13/18 07:13 PM
Nokesville, VA
brianl703 Offline
brianl703  Offline
Nokesville, VA
Re: Heatpump thermostat replacement [Re: fonecord2] #4756277
05/13/18 07:22 PM
05/13/18 07:22 PM
Nokesville, VA
brianl703 Offline
brianl703  Offline
Nokesville, VA
On page 8 is a description of what the ambient sensor does. Other brands of heat pumps do not have a sensor connected this way to the thermostat, so you could probably do without it.
http://www.completeheating.ca/images/pdf/LennoxHP26.pdf
Re: Heatpump thermostat replacement [Re: fonecord2] #4757192
05/14/18 05:05 PM
05/14/18 05:05 PM
Ohio
Ohio
There are two wires going to the Y terminal and none to the E. Any ideas? Did someone turn off the emergency heat to avoid a high electric bill? Should those remain together on the new t-stat?
2006 CTS
Re: Heatpump thermostat replacement [Re: fonecord2] #4757228
05/14/18 05:36 PM
05/14/18 05:36 PM
Nokesville, VA
brianl703 Offline
brianl703  Offline
Nokesville, VA
The extra wire on the Y terminal looks like it's part of the thermostat, since it doesn't go into that hole in the middle where the rest go.
Someone may have disconnected the emergency heat OR there is only one stage of heating in your equipment (as opposed to 1st stage aux heat and 2nd stage emergency heat).
I would run the aux heat wire through a standard toggle switch placed near the furnace (or another location if that's not convenient) so that you have more control over when it comes on. Some thermostats are way too quick to turn on the aux heat--this lets you keep it off until YOU want it on.
Re: Heatpump thermostat replacement [Re: fonecord2] #4757244
05/14/18 05:44 PM
05/14/18 05:44 PM
Nokesville, VA
brianl703 Offline
brianl703  Offline
Nokesville, VA
E might also be the wire that just turns the "EMERG HEAT" light on.
