Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
92 registered members (advocate, 69Torino, 69GTX, A310, 4WD, 1.8Tango, 10 invisible), 1,809 guests, and 43 spiders.
Topics296,895
Posts4,961,144
Members66,997
Most Online2,688
Jan 19th, 2019
Help w/P1259 Honda, VTEC #4755116
05/12/18 01:27 PM
05/12/18 01:27 PM
Seattle-ish, WA
Oro_O Offline OP
Oro_O  Offline OP
Seattle-ish, WA
Helping a neighbor fix a small problem.
1998 Accord 5spd. Has Code P1259, VTEC malfunction. Car stumbles ~4k rpm (VTEC not working it appears).
She said it appeared immediately after the clutch was replaced. I am guessing some VTEC wiring was not re-installed or damaged. I get the concept, but Iíve never worked on a Honda auto. What and where should I look? I googled the code and found this suggestion, but Iím not familiar with the engine and system. On the back of the head or somewhere else?
Re: Help w/P1259 Honda, VTEC [Re: Oro_O] #4755120
05/12/18 01:31 PM
05/12/18 01:31 PM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
Is there a compelling reason she wouldn't just take it back to where the clutch was replaced and have them troubleshoot their mistake?
beanoil: Tough under heat, real dirty afterwards.
Re: Help w/P1259 Honda, VTEC [Re: Oro_O] #4755134
05/12/18 01:57 PM
05/12/18 01:57 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I came up with a few results that may help:
Link
Re: Help w/P1259 Honda, VTEC [Re: Oro_O] #4755155
05/12/18 02:27 PM
05/12/18 02:27 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Check the wiring to the vtec spool if the wiring checks check the scree if clear replace the spool valve. Typical VTEC stuff.
As it happened right after having work done I bet they left the wire off.
Re: Help w/P1259 Honda, VTEC [Re: Trav] #4755165
05/12/18 02:46 PM
05/12/18 02:46 PM
Seattle-ish, WA
Oro_O Offline OP
Oro_O  Offline OP
Seattle-ish, WA
i
Ok, looks like i need to check/find the screen.
The work was done a while ago by someone on the cheap, so sheís not going to hassle them.
I found the solenoid, the wire was connected. I pulled it and checked there was voltage. The wire supplied 10.9v (enough?). I removed the solenoid, grounded it to the engine and applied a wire from teh battery and got solid clicks. The battery showed 12.51v after being driven yesterday, so no the healthiest but functioning. The spool valve is the assembly beneath the soleoid that on which it mounts?
Thanks.
Re: Help w/P1259 Honda, VTEC [Re: Oro_O] #4755182
05/12/18 03:21 PM
05/12/18 03:21 PM
Trav Offline
Trav  Offline
Yes the spool valve is under the solenoid, the solenoid controls it. Check the screen first it is in the spool valve gasket.
If its clean check the valve for varnish and sticking, clean with carb cleaner sometimes that will cure it, if it happens again change the whole valve assy.
What engine is this?
Re: Help w/P1259 Honda, VTEC [Re: Oro_O] #4755189
05/12/18 03:28 PM
05/12/18 03:28 PM
USA
mk378 Offline
mk378  Offline
USA
There is also a pressure switch on the valve, with a 2-wire plug. The switch is measuring pressure on the output of the valve. Right after it commands the valve open, the ECU checks if the switch tripped. If it did not, the ECU throws a code and disables VTEC until the next startup.
So the switch has to be plugged in, the screen clear (to allow pressure to come through), and the overall oil pressure sufficient for proper VTEC operation. The switch is there because if the VTEC actuators only move halfway due to low pressure, the valvetrain will be damaged.
Re: Help w/P1259 Honda, VTEC [Re: Oro_O] #4755215
05/12/18 04:34 PM
05/12/18 04:34 PM
Seattle-ish, WA
Oro_O Offline OP
Oro_O  Offline OP
Seattle-ish, WA
This is the 2.3l four, sorry I forgot to mention that.
I appreciate the advice from you guys very much. Iíll take the spool valve off and clean the screen and try to flush the valve body with some carb cleaner and try it after that, and also check the voltage at that other plug. I did see that on the side of the spool valve.
Re: Help w/P1259 Honda, VTEC [Re: Oro_O] #4755251
05/12/18 05:47 PM
05/12/18 05:47 PM
Trav Offline
Trav  Offline
Here you go, for $57 its not really worth messing around, a couple of bolts and you are done (providing the wiring is okay).
Spool Valve
Re: Help w/P1259 Honda, VTEC [Re: Oro_O] #4755490
05/12/18 11:00 PM
05/12/18 11:00 PM
Seattle-ish, WA
Oro_O Offline OP
Oro_O  Offline OP
Seattle-ish, WA
I had looked around for replacements and wondered what was safe to buy. Prices on ebay ran from $35 to $100, much of it unbranded. If that one is really OEM, then itís a great deal. The lowest price ones at RockAuto were $90 for a Gates (re-branded, Iím sure).
I didnít check the power on that other harness; Iíll do that in a day or two and then likely order that part. The car is 20 years old and 150k miles, which seems about the life of these components anyway from what I read of how common failures are.
Re: Help w/P1259 Honda, VTEC [Re: Oro_O] #4755555
05/13/18 04:13 AM
05/13/18 04:13 AM
Trav Offline
Trav  Offline
Ebay has plenty of great deals and a lot of scams and rubbish, that one is being sold as OE so any shenanigans and you can return it with no trouble.
Do not use any unbranded or that garbage from Rock OE only. I would have no problem buying the one I posted.
Re: Help w/P1259 Honda, VTEC [Re: Oro_O] #4795526
06/23/18 04:30 PM
06/23/18 04:30 PM
Seattle-ish, WA
Oro_O Offline OP
Oro_O  Offline OP
Seattle-ish, WA
So I have to kick this up again as I am still stumped. Installed the new spool valve but have the same problem.
It took a while to synch schedules and get access to her car. I installed the spool valve and there was no chance in the condition and the same code re-appeared. I can think of three things:
1) the 10.9v noted on the solenoid is not enough?
2) the oil pressure is low (no warning or other signs of that)
3) new spool valve is bad? (I would think very unlikely)
