Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
114 registered members (advocate, 4WD, andyd, 69GTX, 69Torino, Ag76, 13 invisible), 1,826 guests, and 33 spiders.
Topics296,898
Posts4,961,178
Members66,997
Most Online2,688
Jan 19th, 2019
STP Air Filter Efficiency #4754900
05/12/18 08:38 AM
05/12/18 08:38 AM
Colorado
JerryBob Offline OP
JerryBob  Offline OP
Colorado
I watched my cousin changing the air filter in his Jeep using an STP filter.
The box said 90% efficiency. That struck me as very low. Shouldn’t it be in the high 90s?
Re: STP Air Filter Efficiency [Re: JerryBob] #4754906
05/12/18 08:46 AM
05/12/18 08:46 AM
Illinois
mrsilv04 Offline
mrsilv04  Offline
Illinois
90% efficient at what? Filtering out gravel sized chunks? Unfortunately, there's not a lot to go on here.
However, this is likely a case of where your cousin got what he paid for... or less than he paid for.
I can buy a $3 oil filter, and see the spec is 99% at 30 microns... right on the box. For what I'm trying to accomplish, that's plenty good enough.
Air filters may not be as straight-forward.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: STP Air Filter Efficiency [Re: JerryBob] #4754925
05/12/18 09:07 AM
05/12/18 09:07 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Not enough information available to make an informed decision.
Yes, really.
Re: STP Air Filter Efficiency [Re: JerryBob] #4754985
05/12/18 10:24 AM
05/12/18 10:24 AM
NW Ohio
Jim Allen Offline
Jim Allen  Offline
NW Ohio
The only way to know is to query the manufacturer. That is an odd spec to list given that other manufacturers list higher numbers. It wouldn't be a horrible filter if it was a test made on find dust. That would equate to somewhere around 95+% on coarse (which is the more common spec listed. Nowaways, most mfrs list 98 percent on the coarse dust test and some at 99% (one percent counts for a LOT in an air filter and 4-5 percent is HUUUUUGE). 90% isn't much better than an oil bath filter and they suck (literally and figuratively).
Jim Allen
Keepin' the Good Old Days of Four Wheeling Alive
Re: STP Air Filter Efficiency [Re: JerryBob] #4755169
05/12/18 02:57 PM
05/12/18 02:57 PM
Arkansas
mazdamonky Offline
mazdamonky  Offline
Arkansas
Sadly, this number sounds not good to me, though we don't know what the 90% efficiency rating is for. Sadly, this is the only filter I can get locally for my 85 rx7. Everything else has to be ordered online and Fram has pretty much stopped making that filter so you can't get it anywhere.
2018 mazda3 hatch 2.5 263 miles
1985 rx7 1.1 98k miles
2002 protege 220k miles
1985 rx7 with a 5.0 swap
2002 Protege 299k miles Girlfriend's
4 more running cars in yard not mentioned
Re: STP Air Filter Efficiency [Re: mazdamonky] #4755501
05/12/18 11:57 PM
05/12/18 11:57 PM
Cali
Malo83 Offline
Malo83  Offline
Cali
I run 2 STP filters on my DD 83 Silverado with no problems, oil and air get them at AutoZone. thumbsup
Re: STP Air Filter Efficiency [Re: JerryBob] #4755548
05/13/18 03:44 AM
05/13/18 03:44 AM
Virginia
bbhero Offline
bbhero  Offline
Virginia
Yeah I saw that the other day in AZ. And I was like holy cow that is substandard.
I thought the back of the box should have read: "This air filter only catch large insects, hummingbirds, and large pieces of gravel. This air filter is not intended for the meaningful use of small particulate filtration".
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: STP Air Filter Efficiency [Re: JerryBob] #4770354
05/28/18 01:29 PM
05/28/18 01:29 PM
WV
jonnied1 Offline
jonnied1  Offline
WV
Purchased a STP filter for my 2008 Jeep Rubicon the other day. The rubber seal around the edge of the filter is not even secured to the filter media. Pulled the seal loose removing the filter from the box. Took it back and purchased a Purolator filter.
The STP is a very poor quality build as far as I am concerned!
