comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
92 registered members (1978elcamino, anndel, 53' Stude, 2015_PSD, AdditiveOCD, 9 invisible), 2,041 guests, and 58 spiders.
Topics286,391
Posts4,907,422
Members67,614
Most Online2,967
Mar 10th, 2019
Yamalube Outboard Oil still the best? #4754758
05/12/18 06:12 AM
05/12/18 06:12 AM
FL
Gbert Offline OP
Gbert  Offline OP
FL
I have a set of 2001 Yamaha 200hp HPDIs. ~ 400hrs. Run Great. I don't do much idling, run at 4000-4300rpm. I don't foul plugs and it doesn't smoke too bad. Problem is that I used to buy bulk ~ $21/gallon but now they charge $28. Question is am I better off these days using a competitor's brand like Evinrude XD50 or Mercury Premium Plus? Both seem to be in the same price range. Many advocate for Pennzoil XLF or Synthetic which are quite cheaper and burn cleaner. Some dealers claim that these have been prone to gelling and clogging the smaller in-line oil filters.... Are they less expensive due to less corrosion protection/additives? I use 1oz Ring Free per 10 Gal of fuel with every fill. I keep my boat on my lift and therefore exposure to salt air is higher than average. I'm looking for the best oil not the least expensive. Please share your thoughts and oil analysis if you have any. Yamaha couldn't provide any details.
Thanks in advance.
Re: Yamalube Outboard Oil still the best? [Re: Gbert] #4754770
05/12/18 06:44 AM
05/12/18 06:44 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Donít worry. You are getting caught up in the advertising game. The oil you want should approved by the NMMA as TCW-3. If it has the emblem you are good to go. The rest is fierce brand loyalty which is what advertisers work hard to install into people, plus personal opinions, some based on inadequate data, peer pressure, internet rumours, and what have you. Corrosion protection is a big deal with with TCW-3 and one of the main reasons to look for the emblem.
Iíd recommend using anything with the TCW-3 emblem and stocking up on sales.
If you want the job done right......do it yourself.
Re: Yamalube Outboard Oil still the best? [Re: Snagglefoot] #4754816
05/12/18 07:58 AM
05/12/18 07:58 AM
Toronto Canada
WobblyElvis Online content
WobblyElvis  Online Content
Toronto Canada
Agree + 1
Re: Yamalube Outboard Oil still the best? [Re: Gbert] #4754846
05/12/18 08:34 AM
05/12/18 08:34 AM
IL
Vern_in_IL Offline
Vern_in_IL  Offline
IL
Think with your dipstick Jimmy!
Re: Yamalube Outboard Oil still the best? [Re: Gbert] #4754873
05/12/18 09:11 AM
05/12/18 09:11 AM
texas
danez_yoda Offline
danez_yoda  Offline
texas
There was a test report some time ago with yamalube vs johnson evenrude and quicksilver mercury. They were all good but yamalube left fewer deposits.
If yamalube got you this far id continue usng it.
Re: Yamalube Outboard Oil still the best? [Re: Gbert] #4754918
05/12/18 09:59 AM
05/12/18 09:59 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Just need to find out who bottles it FOR Yamaha and order it from them
Re: Yamalube Outboard Oil still the best? [Re: Gbert] #4754947
05/12/18 10:37 AM
05/12/18 10:37 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
This is always tough. Yamaha lubes are very good, and very pricey. No dummies in their engineering dept.
But Mercury Marine is usually equally good at what they do, and they make/market some very good lubes. Their bottom end oils are maybe the best there is. Over many years, I have had very good luck with Quicksilver lubes. So I'd say they are equivalent, based on personal experience.
However, I used to be the small boats engineer for NOAA out here in Cali and we ran the snot out of our outboards - like 8 hrs a day under all kinds of condition including pulling bottom clearance drags which meant near full throttle at low hull speeds for hours on end. We only used Chevron TCW-3 and never had one hitch (it was on contract). Motors always came apart clean. The Chevron guys obviously know what they are doing too ...
So you are going to have to start looking for lube tests. It's not often easy data to come by.
Personally I would use any name brand big refiner TCW-3 and just cruise on. You are already adding ring free. So your cocktail is about as good as you'll need. The motors are well broken in. I would not sweat it. But I know the nagging feeling ...
Re: Yamalube Outboard Oil still the best? [Re: Gbert] #4755194
05/12/18 04:37 PM
05/12/18 04:37 PM
Pennsylvania
Slick17601 Offline
Slick17601  Offline
Pennsylvania
Quicksilver Premium Plus is also a really good oil. I would be surprised though if it was much cheaper than Yamalube.
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: Yamalube Outboard Oil still the best? [Re: Gbert] #4758163
05/15/18 07:06 PM
05/15/18 07:06 PM
FL
Gbert Offline OP
Gbert  Offline OP
FL
Anyone seen the test report of yamalube v Mercury v Evinrude?
Link?
Thanks for the feedback.
Re: Yamalube Outboard Oil still the best? [Re: Gbert] #4759384
05/17/18 01:31 AM
05/17/18 01:31 AM
iowa
sh40674 Offline
sh40674  Offline
iowa
guessing this is a 2 stroke? i've owned boats but never got into the motors much, or the oil as i've always used pennzoil. i have an 84' 40hp evinrude. never an issue, carbs are clean as a whistle. had it checked over when i bought it and the shop said it's one of the cleanest they've seen in those years. the guy i bought it from, his father bought it in 84 and they've always used pennzoil. used it on my last boat too and never an issue. i love pennzoil products. used to fall into the hype that it was junk oil but after being on this site, i use it quite a bit. my truck runs great on it, much smoother. i've become a big believer in their stuff.
plus the pennzoil marine is available almost everywhere, and not bad priced at all.
Re: Yamalube Outboard Oil still the best? [Re: Gbert] #4769056
05/26/18 09:09 PM
05/26/18 09:09 PM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
Thanks in advance.
[b]Yamalube Outboard Oil still the best?[/b]
Who told you it was the best?
Imo, based on what I have seen and read, it is overpriced and overly hyped everyday run of the mill oil.
Many other oils, both 2 and 4 stroke, exist out there that are not only better but also way cheaper.
I used Yamalube once in my 2008 4 stroke Yamaha snowmobile and never went back. One oil change, (3 ltrs and a Yamaha filter) cost me over $90 dollars CDN. Did some reading here on VOA's and UOA's and started using Mobil-1 0W-40 European formula and a Hi-Flo filter. Cost went from $90 down to $40 and I am now running a superior oil and filter compared to the Yamalube junk.
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: Yamalube Outboard Oil still the best? [Re: irv] #4772181
05/30/18 10:38 AM
05/30/18 10:38 AM
GA
Proven Offline
Proven  Offline
GA
Yamalube is custom blended to factory specifications by Nippon Oil Company. They have a location in Alabama that they built primarily for just this reason. It is not rebranded/relabled oil. Yamalube might be more expensive, but the margins on it are honestly low.
TC-W3 is the standard for which 2-Stroke Marine oils are measured, some will exceed the standard and others will only meet it. The governing body meets once or twice a year to go over their surveillance results, which are generated by SWRI. If you stick with major OEM oils, you should be safe. The last thing they want is their customers to experience engine failures in the motors they sell.
The adage of "pay me now or pay me later" comes to mind. You sure can just grab any TC-W3 rated oil and run it, but there are definitely differences in these oils that should matter. If you've got twin 200HP HPDI's, you've got a lot invested in that boat and running [censored] oil could ruin it for you.
Proven
I fix, I build, I break, I do.
Re: Yamalube Outboard Oil still the best? [Re: Snagglefoot] #4801606
06/30/18 04:38 PM
06/30/18 04:38 PM
Bucks County, PA
Hot_Ajax Offline
Hot_Ajax  Offline
Bucks County, PA
Agreed. Marketing trick. I've run Pennzoil, Amsoil, something from Merc, all TCW-3. Guess what? The only engine work I've done is to change the spark plugs and fuel filters. So if you sleep better at nite with Yamalube in the tanks, go for it. Otherwise, I would save my money.
Re: Yamalube Outboard Oil still the best? [Re: BrocLuno] #4805333
07/04/18 09:24 PM
07/04/18 09:24 PM
Owego, New York
Gillsy Offline
Gillsy  Offline
Owego, New York
Spent some time on the phone with a Chevron Lube Tech one day discussing outboard oil. He told me that two stroke outboard oil was a pretty crude product. Nothing really special about it. I've tried many brands including Redline, Citgo, Pennzoil, Chevron, and Phillips Injex. Nothing bad to say about any of them. Be aware that changing oil brands can sometimes change idle quality on a carb engine. No experience with a HPDI.
Many are the afflictions of a righteous man
2018 F150 Supercab 2.7 Ecoboost 4x4
400 lbs/ft of grin at 2750 RPM
2016 Kawasaki 650 Versys LT
