No LS blocks in NHRA Pro Stock. And not enough RPM or power for a Pro Stock engine.
Good point. A quick search yielded this Kaase built 820ci Ford Pro Stock video:
Which is now 830ci:
http://jonkaaseracingengines.com/shop/engines/kaase-830-c-i-pro-stock-ford/
And makes over 2,000HP N/A.
NHRA Pro Stock is limited to 500 cu in.
There are other racing series that allow larger displacement, some run as much as 1000 cu in.
That'd be IHRA Pro Stock Mountain Motor IIRC. I watched them run a few times, the 800+ CI mills were nuts!
Yes, the PDRA, and the IHRA when running in the USA allow larger displacement.
ANDRA and the IHRA (when running in Australia) allow 400 cu in.
