A 2001 Lincoln Continental I am buying. Comes with Cooper made Starfire RS-C 2.0 (225 R16) up front which are nearly new. The rear tires are factory original Michelins built in late 2000 - and dry cracked way too far - they almost look pitted. But still have decent tread at 40K miles...18 yrs old!
The rear tires are spent and will be junked. What to put on the rears? Another pair of Starfires ($75 each) to match the set?...and when those wear out as a group...replace with a quality set of 4. Starfires aren't exactly Grand Touring tires like Michelin Primacy MXV4. I've had 3 sets of Primacy and like them. The Altimax RT43 is another GT tire I wouldn't mind trying either. So what are the best options here? Is putting a different brand of tire on the back a bad idea? Note that with Front Wheel Drive the mfg recommends an X pattern when rotating tires. So any tire will spend time on both sides of the car.
