Originally Posted By: oil_film_movies
Although, IF it seems built good with a silicone ADBV, then the Ryco full-syn media filter may be very good.
Yes the Ryco Syntec has a silicone ADBV.
Quote:
Features:
15,000 kilometre service life
100% synthetic media, with wire backing for added strength
99.8% efficiency at 25µm
High temperature resistance (up to 260°C)
Low restriction to flow (excellent at start up and when cold)
High resistance to chemical attack
Spiral wound centre tube for strength, to withstand pressure
Teflon coated main sealing gasket to aid in removal
Grit finished spin on can for better grip
Silicone ADV*
*where fitted
Ref:
http://www.rycofilters.com.au/products/syntec
They say 15,000 KM but I think that is based on the standard Aussie OCI of 10,000 KM with regular filters. So they are probably saying Syntec can go 50% longer. My car specs a 15,000 KM on a regular filte, so I would happily go 20,000 KM on a Syntec. But that's just me.
OP, most auto stores like Repco or SCA have the new Ryco Syntec filters, so it should be easy to find them or order them in. Do you live out bush ? Should be able to order on-line, you want a Z9ST.
