Walmart and Valvoline
by Bullwinkle007. 01/22/19 09:10 PM
Getting Our Kicks On Route 66
by 2015_PSD. 01/22/19 08:40 PM
Uploading a short film clip from an IPhone.
by Snagglefoot. 01/22/19 07:52 PM
Purolator L34631 (torn media)
by LDM. 01/22/19 07:51 PM
THIS close to getting a VDB today at TPA
by 14Accent. 01/22/19 07:48 PM
Supco Appliance Parts.
by George7941. 01/22/19 07:36 PM
Unusual Jury summons.
by Chris142. 01/22/19 06:31 PM
Vibration feeling after new tires installed?
by MONKEYMAN. 01/22/19 05:51 PM
Sudden Shake - ‘18 Accord
by Throt. 01/22/19 05:43 PM
05 Ford 500 Intake hole - melted
by Geauxtiger. 01/22/19 05:41 PM
How's K&N 1004 on Kia/Hyundai GDI
by SlavaB. 01/22/19 05:18 PM
more PSD woes with cold weather
by Donald. 01/22/19 05:10 PM
Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
73 registered members (209paulc, AdRock, 69GTX, askani79705, 11 invisible), 1,159 guests, and 41 spiders.
Topics297,006
Posts4,963,331
Members67,013
Most Online2,821
Jan 21st, 2019
Mercedes cartridge filter comparison #4754263
05/11/18 01:16 PM
05/11/18 01:16 PM
Seattle, WA
SnowmanCO Offline OP
Seattle, WA
Up until a couple years ago, most Mercedes engines used a particular cartridge filter. I recently acquired a 2010 C300, and wanted to compare some filters out there. I have seen numerous reports of paper versions of these filters being problematic due to the high oil pressures causing them to twist and distort, so I only only purchased synthetic (fleece as the Mercedes people call them) filters. I ended up getting a Mann (who is the OEM supplier for this model), Bosch, Premium Guard, Mahle, and Hegst Here is my stock:
All good quality filters. Notice the Mann, Bosch and PG models look very similar. More on that later. Here is a closer look at the top of the Hengst:
A nice felt seal at the ends of the filter. The banding around the exterior to prevent filter distortion from pressure is made out of some sort of glue material. Each of the three strips was uniformly applied with no sign of any gaps. The box was also sealed, so it could not be tampered with without breaking the seal. Next is the Mahle:
This one has a rubber seal at the ends. The two bands are probable the downside of this filter. They are made out of a plastic material that is bonded to the filter. There is some overlap where the band is wrapped around (not shown). Next is a close up of the premium guard:
Rock Auto had this one for $4.12 cents, and the picture appeared to be exactly like the OEM Mann filter, so I thought I would give it a chance. It turns out, its a Mann knock off made in China (the Mann and Bosch filters are made in Germany). The media is very similar, but may be a little thicker on the PG. The nylon string banding is appears to be coated with some sort of glue to allow it to attach to the filter (in all 3 cases).
Next, comes the Bosch:
This filter appears to be identical to the Mann. I would even say, they are most likely made in the same factory based on the fonts on the date codes. Here is a closer look at the Mann:
The Mann filters are also in a sealed box, so they cannot be tampered with. They are the gold standard for this filter model. I don't have an official "Mercedes Branded" filter to compare these to, but there is numerous evidence that they are indeed Mann made (no pun intended) filters on this model. I can get the Mann filters for around $9 from FCPEuro and RMEuropean, and the Bosch filters for just over $7 from RMEuropean. If I ever need to buy more filters, I would probably go with the Bosch just to save two bucks. All signs point to them actually being manufactured in the same factory as the Mann models. The Chinese knock off PG filters aren't bad, but I would rather get the legit filters for a couple bucks more (plus, Rock auto adds shipping costs).
16 F150 5.0-QS UD 5w20,MtCrft FL500S
10 Merc C300-Mob 1 0w40,MANN H U7 18/5X
08 Maz3S 2.3-Cast Syn 5w30,Wix 57203XP
17JD D160-Cast Syn 0w30,MtCrft FL400S
Re: Mercedes cartridge filter comparison [Re: SnowmanCO] #4754369
05/11/18 03:45 PM
05/11/18 03:45 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Many thanks. That was good.
Now weigh them and post the results.
Best of luck with your new ride.
Re: Mercedes cartridge filter comparison [Re: Kira] #4754376
05/11/18 03:56 PM
05/11/18 03:56 PM
Seattle, WA
Seattle, WA
Getting a scale at Harbor Freight my next visit. Will do!
Re: Mercedes cartridge filter comparison [Re: SnowmanCO] #4754379
05/11/18 04:03 PM
05/11/18 04:03 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
Thank you for posting thumbsup
The Purolator Boss will be the same as the Bosch/Mann. Bosch used to co-own Purolator with Mann, and although Bosch divested themselves from Puro, their filters are still made by Purolator and Mann. I looked at all three Purolators for this application (25277), and they all look the same! So yout CLassic, P1, and Boss could all be the same but in different boxes (and prices). L25277/PL25277/PBL25277 crzy
There is also a Fram Ultra for this application, XG8481, and the FPS version FPS8481. It uses the standard Fram Ultra pink media and wire backing.
Wix also makes a filter for this car, and the 57078 seems to use the same OE fleece and plastic mesh construction. It has black plastic end caps and a spiral glue pattern
Re: Mercedes cartridge filter comparison [Re: slacktide_bitog] #4754408
05/11/18 05:00 PM
05/11/18 05:00 PM
Seattle, WA
Seattle, WA
Good call! It does appear that all 3 of the Purolator filters are the exact Mann/Bosch equivalents. That is insane, especially considering the price differences (it looks like they vary from $13 for classic ti 20+ dollars for the Boss - for the same filter I purchased as a Bosch for $7). It goes to show that branding effects price. It does look like the Wix 57078 is now the same filter too. When looking around, I noticed Wix used to offer a different variant - https://www.youtube.com/watch?v=sTpOH5J7SZU. Even Wix's website shows that same model, so it may have been a recent change http://www.wixfilters.com/Lookup/Exactmatch.aspx?PartNo=57078. It all makes sense since they are all under the Mann company.
Re: Mercedes cartridge filter comparison [Re: SnowmanCO] #4754425
05/11/18 05:22 PM
05/11/18 05:22 PM
Tri State Conservative
Zee09 Offline
Zee09  Offline
Nice post. Thanks.
I had a few PG clones of the 7317 filters and they looked good.
Can synthetic type. PG said they were 98% efficiency ( 30 microns)
Not bad. Unrelated of course but a PG. Product too
"If I walked on water, they'd say I couldn't swim."
Re: Mercedes cartridge filter comparison [Re: SnowmanCO] #4754542
05/11/18 07:50 PM
05/11/18 07:50 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Mann ftw!
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: EDGE 0W-30
Re: Mercedes cartridge filter comparison [Re: SnowmanCO] #4754570
05/11/18 08:16 PM
05/11/18 08:16 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Nice photos, thanks!
Re: Mercedes cartridge filter comparison [Re: SnowmanCO] #4754623
05/11/18 09:01 PM
05/11/18 09:01 PM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
I have a MB left, looks identical to Mann except has MB logo. The two black marks are to know when the filter is correctly inserted? The others look nice, the Mahle has a different cap. The PG is a good copier.
Re: Mercedes cartridge filter comparison [Re: SnowmanCO] #4754631
05/11/18 09:19 PM
05/11/18 09:19 PM
Chicago, IL
Brybo86 Offline
Brybo86  Offline
Chicago, IL
Subbed
08 Honda Accord EX-L 2.4L M1 EP 0w20 145k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 193k
95 Yamaha Jog
Re: Mercedes cartridge filter comparison [Re: SnowmanCO] #4754762
05/12/18 05:20 AM
05/12/18 05:20 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Not surprised Bosch likely identical to Mann. Companies still pretty tight I'd imagine in oil filter manufacturing. Former co owners of Purolator and M&H Puro still making US made Bosch filters.
'Appearance wise' heck of a Mann knock off by PG. Can't speculate on functional similarity.
Thanks for pics.
Re: Mercedes cartridge filter comparison [Re: Sayjac] #4755684
05/13/18 07:59 AM
05/13/18 07:59 AM
North Carolina
Egg_Head Offline
Egg_Head  Offline
North Carolina
Very nice write up. I have used the same Mann filter p/n on my neighbor's Benzs. I purchase from AAP and have never seen one that is sealed.
1979 Garelli Rally Sport
2009 Cub Cadet LT1042
2002 BMW 540 M Sport (totaled)
2011 MB E350 4Matic wagon
1979 CJ-7
Re: Mercedes cartridge filter comparison [Re: SnowmanCO] #4756301
05/13/18 07:48 PM
05/13/18 07:48 PM
Illinois USA
IllinoisSparky Offline
Illinois USA
Thanks Snowman.
I have used the Mann, Mahle, and Hengst. I now prefer the Mann and Mahle because they seal really well around the housing.
Just took a Mann off, and put on a Mahle on my 99. Mann was still tight, and Mahle rubber seal fits very tight.
If the seal top/bottom is not tight, it is no different than a tear in the media. IMO
04 Ford Explorer PP 5W-30/Puro PSL
99 MB CLK320 Castrol 0W-40/M1 filter
08 MB SL550 M1 0W-40/MB
09 BMW X5 3.0i Dealer 5W-30/BMW
11 MB E350 Bluetec MB 5W-30/MB
Re: Mercedes cartridge filter comparison [Re: IllinoisSparky] #4756964
05/14/18 12:02 PM
05/14/18 12:02 PM
Seattle, WA
Seattle, WA
I thought I would post a couple pics showing how the Mann and Hengst filter boxes are sealed. This was the case for me for the filters I have purchased from FCP Euro and RMEuropean. I The Hengst has a tab on top of the box that has to be ripped to open. I ended up taping mine up, which ripped off some of the paper from. The Mann has two small glue areas at the top, and is well glued at the bottom.
Re: Mercedes cartridge filter comparison [Re: SnowmanCO] #4757879
05/15/18 11:19 AM
05/15/18 11:19 AM
England
Tikka Offline
Tikka  Offline
England
Hi
Super thread and photos, thank you.
Are these the Filters used on the OM642 Merc engine?
Are they idiot proof to fit? I noticed someone asked about the two black marks being an aid to fitting. How is this please?
Forgive any dumb questions but I am new to forum and keen to learn more.
Many thanks.
