Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
Starter cross reference?
by dlundblad. 01/22/19 05:11 AM
Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
How cold is it? (Humor)
by StevieC. 01/21/19 07:13 PM
Slight performance decrease
by A_User55555. 01/21/19 06:54 PM
Binco, Coolbreez1973, jmcast1127, DF8005, FT86dude11
67009 Registered Users
105 registered members (53' Stude, 4WD, Arctic388, 2015_PSD, AndyB, 15 invisible), 1,837 guests, and 36 spiders.
Topics296,966
Posts4,962,553
Members67,009
Most Online2,821
Jan 21st, 2019
Ford Escape Owner's manual says 5.7 quarts, but... #4753879
05/11/18 07:13 AM
05/11/18 07:13 AM
McGregor TX
mrdctaylor Offline OP
McGregor TX
I changed the oil in my son's new-to-him 2017 Ford Escape with the 2.0L Ecoboost engine for the first time. So far it has been a great little car. I put a Motorcraft filter on it and used 5W30 (which is what the 2.0 calls for) Havoline Pro DS Synthetic that I had from an O'Reilly clearance a while back.
Anyway, the manual says it uses 5.7 quarts. I put in 5 and ran it for a minute to check for leaks. I then buttoned everything up and backed it off of the ramps to put in the rest of the oil. I put in another half quart and it was still at the bottom of the hash marks. I added more...more...I ended up adding a full 6.0 quarts (maybe 6.1--I'm using 5 quart jugs so it isn't exact) of oil to get it just to the top of the hashmarks on the dipstick. Yes, I waited a bit to let oil drain down to the pan like I do with all of my vehicles.
I'm just wondering if this dipstick is calibrated so that 5.7 is supposed to be in the *middle* of the hashmarks (as opposed to the top). I'm pretty confident it isn't overfilled given that it comes to the top of the hashmark but not over. I've just never had a vehicle where the amount in the owner's manual wasn't right at the "full" mark. Thoughts? Has anyone else who has this car/engine noticed this? Even if I did overfill it by .3-.4 quarts, I'm assuming we won't have issues, right? I know REALLY overfilling can cause problems, obviously, but .3-.4 quarts seems pretty nominal especially given the dipstick markings.
02 Tacoma 3.4L, 222K, Magnatec 10W30
12 Highlander 3.5L, 101K, Napa Syn 0W20
17 Escape 2.0L, 37K, Hav ProDS 5W30
02 Trailblazer 4.2L, 182K, Edge HM 10W40
Re: Ford Escape Owner's manual says 5.7 quarts, but... [Re: mrdctaylor] #4753887
05/11/18 07:20 AM
05/11/18 07:20 AM
Midwest
volk06 Offline
volk06  Offline
Midwest
Did you let it sit for 15 minutes before checking? Its important on the ecoboost engines to check it cold or after atleast 15 minutes.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
Re: Ford Escape Owner's manual says 5.7 quarts, but... [Re: mrdctaylor] #4753889
05/11/18 07:22 AM
05/11/18 07:22 AM
McGregor TX
McGregor TX
I went back and checked it an hour or so later and it was right at the top of the hashmarks where it should be. shrug
Re: Ford Escape Owner's manual says 5.7 quarts, but... [Re: mrdctaylor] #4753890
05/11/18 07:23 AM
05/11/18 07:23 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
The dipstick is(IDK if calibrated is the best word) fairly accurate and I myself would look at 5.7 qts as 6.0 qts. For the next several OCI's, monitor what you are putting in and that should give you a baseline to work with. In the vehicles future, you may feel very comfortable just dumping in the full 6.0 qts and calling it a day.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Ford Escape Owner's manual says 5.7 quarts, but... [Re: mrdctaylor] #4753893
05/11/18 07:27 AM
05/11/18 07:27 AM
McGregor TX
McGregor TX
Yeah, this was the first oil change so I was being cautious just adding a little bit at a time. I know how my other vehicles are so I'm a little more laid back with them.
Plus, I wanted to get it at the top of the hash so I can easily tell if this engine is using any oil over the course of the interval. I just like to keep an eye on things like that and I've taught my son to do the same. It is still under warranty so I want to make sure we monitor everything.
Re: Ford Escape Owner's manual says 5.7 quarts, but... [Re: mrdctaylor] #4753897
05/11/18 07:28 AM
05/11/18 07:28 AM
midwest
JamesBond Offline
JamesBond  Offline
midwest
Maybe more drains out when it's on ramps as opposed to when it's level. The guys as the Ford factory probably use a lift instead of laying on the ground under ramps when they write the owners manual.
i wouldn't worry about it, just go off of the dipstick.
Re: Ford Escape Owner's manual says 5.7 quarts, but... [Re: mrdctaylor] #4753903
05/11/18 07:33 AM
05/11/18 07:33 AM
MN
oil_film_movies Offline
MN
Yes, got to let it sit for a good long time, and then check it. Its probably better just to put in 1 quart less than spec capacity at oil change time, after draining for 10 minutes or so of course. Then, just check it a week later and keep adding a dash every 2 weeks or so until its full. That way it creeps up to the line, and you can base the reading off of having it sit all night for accuracy.
If you do have it overfilled a bit, just check the dipstick immediately after driving it to look for bubbles. No bubbles, you're fine.
Re: Ford Escape Owner's manual says 5.7 quarts, but... [Re: mrdctaylor] #4753904
05/11/18 07:34 AM
05/11/18 07:34 AM
McGregor TX
McGregor TX
That crossed my mind. Given the position of the drain plug, it does seem like you could get slightly more oil out of the pan on ramps. Who knows.
Re: Ford Escape Owner's manual says 5.7 quarts, but... [Re: mrdctaylor] #4753908
05/11/18 07:37 AM
05/11/18 07:37 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
That oil was sticking to the engine nicely. Good for startups.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Ford Escape Owner's manual says 5.7 quarts, but... [Re: mrdctaylor] #4753961
05/11/18 08:14 AM
05/11/18 08:14 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
I usually put ~250ml under the drain and refill with filter amount and it falls where it may on the dipstick. Volume replaced is more important than DS reading; I wouldn't feel comfortable if it was 500ML OVER the top of the hashmark with this process though.
2019 VW Jetta S,6M OCI#0 62mi-Castrol Edge Prof VW508+OE Filter; '17 Subaru Crosstrek CVT OC#5 37K mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Ford Escape Owner's manual says 5.7 quarts, but... [Re: mrdctaylor] #4754084
05/11/18 09:49 AM
05/11/18 09:49 AM
Ruidoso, NM USA
ammolab Offline
ammolab  Offline
Ruidoso, NM USA
Often the mfg stated capacity brings the level to the midrange of the dipstick marks...not to the "max" of the range.
2009 Honda CR-V
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: Ford Escape Owner's manual says 5.7 quarts, but... [Re: mrdctaylor] #4754109
05/11/18 10:11 AM
05/11/18 10:11 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
My Civic calls for 4.25L, always takes almost a full 5.0L to fill.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Ford Escape Owner's manual says 5.7 quarts, but... [Re: mrdctaylor] #4754134
05/11/18 10:38 AM
05/11/18 10:38 AM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
I put in 6 quarts on my mom's Fusion with a 2.0EB and have been doing it as long as she has owned the car without issue.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Ford Escape Owner's manual says 5.7 quarts, but... [Re: bdcardinal] #4754215
05/11/18 12:27 PM
05/11/18 12:27 PM
The Garden State
Whimsey Offline
Whimsey  Offline
The Garden State
If you use 6 quarts instead of 5.7 you are adding 10 oz more, not a problem. In fact the dip stick for our 2017 Explorer 2.3 EB has the hash marks for 5.7 quarts and a maximum fill "hole" mark, which I assume is if you add 6 quarts instead of 5.7. For me 5.7 quarts for an oil change brings it to the top of the hash marks. It's just a pain in the butt to wait the 20 minutes to get a semi accurate reading on the dip stick. Luckily the Explorer doesn't use any significant amount of oil even in a 7,000 mile summer high speed run.
Whimsey
Re: Ford Escape Owner's manual says 5.7 quarts, but... [Re: bdcardinal] #4754216
05/11/18 12:28 PM
05/11/18 12:28 PM
Raleigh ,NC CSA
rshaw125 Offline
rshaw125  Offline
Raleigh ,NC CSA
Same here with our Edge 2.0 EB. Currently Motorcraft filter and Mobil 1. 15% on the OLM and it'll get changed again.
2012 Porsche Carrera S
2016 Ford Edge 2.0
2002 Taurus Vulcan SOLD
2006 Explorer SOLD
