Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
How cold is it? (Humor)
by StevieC. 01/21/19 07:13 PM
Slight performance decrease
by A_User55555. 01/21/19 06:54 PM
how to keep your vehicle battery...
by Char Baby. 01/21/19 06:31 PM
2012 to 2016 ford focus
by WhyMe. 01/21/19 06:30 PM
LHM anyone?
by mistersooty. 01/21/19 06:30 PM
Walmart Oil Changes.
by Bill7. 01/21/19 06:10 PM
Coolbreez1973, jmcast1127, DF8005, FT86dude11, RTSAllison
67008 Registered Users
34 registered members (Astro_Guy, bmod305, ccs368, AurionX2, Char Baby, CB900F2, 6 invisible), 936 guests, and 47 spiders.
Topics296,961
Posts4,962,414
Members67,008
Most Online2,821
Jan 21st, 2019
Prestone vs. Asian Antifreeze #4753850
05/11/18 06:49 AM
05/11/18 06:49 AM
WA
OilUzer Online content OP
OilUzer  Online Content OP
WA
We have a Hyundai Tuscon and based on the Owners manual, I should be able to use Prestone antifreeze.
OM says ethanol glycol based antifreeze and there is no other specific requirements ...
However the antifreeze in the car is kind of blue (if I recall correctly) and few people (including the parts dept at Hyundai) have told me not to use Prestone ... another guy at auto parts place told me i need to buy a special antifreeze for Japanese cars like zerex Asian???
I have to trust the OM (unless if it is out of date) and besides I have 3 gallons of prestone in the garage... lol
something doesn't make sense here! I haven't done a lot of research but I should be able to trust the OM. No?
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4753864
05/11/18 07:03 AM
05/11/18 07:03 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
IIRC, the Asian antifreeze are silicate free while the regular Prestone have silicate.
Not sure why that is important but I am sure when dealing with chemicals, there may be reaction if mixed together.
The results may be undesirable for long term.
  • 2017 Toyota Sienna
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4753870
05/11/18 07:08 AM
05/11/18 07:08 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
I have a Nissan that uses blue. I use this pre mixed 50/50. Guess the jug is blue for a reason. https://www.oreillyauto.com/detail/b/zer.../861398/2496985
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4753891
05/11/18 07:23 AM
05/11/18 07:23 AM
Central Texas
Brian553 Offline
Brian553  Offline
Central Texas
Not all Prestone is the same! If you have the Dex-cool (OAT) prestone fluid, I would take it back, because Hyundai does not use OAT.
If you bought Prestone Extended Life, then you can mix it, and it will be fine; these are both HOAT fluids (their organic acids are the same, or at least have no resulting detriment to mixing.)
Typically the Asian HOAT formulas use corrosion inhibitors that are different than european formulas.
Asian formulas use phosphates to protect against corrosion on ferrous parts and preventing cavitation.
European formulas use silicates in small concentrations, which helps protect aluminum from high temperature corrosion (and can also help slow or stop a head gasket leak if one forms).
Asian formulas can be bought at the car dealer, but their suppliers in NA are generally Zerex, owned by Valvoline.
Zerex Asian : https://www.valvoline.com/our-products/antifreeze-products/zerex-asian-vehicle-antifreeze-coolant
Valvoline Asian : https://www.walmart.com/ip/Valvoline-Asian-Vehicle-Antifreeze-Ready-To-Use-1-Gallon/49660461
[As far as I have found, these are the same products... I have no idea what Valvoline is doing.]
Personally, I wish I could get a low silicate addition to either of these, but I have come up dry. Can't say I've ever heard of it being an issue anyway.
17 Rio 58k............Delvac 15w40 5k
08 Rav4 V6 158k..ST Synthetic HM 5w30-5k
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4753902
05/11/18 07:33 AM
05/11/18 07:33 AM
Michigan
khittner Offline
khittner  Offline
Michigan
If your Hyundai’s owner’s manual is like the one for my ‘10 Sonata, the coolant spec is for an “ethylene glycol base for aluminum radiator”. My Sonata’s OEM coolant was also blue. Get the Zerex Asian blue stuff, and be happy. Hand off your green Prestone to someone with an older domestic vehicle.
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4754079
05/11/18 09:40 AM
05/11/18 09:40 AM
Nebraska
BJD78 Offline
BJD78  Offline
Nebraska
The OM that I have states :"ethylene glycol based coolant for aluminum radiators" I use regular Peak Long life full strength mixed 50/50 with distilled water. When I type year and model for my Sonata or Tuscon into the part search on Autozone the following brands fit: Prestone, Peak,OET, Pentefrost and the Autozone brands. The 50/50 mix seems a bit high since the full strength is only about $2 more and distilled water is so cheap, easy enough to do a 50/50 mix. Prestone would work fine as would the Zerox Asian blue , or the global types of coolant.
2010 Forester:122K
2009 Sonata :189K
2010 Tucson:55K
OCI 5K using the cheapest dino oil I can buy,usually NAPA or TSC Travelers oil.
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4754081
05/11/18 09:46 AM
05/11/18 09:46 AM
WA
WA
i guess Ethylene and not "ethanol" ... I got my chemicals mixed up smile
Btw, the Prestone i have doesn't say extended but it says verbatim:
"For ANY car"
"Works with ANY color antifreeze"
"Will NOT void warranty"
"ALL MAKES, ALL MODELS"
Better be on the safe side, I am going to get the valvoline zerex. I have seen it at WM. I have older cars that can use the prestone.
Thanks guys!
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4754163
05/11/18 11:10 AM
05/11/18 11:10 AM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
I personally am going to use Pentofrost Asian because I cannot stand purchasing 50/50 mix and valvoline only offers that in their zerex asian.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4754416
05/11/18 05:13 PM
05/11/18 05:13 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
Recochem brand "OEM" Antifreeze is also sold in concentrate, at Pep Boys in this area, but I don't know cost comparison to Pentofrost. Recochem is a Canadian company.
http://www.oemantifreeze.com
Here's the OEM Blue concentrate, less than $15 / gallon.
https://m.pepboys.com/product/details/879925/00233
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4754493
05/11/18 06:53 PM
05/11/18 06:53 PM
WA
WA
I don't recall seeing the Asian concentrate in stores either. At least for the name brands i use.
Just curious why prestone (see my previous post) says use for all cars, models, any color ...
Is that marketing [censored]?!
Re: Prestone vs. Asian Antifreeze [Re: Brian553] #4757555
05/15/18 05:15 AM
05/15/18 05:15 AM
New York
pbm Offline
pbm  Offline
New York
GO-5 is a H-OAT with a little silicate in it.
Also, I believe that Prestone AMAM is an OAT coolant (very similar to their Dexcool without the license).
I think any of these will work fine for the OP as long as he FLUSHES his system (with Distilled) water) until there is no trace of the original coolant...3X should do it.
If the OP is intent on using a phosphated H-OAT he should check his local Autozone for the Pentosin that's on CLEARANCE....the A2 green and the A4 blue are both compatible....the A2 is a concentrate and the A3 is a pre-mix. The A2 is original H-HOAT LL while the A3 is improved formula good for 'extended' long life. These are similar to what came in his Hyundai originally. I also wouldn't hesitate using the silicated H-OAT, GO-5, after a good flush.
'Journalism is Dead'
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4762324
05/19/18 06:36 PM
05/19/18 06:36 PM
California
jj51702 Offline
jj51702  Offline
California
I don't discriminate against my antifreeze whether it's Asian or not
Re: Prestone vs. Asian Antifreeze [Re: jj51702] #4763609
05/21/18 04:49 AM
05/21/18 04:49 AM
WA
WA
That's not for you to decide!
Will your car marry the antifreeze in order to make it %100 legal? it will be for 3-5 years if compatible like most Other marriages ... grin
Btw, no one knows about the "any color, any car, any ..." claim On the container!
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4763917
05/21/18 12:04 PM
05/21/18 12:04 PM
California
jj51702 Offline
jj51702  Offline
California
Haha
Re: Prestone vs. Asian Antifreeze [Re: OilUzer] #4780926
06/08/18 05:34 AM
06/08/18 05:34 AM
WA
WA
did some more research ... I have prestone cor-guard and it says "extended life" on it as well. I missed that before. It is the regular yellow container you see in most stores. It also says to use in any car/model, or with any color antifreeze ...
As @pbm and others have said here, it should be ok to use it in Hyundai. OM says use ethylene glycol based coolant for aluminum radiator and I called another Hyundai parts department and the parts person put me on hold and asked one of the mechanics at the service dept. and was told that it is ok to use the prestone.I
Regarding any car, and model, any color antifreeze claim:
So far ok for Asian cars ... and also this is from prestone website regarding Europen cars:
"Some European automobile manufacturers request that a phosphate-free antifreeze be used in their vehicles. This issue is related to the extremely high mineral content of the water in Europe. If you were to mix an antifreeze that contained phosphates with the type of water they have in Europe, it may produce deposits that can settle in the cooling system and promote corrosion. However, in North America we do not have this type of water problem. Typical North American coolants have contained phosphates (which is part of the corrosion inhibitor package) for many years. Therefore, the question of phosphates is a non-issue here in North America. Prestone® Antifreeze/Coolant is completely safe for use in both foreign and domestic vehicles. "
Anyways, do your own research but I will be using prestone cor-guard in our 2014 hyundai. We also have a 2005 hyundai (original owner) and I have always used regular prestone with no issues. I have also used the same in my Toyota Tacoma and no issues ...
Thanks everyone for your help!
