Walmart and Valvoline
by Bullwinkle007. 01/22/19 09:10 PM
Getting Our Kicks On Route 66
by 2015_PSD. 01/22/19 08:40 PM
Uploading a short film clip from an IPhone.
by Snagglefoot. 01/22/19 07:52 PM
Purolator L34631 (torn media)
by LDM. 01/22/19 07:51 PM
THIS close to getting a VDB today at TPA
by 14Accent. 01/22/19 07:48 PM
Supco Appliance Parts.
by George7941. 01/22/19 07:36 PM
Unusual Jury summons.
by Chris142. 01/22/19 06:31 PM
Vibration feeling after new tires installed?
by MONKEYMAN. 01/22/19 05:51 PM
Sudden Shake - ‘18 Accord
by Throt. 01/22/19 05:43 PM
05 Ford 500 Intake hole - melted
by Geauxtiger. 01/22/19 05:41 PM
How's K&N 1004 on Kia/Hyundai GDI
by SlavaB. 01/22/19 05:18 PM
more PSD woes with cold weather
by Donald. 01/22/19 05:10 PM
Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
82 registered members (69GTX, AdRock, askani79705, asiancivicmaniac, aleneros, 9 invisible), 1,174 guests, and 41 spiders.
Topics297,006
Posts4,963,324
Members67,013
Most Online2,821
Jan 21st, 2019
CDN Tire "OEM" Brand Vehicle Specific Brake Fluid #4753554
05/10/18 08:50 PM
05/10/18 08:50 PM
Canada
nobb Offline OP
nobb  Offline OP
Canada
In the last few years I've noticed that Canadian Tire is starting to roll in their "OEM" brand of fluids. At first it was the formulated coolants to match brand specific chemistry and now most of the brake fluid selection is also "OEM" branded DOT 3 and 4 with vehicle specific branding. For DOT 3 alone, there's 5 different formulations:
http://www.canadiantire.ca/en/pdp/oem-pr...81914p.html#srp
http://www.canadiantire.ca/en/pdp/oem-dot-3-brake-fluid-asian-946-ml-0381915p.html#srp
http://www.canadiantire.ca/en/pdp/oem-do...81913p.html#srp
http://www.canadiantire.ca/en/pdp/oem-dot-3-brake-fluid-ford-500-degrees-946ml-0381928p.html#srp
I was not aware brake fluid would be necessary to have manufacture specific formulas. Does anyone have any idea what's the difference between these? Why would you not just purchase the one with the highest temperature rating (Super DOT 3)? It's interesting that the Super DOT 3 actually has a higher temperature rating than the DOT 4 stuff.
Re: CDN Tire "OEM" Brand Vehicle Specific Brake Fluid [Re: nobb] #4753593
05/10/18 09:36 PM
05/10/18 09:36 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
I suspect it might help them differentiate their product to convince people to buy their brake fluid from them. They certainly can't differentiate their product on a more palatable price. I get Castrol LMA DOT 4 at significantly cheaper than any of CT's offerings.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: CDN Tire "OEM" Brand Vehicle Specific Brake Fluid [Re: nobb] #4753619
05/10/18 10:05 PM
05/10/18 10:05 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
I've used the euro dot 3
The euro dot 4 is not super dot 4 so I had a feeling it is just marketing
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: CDN Tire "OEM" Brand Vehicle Specific Brake Fluid [Re: nobb] #4753761
05/11/18 05:04 AM
05/11/18 05:04 AM
Johnny2Bad Offline
Johnny2Bad  Offline
Wouldn't be the first time Canadian Tire used labelling to support a higher price. Let the nervous and clueless but it and buy whatever meets your manual's DOT requirements.
Remember to not mix DOT 5 (silicone) with DOT 3,4 and you're good. Note that there is such a thing as "better" brake fluid but unless you're racing or driving a high performance vehicle you probably don't need it. Motul brand is what everybody in that category buys.
Read the boiling temperatures on the label if you're faced with choices and care, ("wet" boiling temp is more important than "dry") but to be honest cheap DOT-compliant fluid and a 2-year full fluid change is better than adding expensive fluid and never doing so.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: CDN Tire "OEM" Brand Vehicle Specific Brake Fluid [Re: nobb] #4753952
05/11/18 08:09 AM
05/11/18 08:09 AM
Canada
Lolvoguy Offline
Lolvoguy  Offline
Canada
Didn't see any of the links, but if you can find 5.1, it's fully compatible with all other brake fluids except Dot 5.
http://www.epicbleedsolutions.com/resources/faq/difference-between-dot4-and-dot51-brake-fluid/
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: CDN Tire "OEM" Brand Vehicle Specific Brake Fluid [Re: nobb] #4753958
05/11/18 08:13 AM
05/11/18 08:13 AM
Canada
nobb Offline OP
nobb  Offline OP
Canada
Thanks for the replies. I am servicing a Ford, Dodge, Hyundai, and Toyota and was hoping to just buy one fluid in bulk. After some research I think I'll buy the Ford PM1C DOT 3 fluid online. It's only $5 per bottle @ RockAuto and has a 500F boiling point which is higher than most DOT 4s.
Re: CDN Tire "OEM" Brand Vehicle Specific Brake Fluid [Re: nobb] #4754209
05/11/18 12:11 PM
05/11/18 12:11 PM
California
nthach Offline
nthach  Offline
California
Unless you're buying CCI's fluid they supply Toyota/Honda/Nissan/Subaru and Gold Eagle/Excelda with, I don't think there's really a "true" OEM spec fluid. The Motorcraft HD DOT 3 fluid is liked by many for its high dry boiling point.
With that said, I prefer German made fluids - it seems like ATE and Pentosin have BASF and Clariant make their fluids and if they are good enough for the German OEMs, it's good enough for me. I wouldn't be surprised if Castrol GT LMA is also made by either one of those German chemical firms. ATE Type 200 or GT LMA were my old go-to fluids, I'm now switching over to ATE SL6.
Ford and GM are now calling for DOT 4LV fluid, and it's backwards compatible with DOT 3/4/5.1. ATE SL6 is a safe pick and reasonably priced.
Re: CDN Tire "OEM" Brand Vehicle Specific Brake Fluid [Re: nobb] #4754548
05/11/18 07:58 PM
05/11/18 07:58 PM
Garak Offline
Garak  Offline
That's reasonable. Maybe check if some local parts store where you can get a jobber rate deals with Wakefield. My Castrol LMA price is something like $4 a pint.
Re: CDN Tire "OEM" Brand Vehicle Specific Brake Fluid [Re: nobb] #4754584
05/11/18 08:31 PM
05/11/18 08:31 PM
VW Fanboy Island
VW Fanboy Island
I chose my brake fluid in the BITOG tradition of ignoring what the manufacturer suggests. I went with DOT 3 over DOT 4 for the moisture resistance.
