Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17‚ÄĚ Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
32 registered members (BlueOvalFitter, Blkstanger, Aichiguy, 97prizm, 74Widebody, 2 invisible), 1,046 guests, and 20 spiders.
Topics301,812
Posts5,203,170
Members70,784
Page 1 of 5 1 2 5
Fram XG12060 - GM 22psi spec Ultra coming soon! #4752965 05/10/18 11:17 AM
W
webfors Offline OP
W
Just heard from Motorking. The new 22psi spec ultra for GM spec'd vehicles will be available in the next 2 months. The part number will be XG12060.
17 Cadillac ATS 2.0T, Edge D1G2 5w30, Champion COS10590
17 Dodge GC, VWB 5w30, Mopar MO-349
18 DL1000XT, Valvoline Dino 20w50, Suzuki OEM OF
Small engines; RT5 10w30
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: webfors] #4752971 05/10/18 11:22 AM
4WD Offline
https://www.bobistheoilguy.com/forums/ubbthreads.php/ubb/showflat/Number/4750189/Searchpage/1/Main/288895/Words/Patman/Search/true/Re:_Wix_GM_Application/Filter_#Post4750189
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: webfors] #4752985 05/10/18 11:34 AM
A
Ag76 Offline
A
Apparently the XG12060 won't fit my two newer GM vehicles with the 5.3L engine, and the XG10575 doesn't meet the GM 22 psi bypass spec. I'd prefer to use an Ultra, but feel like I should stay with a filter that meets the GM recommended spec for the warranty. Does Fram have anything in the works for these vehicles?
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: Ag76] #4753015 05/10/18 12:10 PM
M
Motorking Offline
M
Actually it does fit your late model 5.3. Your vehicle uses 22mx1.5 thread size and has the same location for the o ring. This issue is complicated. The 10575 fits many Ford and FCA vehicles that have much lower bypass, that is why we cannot just change the valve in the 10575. The PH12060 was released with the 22 psi bypass for GM 4 cylinders and then GM changed requirements for V8's as well.
Jay Buckley
Motorking Automotive
[email protected]
248-808-4551
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: webfors] #4753040 05/10/18 12:27 PM
smithph Offline
This is targeted at the PF64 filter, correct? Are there plans to support the UPF64R filters in the future as there have been reports the bypass setting on the 64R is over 30psi?
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: webfors] #4753066 05/10/18 12:44 PM
P
Phishin Offline
P
So....Should I make sure I get 22psi bypass filters for my new Silverado 3500HD, which has the 6.0L gas engine?
2018 Chevy Silverado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: MaxLife 5w30 + Torco MPZ
2014 CR-V LX K24: M1 0w30
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: Phishin] #4753099 05/10/18 01:13 PM
W
webfors Offline OP
W
If under warranty, probably.
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: Motorking] #4753265 05/10/18 04:50 PM
O
oil_film_movies Offline
O
Just because something "fits" the space doesn't mean its right to use. And its not really complicated. Very simply, Fram has been crossing the UPF64R with their PH12060, which is wrong since the UPF64R has a 35 psi bypass and the PH12060 has a reduced 22 psi bypass.
Not complicated, just confused by Fram's (and some other aftermarket company's) insistence on the wrong look-ups in some applications. Just weird really.
Mabye Fram and a few others should clean up their act? There's an idea. Call out the right part for the job for a change.
Currently the only Fram filter you can get to replace a PF63E application is the HP19, a very good choice in construction & efficiency, a tad expensive and not at Walmart though.
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: oil_film_movies] #4753311 05/10/18 05:35 PM
smithph Offline
I have seen the 35psi quoted many times on many forums but have yet to see anyone post an email from ACDELCO confirming this, just some references to a non-ACDELCO site which listed a 35psi. Does anyone have confirmation directly from ACDELCO or GM that the UPF64R does in fact have a 35PSI bypass setting?
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: webfors] #4753323 05/10/18 05:46 PM
L
Linctex Offline
L
I think I would pay good money to see any kind of ACTUAL 35 psi bypass event.
......when pigs fly is my guess.
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: webfors] #4753345 05/10/18 06:04 PM
Snagglefoot Offline
If I may interject. The 6.0 is still a Gen IV engine and does not have the higher oil pressure system seen in the 5.3 liter (2014 +) which is a Gen V. You would not want to use the higher pressure bypass in this engine. However, the Fram filters that fit this engine still have the lower bypass pressure so you are fine with the short Fram 10060 or the longer Fram 10575 because they both have the lower bypass pressure. Eventually, there will be an upgraded 10575 probably with a new part number. It will be for 2014+ Gen V engines such as the 5.3.
Fram shows the current 10575 being for the Gen V engines but they are behind the 8 ball because they have not yet updated the bypass pressure to 22 psi. I understand they are working on it.
If you want the job done right......do it yourself.
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: smithph] #4753352 05/10/18 06:07 PM
Z
ZeeOSix Offline
Z
Good question ... I was wondering the same thing.
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: Snagglefoot] #4753506 05/10/18 08:05 PM
Snagglefoot Offline
Didnít read all of Webfors post. 12060 it is. I would have chosen 12575. Weíll have to see if itís long or short.
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: webfors] #4755319 05/12/18 06:53 PM
Snagglefoot Offline
Here is my latest experiment. I have a 2008 Chev Gen IV 6 liter. Instead of running the usual Fram 10060, I ran a Fram 10575, both as Fram Ultraís. Because both filters still have a 9-15 psi bypass setting , they work fine. What do I get? More filter cross section for the same price. Hereís how they look. Sorry for the poorly exposed photo.
10060
10575
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: ZeeOSix] #4777140 06/04/18 10:20 AM
smithph Offline
Well it's been a month. I think I will call BullS__t on the 35psi clams for a UPF64R. I called Delco and they would not confirm or deny the 35psi bypass setting and would not provide a UPF64R spec sheet. Without confirmation from the manufacture the 35PSI claim is just an internet rumor.
Fear, uncertainty and doubt are excuses to do nothing!
Page 1 of 5 1 2 5
