Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
120 registered members (2015_PSD, 87sammy, 2010Civic, 3311, 01rangerxl, 7 invisible), 1,794 guests, and 55 spiders.
Topics286,088
Posts4,902,367
Members67,560
Most Online2,967
Mar 10th, 2019
ZF8 Fluid #4752642
05/10/18 07:15 AM
05/10/18 07:15 AM
NH
stenerson Offline OP
NH
Bust bought a new Ram and was reading up on Fluid types. I assumed they still used ATF4. Just found out this 8 speed used a ZF8 fluid that's crazy expensive. Starting at 27 bucks a quart or so.
The good news is Ram says it's a life-time fluid and I'll never need to change it. (at least not till the warranty is up). LOL
Anyone here done this fluid change yet? No dip stick and a complex process from what I've seen.
2018 RAM 1500ST EXPRESS QUAD CAB 4X4 3.6 VVT 270 miles
2004 Dodge Ram 1500 SLT 4x4 5.7 Hemi 16,627k miles
2005 suburu outback 189k
2007 Hyundai Sonata 181K
Re: ZF8 Fluid [Re: stenerson] #4752652
05/10/18 07:27 AM
05/10/18 07:27 AM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
Google ZF8 Bob. There have been a few discussions on this. Our search function doesnít work well.
If you want the job done right......do it yourself.
Re: ZF8 Fluid [Re: Snagglefoot] #4752677
05/10/18 07:55 AM
05/10/18 07:55 AM
NH
NH
Thanks, will check it out.
Re: ZF8 Fluid [Re: stenerson] #4752772
05/10/18 09:26 AM
05/10/18 09:26 AM
new jersey
hemitruck Offline
hemitruck  Offline
new jersey
I am hoping there will be more after market fluid available when I change mine.
Re: ZF8 Fluid [Re: stenerson] #4752775
05/10/18 09:28 AM
05/10/18 09:28 AM
Nashville, TN via Memphis
john_pifer Offline
john_pifer  Offline
Lifetime fluid...LOL.
That's what Toyota said about my Tacoma (Aisin-Warner A750) when they came out. Then they revised it to 100K...then 60K.
I hit 200K on my truck a while back and just did my 2nd full fluid exchange myself. Same setup - no dipstick. There will be a procedure you can do on your Ram, most likely. It will probably be similar to my A750 - drain pan, refill, disconnect cooler line, start truck, let the amount you got from the pan pump out, refill pan, repeat until you've run however many quarts through to equal system capacity (for mine it's around 12 quarts). Then you'll need to get the fluid to a certain temp in order to check proper pan level (mine has a check plug - when fluid trickles out, you're at correct level). The dealer will use a scan tool plugged into the OBD receptacle that will tell them fluid temp. Doing it without that, on the Tacoma, requires using a wire to bridge 2 ports in the OBD receptacle. Then you move the shifter from neutral to drive several times, and, when the tranny fluid is in the required temp range, a light on the instrument cluster illuminates.
16 WRX - PPPP
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 208K
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: ZF8 Fluid [Re: john_pifer] #4752829
05/10/18 10:13 AM
05/10/18 10:13 AM
NH
NH
The dude in this video uses MaxLife on this 8speed tranny. The Valvoline site claims it's compatible.
2014 Ram 1500 ZF 8 Speed transmission fluid exchange
Re: ZF8 Fluid [Re: stenerson] #4752832
05/10/18 10:15 AM
05/10/18 10:15 AM
KY
MCompact Offline
MCompact  Offline
KY
Originally Posted By: stenerson
Just bought a new Ram and was reading up on Fluid types. I assumed they still used ATF4. Just found out this 8 speed used a ZF8 fluid that's crazy expensive. Starting at 27 bucks a quart or so.
I have a ZF 8HP45 in my 2 Series. It sees the road course and drag strip every now and then, so I'm changing it at 60,000 miles.
ZF states:
In case of above-average operating conditions, such as:
- frequent freeway driving in the upper speed range
- offensive, sporty driving style
- frequent trailer operation
it is recommended to refresh (change) the oil of the automatic transmission every 100,000 km or no later than after 8 years.
More information can be found here.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: ZF8 Fluid [Re: MCompact] #4752841
05/10/18 10:23 AM
05/10/18 10:23 AM
NH
NH
ZF states:
I'll probably change the pan (which has builtin filter) and fluid at 50K to get must of the break in sludge removed. Then just drain and fill after that.
Re: ZF8 Fluid [Re: stenerson] #4752852
05/10/18 10:30 AM
05/10/18 10:30 AM
USA
slacktide_bitog Offline
USA
You can use Maxlife with no problems smile
Re: ZF8 Fluid [Re: stenerson] #4752922
05/10/18 11:28 AM
05/10/18 11:28 AM
john_pifer Offline
john_pifer  Offline
That bottle he uses is a good idea. I've used a cheap Walmart made-in-China pump that makes a huge mess.
16 WRX - PPPP
Re: ZF8 Fluid [Re: stenerson] #4753095
05/10/18 02:10 PM
05/10/18 02:10 PM
California
Dave1027 Offline
Dave1027  Offline
California
I always use a cheap walmart garden sprayer for all my ATF changes. Works like a champ. I simply pump it a few pumps and let the air pressure push the fluid into the transmission. No tedious hand pumping.
Re: ZF8 Fluid [Re: stenerson] #4753373
05/10/18 07:34 PM
05/10/18 07:34 PM
NH
supton Offline
supton  Offline
NH
I'll have to remember that, a sprayer. I have one or two changes coming up. I did use a hose and a funnel on the truck, not sure which is easier.
2011 Toyota Camry, base, 2.5L/6MT, 179k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 146k, ours
1999 Toyota Camry LE, 2.2L/4AT, 202k, his
Re: ZF8 Fluid [Re: stenerson] #4753412
05/10/18 07:59 PM
05/10/18 07:59 PM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Or you can do what I did:
Get a cheap container (I use a 2.5 gallon gas can), thread in a barbed fitting, and use some nylon tubing and a valve.
I set it on the engine and let gravity do the work. Think I spent $15 at Lowe's.
"Zed's dead baby, Zed's dead."
Re: ZF8 Fluid [Re: rooflessVW] #4753543
05/10/18 09:40 PM
05/10/18 09:40 PM
CA
The Critic Offline
The Critic  Offline
CA
https://www.nationaltoolwarehouse.com/8-...ASABEgJH2fD_BwE
IMO these are well worth the investment for anyone, even DIY'ers. I have 3 of them and they are incredibly useful.
2011 Toyota Prius 1.8L - 185K - SuperTech Dexos Full Syn 0W-20
2007 Honda Accord 2.4 - 135K - Mobil 1 EP HM 5W-30
Re: ZF8 Fluid [Re: Dave1027] #4753575
05/10/18 10:13 PM
05/10/18 10:13 PM
Cool idea. cool
