Walmart and Valvoline
by Bullwinkle007. 01/22/19 09:10 PM
Getting Our Kicks On Route 66
by 2015_PSD. 01/22/19 08:40 PM
Uploading a short film clip from an IPhone.
by Snagglefoot. 01/22/19 07:52 PM
Purolator L34631 (torn media)
by LDM. 01/22/19 07:51 PM
THIS close to getting a VDB today at TPA
by 14Accent. 01/22/19 07:48 PM
Supco Appliance Parts.
by George7941. 01/22/19 07:36 PM
Unusual Jury summons.
by Chris142. 01/22/19 06:31 PM
Vibration feeling after new tires installed?
by MONKEYMAN. 01/22/19 05:51 PM
Sudden Shake - ‘18 Accord
by Throt. 01/22/19 05:43 PM
05 Ford 500 Intake hole - melted
by Geauxtiger. 01/22/19 05:41 PM
How's K&N 1004 on Kia/Hyundai GDI
by SlavaB. 01/22/19 05:18 PM
more PSD woes with cold weather
by Donald. 01/22/19 05:10 PM
Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
52 registered members (bbhero, AdRock, bdcardinal, 209paulc, bernardch, 7 invisible), 1,055 guests, and 44 spiders.
Topics297,006
Posts4,963,339
Members67,013
Most Online2,821
Jan 21st, 2019
ABS Sensor Replacement #4752485
05/09/18 09:37 PM
05/09/18 09:37 PM
New Jersey
JHZR2 Offline OP
JHZR2  Offline OP
New Jersey
I'm a bit annoyed, but my BMW ABS sensor seems to be busted.
Speedometer had a glitch, then got an ABS light. Went away when I turned the car off and restarted. Showed up about 190 miles later. Codes indicate left rear.
Got an OEM part, ready to do it. $40 or so.
An online DIY shows it's just held in with a single screw. Not much to it. But it's stated to coat with a long life grease.
That means that whatever I remove also had a long life grease.
Ive never replaced a sensor before. I'm not that concerned, but I seem to recall that the abs sensor magnets on a hub should never be touched, and that contact with them or getting dirt on them can cause them to not work. That may not be true or lost in translation/my memory.
So what should I use to clean the spot wher the sensor is mounted? Paper, popsicle stick, screwdriver, etc? Are chemicals Ok? Can you go too deep and damage the hub, magnets, bearings, etc?
Once clean, I'll coat the sensor lightly and install. How much is too much? Coat the whole thing or just the sensor shaft or top (I.e. Use the grease more as anti seize or anti-rust at the top?).
Is dielectric grease ok for the other end?
DIY that's very similar:
https://www.pelicanparts.com/BMW/techart...Replacement.htm
Thanks!
Re: ABS Sensor Replacement [Re: JHZR2] #4752565
05/10/18 02:08 AM
05/10/18 02:08 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Usually you get info about a distance between a sensor and the hub via google/autodata/....
Use ceramic grease/paste to lubricate...or regular lithium grease you have in your garage...avoid any grease with metal parts in it (copper grease or antisieze with zinc etc) because it can interfere with sensor readings... Brakecleaner/wd40 /... For cleaning
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: ABS Sensor Replacement [Re: JHZR2] #4752592
05/10/18 04:45 AM
05/10/18 04:45 AM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Are you supposed to coat the screw with long life grease or the sensor or both?
In my 98 sienna the screw head snapped flush. Had to be drilled out. For the screw I used anti seize. Sensor was left dry.
I would make sure you use plenty of penetrating fluid before trying to remove it and use a wire brush as well to knock the corrosion off.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: ABS Sensor Replacement [Re: JHZR2] #4752595
05/10/18 04:54 AM
05/10/18 04:54 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
If the car has seen winter and salt it can be a nightmare but hopefully not. Soak it down good with penetrant a couple of days before as cheap insurance.
Once the bolt is out try and wiggle it before prying on it, if it moves go ahead and pull it, if it wont move try moving it left to right with pliers and pry it up at the same time, if it breaks you have a bit of a job ahead of you. If this happens post or PM me.
On these I use marine never seize or Green Grease, the stuff is so thick and tacky and waterproof, wear nitrile gloves its a bugger to get off but it works great.
Don't worry about metal anti seize you can also use it just don't get any on the magnet tip. The sensor body is insulated and in a metal housing anyway so it doesn't make any difference.
https://www.amazon.com/Marine-Grade-Anti...&dpSrc=srch
https://shop.advanceautoparts.com/p/gree...mp;gclsrc=aw.ds
Re: ABS Sensor Replacement [Re: Kamele0N] #4752646
05/10/18 06:20 AM
05/10/18 06:20 AM
New Jersey
JHZR2 Offline OP
JHZR2  Offline OP
New Jersey
I think depth is set by the sensor body flange:
For cleaning, it's safe to assume that whatever flows through won't harm the magnets and whatnot on the other end of the hole? Id think it all has to be pretty well sealed given exposure to road water, but Ive not looked in detail yet.
Re: ABS Sensor Replacement [Re: Trav] #4752650
05/10/18 06:23 AM
05/10/18 06:23 AM
New Jersey
JHZR2 Offline OP
JHZR2  Offline OP
New Jersey
Fortunately the car is not a winter driver, and I have both moly AS and tacky waterproof grease. Planning to use Schaeffers 238 on the body and a bit of marine AS on the bolt.
Thanks!
Re: ABS Sensor Replacement [Re: JHZR2] #4752660
05/10/18 06:40 AM
05/10/18 06:40 AM
NH
supton Offline
supton  Offline
NH
Might want to check the module, but I believe the magnet is inside the module you are swapping (touch the sensor against something ferrous, like the fridge). The ABS tone ring is ferrous and is used to direct the magnetic field through the sensor--the sensor is backbiased. I have a tough time believing that grease on the sensor will do anything--it would have to be ferrous to have an impact.
I'd be more worried about the sensor sitting out from the hub (due to rust buildup) and placing too much distance between sensor and target.
2011 Toyota Camry, base, 2.5L/6MT, 176k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 145k, ours
1999 Toyota Camry LE, 2.2L/4AT, 199k, his
Re: ABS Sensor Replacement [Re: JHZR2] #4752691
05/10/18 07:08 AM
05/10/18 07:08 AM
Trav Offline
Trav  Offline
It should be no problem being a summer car. There is no adjustment on these where it sits on the flange is the correct distance.
Re: ABS Sensor Replacement [Re: JHZR2] #4752762
05/10/18 08:13 AM
05/10/18 08:13 AM
New Jersey
JHZR2 Offline OP
JHZR2  Offline OP
New Jersey
How much should I try to clean the hole??
Thanks!!
Re: ABS Sensor Replacement [Re: supton] #4752932
05/10/18 10:38 AM
05/10/18 10:38 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I saw a YouTube video of that exact issue .
Wyr
God bless
Re: ABS Sensor Replacement [Re: WyrTwister] #4752938
05/10/18 10:45 AM
05/10/18 10:45 AM
NH
supton Offline
supton  Offline
NH
Want to say it was GM & some calipers on their trucks with that issue?
Re: ABS Sensor Replacement [Re: JHZR2] #4753003
05/10/18 11:59 AM
05/10/18 11:59 AM
Trav Offline
Trav  Offline
Thanks!!
Just clean it up a lightly with 400 then blow it out with some brake cleaner.
Re: ABS Sensor Replacement [Re: supton] #4753264
05/10/18 04:47 PM
05/10/18 04:47 PM
New Jersey
JHZR2 Offline OP
JHZR2  Offline OP
New Jersey
Fortunately as soon as I did about 3 mph, all lights went out. All seems well now.
I was fearful that a car that sits a lot outdoors could have had water seepage affect the bearing and shift the position of the rings on the hub. I had read of that happening.
Fortunately an easy success.
Re: ABS Sensor Replacement [Re: JHZR2] #4753338
05/10/18 05:56 PM
05/10/18 05:56 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
In the video I refereed to , I think " rust jacking " was the problem . The video also stated , in the rust / salt belt , it was common to destroy the sensor while getting it out .
Wyr
God bless
Re: ABS Sensor Replacement [Re: JHZR2] #4753348
05/10/18 06:06 PM
05/10/18 06:06 PM
Trav Offline
Trav  Offline
Nice when the job goes easy. The ones I do are mostly are ones that are rotted tight in there and the bolt breaks 1/3 of the time.
