Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
97 registered members (advocate, 69Torino, 53' Stude, 69GTX, A310, 4WD, 12 invisible), 1,771 guests, and 42 spiders.
Topics296,896
Posts4,961,146
Members66,997
Most Online2,688
Jan 19th, 2019
Is Euro 5W30 for Diesel Resource Conserving Oil? #4752443
05/09/18 08:54 PM
05/09/18 08:54 PM
MURICA
maverickfhs Offline OP
MURICA
So I was browsing and reading for oils, good for motorcycles and all.
Came across this thread: http://www.r1messagenet.com/forums/5-r1-maintenance-technical/4-definitive-oil-thread.html
and http://www.r1-forum.com/forums/16-racers-corner/370873-recommended-oil-racing-5w30-10w40-2.html
Where they mention to use 5W30, without any issues and it might be better.
Question is, is Euro formulated for Diesel vehicles energy conserving? Also, would it be good in a motorcycle with wet clutch? Currently, I am using Rotella 15W40 and it's running flawlessly.
Why I ask, because I have about 25 quarts in stash, so why not use in a Civic and motorcycle together smile
I don't have access to oil bottle and will verify from it too. Thanks for the input and help.
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
Re: Is Euro 5W30 for Diesel Resource Conserving Oil? [Re: maverickfhs] #4752460
05/09/18 09:17 PM
05/09/18 09:17 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
I don't know about the wet clutch, but most Euro diesel oils, be they C3, A3/B4, or E6, E7, E9, will not be resource conserving, since all those specifications have elevated HTHS.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Is Euro 5W30 for Diesel Resource Conserving Oil? [Re: Garak] #4752474
05/09/18 09:25 PM
05/09/18 09:25 PM
MURICA
MURICA
Thank you, is this 5W30 more close to 5W40, being on thick side or no?
Re: Is Euro 5W30 for Diesel Resource Conserving Oil? [Re: maverickfhs] #4752508
05/09/18 10:03 PM
05/09/18 10:03 PM
Garak Offline
Garak  Offline
Yes, all those examples will have an HTHS around 3.5 or greater, by virtue of the specs they meet. The same applies to the Rotella T6 5w-30 I'm running now, which has a higher HTHS than say the ordinary ILSAC 5w-30.
I'm sure some of them would be suitable for motorcycle use, but trying to figure out which would be best, particularly from a friction modification standpoint, is another matter. wink
Re: Is Euro 5W30 for Diesel Resource Conserving Oil? [Re: Garak] #4752674
05/10/18 06:53 AM
05/10/18 06:53 AM
MURICA
MURICA
Does it mean I stay away from it and stick to Delvac and Rotella sort oils?
Re: Is Euro 5W30 for Diesel Resource Conserving Oil? [Re: maverickfhs] #4752846
05/10/18 09:27 AM
05/10/18 09:27 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
The 5W-30 is energy conserving compared to a 5W-40 !!
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Is Euro 5W30 for Diesel Resource Conserving Oil? [Re: Garak] #4752859
05/10/18 09:34 AM
05/10/18 09:34 AM
Great Lakes
Quattro Pete Offline
Great Lakes
Yup. Just because it's not resource conserving does not necessarily mean it contains no friction modifiers.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Is Euro 5W30 for Diesel Resource Conserving Oil? [Re: Quattro Pete] #4752863
05/10/18 09:35 AM
05/10/18 09:35 AM
MURICA
MURICA
Yup. Just because it's not resource conserving doesn't not necessarily mean it doesn't contain any friction modifiers.
Does anyone know if friction modifiers are going to be less or same compared to any other Diesel oil, like Delvac/Rotella 5W40?
Re: Is Euro 5W30 for Diesel Resource Conserving Oil? [Re: Quattro Pete] #4752909
05/10/18 10:17 AM
05/10/18 10:17 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
This! 5Wxy oils here ARE fuel conserving...but not in CAFE way... Look up for an ACEA descriptions on A3/B4/Cx oils
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Is Euro 5W30 for Diesel Resource Conserving Oil? [Re: maverickfhs] #4752942
05/10/18 10:51 AM
05/10/18 10:51 AM
Finland
Bjornviken Offline
Bjornviken  Offline
Finland
Use castrol motorcykle oil
Re: Is Euro 5W30 for Diesel Resource Conserving Oil? [Re: maverickfhs] #4753433
05/10/18 07:10 PM
05/10/18 07:10 PM
Garak Offline
Garak  Offline
If it were me, yes, I would likely do that. Now, in your automotive applications, I'd have no problem with a C3 oil, at least with conservative OCIs; it would at least be very safe.
The Rotella that had the appropriate JASO spec would still be my first choice, aside from a motorcycle specific oil, because we all know how expensive those can be. Viscometrically, there is nothing wrong with the European choices, it's just the friction modification aspect, in my view. I think an A3/B3 A3/B4 oil would be dandy in a lot of ways for motorcycles, assuming compatibility from the friction modification standpoint, and we cannot assume that compatibility.
Re: Is Euro 5W30 for Diesel Resource Conserving Oil? [Re: maverickfhs] #4753693
05/11/18 02:25 AM
05/11/18 02:25 AM
Finland
Bjornviken Offline
Bjornviken  Offline
Finland
Use recommended viscosity and spec. Putting mid saps oil in a motorcykel, i would never do that.
i recommend Castrol power 1. Did work nice in my bmw s1000rr
