Are all 9012 bulbs HIR2?
by dvancleve - 01/18/20 03:30 PM
Ariens L-3 Synthetic Severe-Duty Gear Lube
by Astro_Guy - 01/18/20 02:04 PM
LSx Crank lock
by P10crew - 01/18/20 02:03 PM
ST9688 gasket
by Farnsworth - 01/18/20 01:26 PM
From my stash
by Fattylocks - 01/18/20 12:48 PM
Toyota to Mexico
by kstanf150 - 01/18/20 12:37 PM
Final Sludge Cleanup, HDEO - Diesel ??
by jssaab - 01/18/20 12:31 PM
A good cabin filter
by NH73 - 01/18/20 10:36 AM
K&N cut open.
by laserred96gt - 01/18/20 10:25 AM
Toyota Oem filter mileage
by Bettez88 - 01/18/20 10:22 AM
OCI, Owners manual versus oil Mfg.
by VQLT - 01/18/20 10:06 AM
MacBook Pro to Microsoft Surface
by Kira - 01/18/20 09:53 AM
Ford 5R55E Auxiliary Transmission Filter
by benjamming - 01/18/20 09:33 AM
Do all synthetic oils act as a cleaner?
by Loobit - 01/18/20 08:26 AM
Mobil 1 ESP now sold in 5qt jugs
by Patman - 01/18/20 08:12 AM
Mobil 1 Extended Performance Oil Filters
by jrommelt - 01/18/20 08:08 AM
These the same?
by Bettez88 - 01/18/20 06:53 AM
MaxLife SB 10w40 on Sale
by Mad_Hatter - 01/18/20 04:27 AM
Bebo77, 2EHA, jonnyb433, kzbd, 54Robert
70465 Registered Users
80 registered members (69Torino, 2oldtommy, 14Accent, 77GrandPrix, 2015_PSD, 8 invisible), 2,275 guests, and 17 spiders.
Topics300,290
Posts5,172,566
Members70,465
Most Online3,728
Jan 11th, 2020
Page 1 of 3 1 2 3
GM 2.8 Duramax - Delvac ESP 5w40 CJ-4 - 5300 miles #4752118 05/09/18 02:41 PM
CleverUserName Offline OP
This is my 3rd oil change and 2nd run using some of the old PAO based CJ-4 Delvac ESP I got in Ď15 for $8 a gallon after MIR.
Vehicle is a 2017 GMC Canyon 4x4 CCLB w/ 2.8 duramax.
70% freeway / 30% city. 11,700 miles on truck and 5,300 on oil. Normal driving, sometimes with a payload of less than 1,000 #. Sometimes I take trips to the mountains, switchbacks and steep grades. I use the exhaust brake and manual shift the transmission to engine brake on these drives, about once per month. This is the hardest itís been driven, no towing yet.
Fueled exclusively with HVO dosed with Stanadyne PF @ 500:1 ratio. Changed oil early this time cause I had fuel dilution in my previous UOA
FD looks like itís under control now.
Refilled with RLI BioSyn Homebrew 10w40. There is a thread on this oil I made in the VOA sub-forum.
Overall the D1 ESP looks like it did really well, however there was some valvetrain noise at startup which I didnít like which is why the BioSyn went in this time.
Re: GM 2.8 Duramax - Delvac ESP 5w40 CJ-4 - 5300 miles [Re: CleverUserName] #4752123 05/09/18 02:43 PM
dnewton3 Offline
Global Moderator
Global Moderator
very nice for such a young engine; break in going well.
you can go much further on the lube than 5k miles ...
are you following the IOLM?
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: GM 2.8 Duramax - Delvac ESP 5w40 CJ-4 - 5300 miles [Re: dnewton3] #4752129 05/09/18 02:53 PM
No IOLM isnít very intelligent in the truck. I think it said ~ 30 ish % when I changed it. Changed early due to the FD issue and I didnt want any stanadyne in the crankcase.
I think you could go more than 10k on this oil, maybe 15k which is two of the recommended OCIs, there is still lots of TBN left.
Re: GM 2.8 Duramax - Delvac ESP 5w40 CJ-4 - 5300 miles [Re: CleverUserName] #4752134 05/09/18 02:58 PM
Shannow Offline
If it's the same OLM as in my 2016 Colorado, it changes recommendation massively depending on driving style.
Re: GM 2.8 Duramax - Delvac ESP 5w40 CJ-4 - 5300 miles [Re: Shannow] #4752149 05/09/18 03:10 PM
That may be the case, however it is calibrated for a Dexos 2 oil, which isnít what Iím using. With a real HDEO like this D1, I believe you could go much longer than what it says @ 0%.
Re: GM 2.8 Duramax - Delvac ESP 5w40 CJ-4 - 5300 miles [Re: CleverUserName] #4754726 05/12/18 01:54 AM
E
edyvw Offline
E
Did you take down DPF? If not, this oil will damage DPF much faster then lower SAPS oils like Mobil1 5W30 ESP.
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: GM 2.8 Duramax - Delvac ESP 5w40 CJ-4 - 5300 miles [Re: edyvw] #4754730 05/12/18 02:05 AM
Nope emissions system is fully intact and under warranty. It will not damage the DPF. The sulfated ash value is only 25% higher with CJ-4 oil vs. Dexos 2. Oil related Ash loading to the DPF is very minor unless your burn oil or have leaking turbo seals. It is insignificant.
The extra P may have an effect on the SCR system but it would take many miles and years for that to happen. I don't believe it's a real issue if you use oils with low NOACK and/or install a catch can.
I'd rather protect my engine with a quality oil then use a Mid-saps offering or Dexos 2.
Thanks for your concern.
Re: GM 2.8 Duramax - Delvac ESP 5w40 CJ-4 - 5300 miles [Re: CleverUserName] #4756463 05/14/18 02:15 AM
E
edyvw Offline
E
So Delvac ESP is quality oil, but Mid-SAPS and Low-SAPS are not? Geez.
Well it is GM, it might need all possible protection. Others just make engines that can last longer, even on Mid-SAPS or Low-SAPS I guess.
Re: GM 2.8 Duramax - Delvac ESP 5w40 CJ-4 - 5300 miles [Re: edyvw] #4756476 05/14/18 03:21 AM
Actually, if you've seen some of the UOAs from this new engine from folks posted on the forums using C3 or Dexos 2 oils, you'd see how much of a difference my last 2 analysis are from the norm. I've seen reports from Amsoil AEL, Castrol, AcDelco, Total Quartz Ineo and PP Euro L among others and none of them have wear numbers like I'm seeing with CJ-4 ESP. Not even close. There is clearly a difference using a "real" low-ash HDEO.
And FYI, GM Duramax Diesels are excellent products, including this new 2.8. The 6.6 and Allison is the best powertrain available in light duty trucks. GM was also the first to pioneer the "9th Injector" for DPF regeneration. They have their $hit together as far as engineering goes in these applications.
GM cars do suck, I'm not going to lie about that. However their trucks/vans and commercial vehicles are the best in class.
Re: GM 2.8 Duramax - Delvac ESP 5w40 CJ-4 - 5300 miles [Re: CleverUserName] #4756668 05/14/18 07:46 AM
M
MichaelArch Offline
M
I'm thinking of doing the same thing. Did your regens shorten? Mine come in around 250 miles every time. Just wondering if this affects regens in any way. I also installed a provent and have been pulling a fair amount of oil out of it. Thanks for any insight!
Michael
Re: GM 2.8 Duramax - Delvac ESP 5w40 CJ-4 - 5300 miles [Re: CleverUserName] #4757060 05/14/18 01:55 PM
E
edyvw Offline
E
So are you saying all those small diesels that are doing hundreds of thousands of miles in Europe running on C3 are bad? IDK, my brother has fleet of VW's, PSA cars, all diesels in business he owns in Europe, and they all racking 400-500,000 miles on C3 oils. But apparently, Duramax cannot. And as far as I know, 2.8ltr is VM engine. Nothing wrong with them, I had them before. Though considering issues with V6 in FCA products, it could be that heavier oils and higher SPAS can hide some engineering issues.
Re: GM 2.8 Duramax - Delvac ESP 5w40 CJ-4 - 5300 miles [Re: CleverUserName] #4759378 05/16/18 11:59 PM
danielLD Offline
I would mention, that test was performed on a Spectro machine, probably on either the Micro or Minilab.
They never get fuel dilution correct, on these machines as they are using IR signatures for the reading. If the FD in real life is over 5%, then it will begin to pick it up to a degree.
You might consider a more accurate testing source in the future to see the true FD %.
I think a lot of people don't understand the Spectro machines are made to be accurate but to a degree and they're primarily meant to be portable usable in the roughest situations, they are the Toughbook of oil analysis. For example, a Navy SDV(seal delivery vehicle) where the primary concern is will it blow up on this mission or not. Where as for something like this truck, you're looking at making changes to the regime based on accuracy, I doubt you're worried about it exploding.
Also, it takes the Navy 4-5 weeks to get oil samples to the lab! So they use 2 sets of samples, the first to tell them on site if the machine is in imminent danger and the second to the real lab to fine tune the machine.
Shell does the same thing for Ferrari.
Just something to think about for next time.
Re: GM 2.8 Duramax - Delvac ESP 5w40 CJ-4 - 5300 miles [Re: CleverUserName] #4759396 05/17/18 02:18 AM
Shannow Offline
Yeah, Italian firm VM Motori did a pretty good job eh ?
18,000+km on my Colorado 2.8 and the regen light hasn't come on once.
Re: GM 2.8 Duramax - Delvac ESP 5w40 CJ-4 - 5300 miles [Re: Shannow] #4760140 05/17/18 03:56 PM
M
MichaelArch Offline
M
Thank you! And this is with an HDEO? Which are you using? Thanks again!
Re: GM 2.8 Duramax - Delvac ESP 5w40 CJ-4 - 5300 miles [Re: MichaelArch] #4760530 05/18/18 02:18 AM
Michael
Hi Michael,
Switching to an HDEO will not have any measurable effect on your regen frequency or interval.
Fuel quality, engine load and driving style are the biggest factors in determining your soot loading to the DPF.
You should try using a quality fuel additive that boosts cetane to 50-55 CN and/or contains catalysts to enhance combustion and reduce smoke. It may also give you a couple extra MPGs as well.
There is also a aftermarket tune for the 2.8 Duramax which reduces EGR flow, and fueling. This tune will also reduce your regen interval as less soot is generated.
Page 1 of 3 1 2 3
