Walmart and Valvoline
by Bullwinkle007. 01/22/19 09:10 PM
Getting Our Kicks On Route 66
by 2015_PSD. 01/22/19 08:40 PM
Uploading a short film clip from an IPhone.
by Snagglefoot. 01/22/19 07:52 PM
Purolator L34631 (torn media)
by LDM. 01/22/19 07:51 PM
THIS close to getting a VDB today at TPA
by 14Accent. 01/22/19 07:48 PM
Supco Appliance Parts.
by George7941. 01/22/19 07:36 PM
Unusual Jury summons.
by Chris142. 01/22/19 06:31 PM
Vibration feeling after new tires installed?
by MONKEYMAN. 01/22/19 05:51 PM
Sudden Shake - ‚Äė18 Accord
by Throt. 01/22/19 05:43 PM
05 Ford 500 Intake hole - melted
by Geauxtiger. 01/22/19 05:41 PM
How's K&N 1004 on Kia/Hyundai GDI
by SlavaB. 01/22/19 05:18 PM
more PSD woes with cold weather
by Donald. 01/22/19 05:10 PM
Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
91 registered members (2015_PSD, Aero540T, AdditiveOCD, 77GrandPrix, 928, 2004tdigls, 8 invisible), 1,369 guests, and 41 spiders.
Topics297,006
Posts4,963,319
Members67,013
Most Online2,821
Jan 21st, 2019
ACEA C3 / LL-04 oil comparison table (I got bored) #4752076
05/09/18 01:42 PM
05/09/18 01:42 PM
Oregon
1JZ_E46 Offline OP
1JZ_E46  Offline OP
Oregon
I'm an oil nerd. I admit it. Considering moving to a C3 / LL-04 oil to limit additives the phosphorous build-up in my cats (I burn about a quart every 2-2,500k). These are all U.S. available options. A few standout (Ravenol HLS, M1 ESP, INEO Long Life). Also really like PP Euro L because of its GTL base (and on the shelf at wallyworld).
BTW, I am on a 5k OCI, so not worried about the low TBNs and U.S. gasoline (which is trending in the right direction).
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: EDGE 0W-30
Re: ACEA C3 / LL-04 oil comparison table (I got bored) [Re: 1JZ_E46] #4752091
05/09/18 01:59 PM
05/09/18 01:59 PM
Great Lakes
Quattro Pete Offline
Great Lakes
Is the Edge C3 available in the US?
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: ACEA C3 / LL-04 oil comparison table (I got bored) [Re: Quattro Pete] #4752096
05/09/18 02:03 PM
05/09/18 02:03 PM
Oregon
1JZ_E46 Offline OP
1JZ_E46  Offline OP
Oregon
Yep. $36 on Amazon for a 5 quart jug. Flashpoint has me concerned though...
Re: ACEA C3 / LL-04 oil comparison table (I got bored) [Re: 1JZ_E46] #4752104
05/09/18 02:17 PM
05/09/18 02:17 PM
Great Lakes
Great Lakes
Oh, it's the 5w-30. I was thinking it was the 0w-30 C3 that's available in Europe.
Re: ACEA C3 / LL-04 oil comparison table (I got bored) [Re: 1JZ_E46] #4752228
05/09/18 04:47 PM
05/09/18 04:47 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
As far as I remember Castrol uses different methodology when it comes to flash point. Also, heavy PAO based oils are not having high flash point. Not sure is 5W30 C3 heavy in PAO (I would say not).
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: ACEA C3 / LL-04 oil comparison table (I got bored) [Re: edyvw] #4752244
05/09/18 05:04 PM
05/09/18 05:04 PM
Oregon
1JZ_E46 Offline OP
1JZ_E46  Offline OP
Oregon
Yeah, you may be right. It just looks way out of line. I also doubt thereís any PAO. Ravenol HLS looks to be the only PAO one. Makes sense given its price. $$$
Re: ACEA C3 / LL-04 oil comparison table (I got bored) [Re: 1JZ_E46] #4752318
05/09/18 06:17 PM
05/09/18 06:17 PM
pa
benjy Offline
benjy  Offline
pa
looked on the Ravenol site, some pretty "serious" oils, but as noted serious prices!! cheap is not usually good + good is not cheap, but for many its good enough for a decent cost!!
Re: ACEA C3 / LL-04 oil comparison table (I got bored) [Re: 1JZ_E46] #4752325
05/09/18 06:21 PM
05/09/18 06:21 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
There has to be some PAO there.
Check ASTM methodology on Castrol 5W30 C3 and Mobil1 5W30 ESp.
Re: ACEA C3 / LL-04 oil comparison table (I got bored) [Re: edyvw] #4752348
05/09/18 06:48 PM
05/09/18 06:48 PM
Oregon
1JZ_E46 Offline OP
1JZ_E46  Offline OP
Oregon
Castrol is D93 and M1 ESP is D92 and the others are D92, however Pennzoil is also D93. Means itís probably right up there with ESP under D92.
Re: ACEA C3 / LL-04 oil comparison table (I got bored) [Re: 1JZ_E46] #4752547
05/09/18 11:21 PM
05/09/18 11:21 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
It has all the approvals, would not sweat it out.
Re: ACEA C3 / LL-04 oil comparison table (I got bored) [Re: 1JZ_E46] #4752760
05/10/18 08:12 AM
05/10/18 08:12 AM
Chicago
Fraser434 Offline
Fraser434  Offline
Chicago
When the Ecodiesel had the MS11106 oil spec (before it changed to CJ4) the best UOA results I saw came from Mobil1 ESP 5W30, only C3 type oil with moly in the additives.
Re: ACEA C3 / LL-04 oil comparison table (I got bored) [Re: 1JZ_E46] #4752940
05/10/18 10:50 AM
05/10/18 10:50 AM
Chicago / IN
vinu_neuro Offline
vinu_neuro  Offline
Chicago / IN
What's D92 and D93?
Re: ACEA C3 / LL-04 oil comparison table (I got bored) [Re: vinu_neuro] #4752959
05/10/18 11:13 AM
05/10/18 11:13 AM
Great Lakes
Great Lakes
Originally Posted By: vinu_neuro
What's D92 and D93?
Different standard for measuring flash point...
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=761083
Re: ACEA C3 / LL-04 oil comparison table (I got bored) [Re: 1JZ_E46] #4753033
05/10/18 12:21 PM
05/10/18 12:21 PM
Oregon
1JZ_E46 Offline OP
1JZ_E46  Offline OP
Oregon
If I do choose to use a C3/LL-04 oil (will be running a fill of M1 10W-30 high mileage next OCI to see how that does), it will be Pennzoil Platinum Euro L. It's a near 100% GTL based oil (per its SDS), has the right certs, impressive specs, and is available down the street from me for $27 (pre-rebate) per 5qt jug. Looking at a VOA of it, starting TBN is around 7.0 and seems to hold up well in the U.S. (drops to around 3 in 5k miles). After a rebate, I can still keep my oil changes to ~$50 (9qt sump).
Re: ACEA C3 / LL-04 oil comparison table (I got bored) [Re: 1JZ_E46] #4753393
05/10/18 06:42 PM
05/10/18 06:42 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
That is a pretty respectable price, to say the least!
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
