Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
Starter cross reference?
by dlundblad. 01/22/19 05:11 AM
Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
How cold is it? (Humor)
by StevieC. 01/21/19 07:13 PM
Slight performance decrease
by A_User55555. 01/21/19 06:54 PM
Binco, Coolbreez1973, jmcast1127, DF8005, FT86dude11
67009 Registered Users
107 registered members (4WD, 2015_PSD, 53' Stude, AmoryBlaine, Arctic388, 14 invisible), 1,845 guests, and 38 spiders.
Topics296,966
Posts4,962,564
Members67,009
Most Online2,821
Yesterday at 01:32 PM
Towing RWD Manual Tranny Trucks. #4752003
05/09/18 11:43 AM
05/09/18 11:43 AM
Toronto, Canada
George7941 Offline OP
Toronto, Canada
--with the rear wheels down. Any time a two company tows a medium duty truck with the rear wheels down, the tow truck driver disconnects the rear driveshaft. Would it not be easier, for short tows of under a few miles, to leave the driveshaft in place, engage top gear, and depress the clutch pedal all the way with a pedal depressor? Countershaft turns and tranny internals get lubricated. The clutch release bearing is very beefy on these trucks and should be able to handle the clutch load for about fifteen minutes.
Sure beats lying under the truck by the side of a busy highway disconnecting the driveshaft.
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Towing RWD Manual Tranny Trucks. [Re: George7941] #4752008
05/09/18 11:51 AM
05/09/18 11:51 AM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
I would assume they are trying to not damage their customer's gear as much as possible. There is no liability when you pull the driveshaft.
What happens if the release bearing is on it's last legs and that does it in? The off chance the depressor is not set correctly or gets knocked off? Different procedures for manuals v autos? An excellent way for an inexperienced employee to cause catastrophic damage.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Towing RWD Manual Tranny Trucks. [Re: George7941] #4752017
05/09/18 12:05 PM
05/09/18 12:05 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Plus they get to charge more to pull the driveshaft.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Towing RWD Manual Tranny Trucks. [Re: George7941] #4752029
05/09/18 12:24 PM
05/09/18 12:24 PM
The Canyons
02SE Offline
02SE  Offline
The Canyons
Disconnecting the driveshaft is quick and removes any possibility of damage if your scenario goes wrong.
Re: Towing RWD Manual Tranny Trucks. [Re: George7941] #4752313
05/09/18 06:13 PM
05/09/18 06:13 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Broadly speaking it's about distance to be towed; if it's short (a few miles) it's OK to tow in Neutral Gear, clutch engaged. If the distance is for any distance, say, beyond 5 miles or so, disconnect the driveshaft.
I would guess that the owner's manual for the towed vehicle almost certainly addresses the issue, refer to it and follow the recommendations.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Towing RWD Manual Tranny Trucks. [Re: George7941] #4752472
05/09/18 09:24 PM
05/09/18 09:24 PM
Detroit
Kurtatron Offline
Kurtatron  Offline
Detroit
Why is it bad to tow in neutral gear? I never heard of such a thing as towing in neutral might cause damage to a red vehicle. What will happen for extended towing?
Re: Towing RWD Manual Tranny Trucks. [Re: George7941] #4752590
05/10/18 04:42 AM
05/10/18 04:42 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
Just put it in neutral. Anyone who drives a manual knows this
Cable ties should hold it
Re: Towing RWD Manual Tranny Trucks. [Re: Olas] #4752644
05/10/18 06:17 AM
05/10/18 06:17 AM
Toronto, Canada
Toronto, Canada
No, any one who drives a manual DOES NOT know this.
When the counter shaft rotates the gears on the counter shaft, which are submerged in oil, transfer the oil to the mating gears on the output shaft and this oil lubricates the gears and the bearings on the output shaft. In neutral none of the gears on the output shaft are locked on to the output shaft, so none of the gears are turning and there is no oil reaching the output shaft. So we have the output shaft turning with no lubrication if the truck is being towed. I would not like to tow a vehicle any more than a kilometre with no oil being fed to the output shaft.
Here is a quote from the Owners Manual of my Sierra RWD pickup truck "Two wheel drive vehicles should not be towed with all four wheels on the ground. Two wheel drive transmissions have no provisions for internal lubrication while being towed."
With 4WD and the transfer case in neutral, the tranny output shaft is not turning and the truck can be towed.
To add to my original post, the release bearing is not rotating if the engine is not rotating, so there is no concern about damage to the release bearing if the truck is towed with the clutch pedal depressed.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Towing RWD Manual Tranny Trucks. [Re: George7941] #4752687
05/10/18 07:02 AM
05/10/18 07:02 AM
stl
MarkM66 Offline
MarkM66  Offline
stl
Does transmission fluid leak out when the driveshaft is removed, and front of vehicle raised up?
Re: Towing RWD Manual Tranny Trucks. [Re: MarkM66] #4752714
05/10/18 07:33 AM
05/10/18 07:33 AM
Toronto, Canada
Toronto, Canada
In the specific case I was discussing - medium duty trucks - no, because the driveshafts are multipiece, there are three or even four shafts coupled together and the rearmost shaft, which is being disconnected, just slides out of the stand alone slip joint which has grease in it.
It would be an issue with my Sierra pickup where the one-piece shaft slides into the rear of the transmission. With light duty vehicles they do not bother disconnecting driveshafts, they use tow dollies if necessary. Now, with more rollback tow trucks, they just load the entire vehicle on to the tow truck.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Towing RWD Manual Tranny Trucks. [Re: Olas] #4752794
05/10/18 08:48 AM
05/10/18 08:48 AM
Toronto, Canada
Toronto, Canada
This is from the video Shannow posted in the Synchromesh Explained thread. This picture should help understand how the output shaft is lubricated.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Towing RWD Manual Tranny Trucks. [Re: George7941] #4752905
05/10/18 10:15 AM
05/10/18 10:15 AM
Detroit
Kurtatron Offline
Kurtatron  Offline
Detroit
So does that mean driving a 2wd rwd car in neutral with the clutch disengaged is in principal the same thing as towing in neutral?
Re: Towing RWD Manual Tranny Trucks. [Re: Kurtatron] #4752936
05/10/18 10:44 AM
05/10/18 10:44 AM
Guilford, CT
exranger06 Offline
exranger06  Offline
Guilford, CT
Basically, yes. However that's not really an issue, as it takes several miles of towing before any damage occurs, and you would never drive for several miles in neutral with the clutch disengaged.
2006 Ford Ranger Sport
1992 Honda Accord EX
2004 Honda CR-V LX - totaled
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: Towing RWD Manual Tranny Trucks. [Re: George7941] #4752947
05/10/18 10:58 AM
05/10/18 10:58 AM
Canuck living in California
KrisZ Online content
KrisZ  Online Content
What would anyone use neutral and keep the clutch disengaged at the same time?
2015 Dodge Grand Caravan-30k miles.
2007 Ford Focus ZX3-110k miles
2006 Mazda 3-168k miles
Re: Towing RWD Manual Tranny Trucks. [Re: KrisZ] #4752963
05/10/18 11:16 AM
05/10/18 11:16 AM
Guilford, CT
exranger06 Offline
exranger06  Offline
Guilford, CT
Exactly. Like I said, not a concern...
