Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
107 registered members (1WildPig, 2012AccentSE, ABerns, 2K2AcuraTL, 69Torino, 1leater, 8 invisible), 2,153 guests, and 150 spiders.
Topics286,196
Posts4,904,009
Members67,576
Most Online2,967
Mar 10th, 2019
2018 Honda Pilot #4751834
05/09/18 08:56 AM
05/09/18 08:56 AM
North Texas
ARB1977 Offline OP
ARB1977  Offline OP
North Texas
Does anyone know if the new 3.5L engine has a timing belt or chain? We maybe looking into one but for maintenance purposes Id like to stick to a chain, lol.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: 2018 Honda Pilot [Re: ARB1977] #4751846
05/09/18 09:12 AM
05/09/18 09:12 AM
Lake County, Ohio
ls973800 Offline
ls973800  Offline
Lake County, Ohio
Timing belt according to this source which shows the Pilot up until the 2017 model. The 2018 has the same engine
http://tbk-garage.timingbeltkit.com/honda-timing-belttiming-chain-complete-list/
Here's a good Pilot forum if you haven't seen it yet. covers the redesigned Pilot which came out as a 2016 model
http://www.piloteers.org/forums/114-2016-third-generation-pilot/
Re: 2018 Honda Pilot [Re: ARB1977] #4751848
05/09/18 09:13 AM
05/09/18 09:13 AM
Oklahoma
Schmoe Offline
Schmoe  Offline
Oklahoma
Belt. That's how they have that silky smooth power and quicker acceleration. All my V6's had belts. You can get that work done cheaper outside of a dealer. But, 105K trouble free miles and all you got to do is change out the belts, spark plugs and AT fluid isn't so bad.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
14 CRV EX-L (RIP) 2018 CRV EX-L
Re: 2018 Honda Pilot [Re: ARB1977] #4751858
05/09/18 09:23 AM
05/09/18 09:23 AM
Canada
nap Offline
nap  Offline
Canada
Belt. You may also see it like this: At 100k miles (and possibly 200k too), would you like to have a brand new belt (and tensioners and water pump to go with it if needed), or a timing chain in unknown status? laugh
Re: 2018 Honda Pilot [Re: ARB1977] #4751879
05/09/18 09:59 AM
05/09/18 09:59 AM
Canuck living in California
KrisZ Offline
KrisZ  Offline
Forget the belt, it's the least of your worries. Disable that dreaded VCM and save yourself engine and engine mount trouble. The engine mounts on the VCM equipped engines are stupidly expensive.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: 2018 Honda Pilot [Re: KrisZ] #4751934
05/09/18 11:24 AM
05/09/18 11:24 AM
Massachusetts
deven Offline
deven  Offline
Massachusetts
How do you disable VCM?
Proud user of ROYAL PURPLE products!
2016 Acura RLX Sports Hybrid(Royal Purple HPS 5w30 + M1-110 oil filter)
KEEP IT SIMPLE STUPID. IT'S ONLY OIL
Re: 2018 Honda Pilot [Re: ARB1977] #4751943
05/09/18 11:34 AM
05/09/18 11:34 AM
KrisZ Offline
KrisZ  Offline
One of the products is called VCM Muzzler that some members here use successfully. But I think other companies make a similar device as well.
Muzzler discussion
Re: 2018 Honda Pilot [Re: KrisZ] #4751949
05/09/18 11:48 AM
05/09/18 11:48 AM
Massachusetts
deven Offline
deven  Offline
Massachusetts
Muzzler discussion
Thanks!
Re: 2018 Honda Pilot [Re: Schmoe] #4751985
05/09/18 12:34 PM
05/09/18 12:34 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Chains "stretch" (wear), and can use replacement for optimal operation in long-lived vehicles.
Refreshing a few things at 100k is a given for any vehicle. The belt replacement is not that expensive. I just don't get why it's a boogeyman.
Re: 2018 Honda Pilot [Re: KrisZ] #4751991
05/09/18 12:35 PM
05/09/18 12:35 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Muzzler discussion
We have the VCMuzzler. I use it when we're driving the van longer highway distances (generally summertime and road trips) VCM does help a lot around town. I think it's prudent to run the system to some extent.
Re: 2018 Honda Pilot [Re: ARB1977] #4751993
05/09/18 12:37 PM
05/09/18 12:37 PM
Tri State Conservative
Zee09 Offline
Zee09  Offline
Every mechanic I know prefers belts.
I do as well.
And no they are not at the stealerships as they say here
"If I walked on water, they'd say I couldn't swim."
Re: 2018 Honda Pilot [Re: ARB1977] #4752007
05/09/18 12:50 PM
05/09/18 12:50 PM
San Rafael, CA
dogememe Offline
dogememe  Offline
San Rafael, CA
Never had a timing chain issue with any of my vehicles. I'm not a huge fan of belts which is why none of the vehicles I've ever owned had a belt. Timing belt job for mom's 95 Accord was over $900! Yeah, the water pump is changed then too but then again changing a water pump in a typical vehicle with a timing chain is usually easy, and with proper maintenance the timing chain will last forever, and never require replacement.
2010 Ford Escape 2.5 ~94K Miles: Royal Purple 5W-30 + Wix 51348
2008 Ford Crown Vic P71 4.6 ~167K Miles: AMSOIL SS 0W-30 + Wix 51372
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30 + ACDelco PF52
Re: 2018 Honda Pilot [Re: Zee09] #4752018
05/09/18 01:05 PM
05/09/18 01:05 PM
KrisZ Offline
KrisZ  Offline
I do as well.
Yes because they get to replace them and make money as regular maintenance.
I'm not opposed to timing belts, they have their advantages and disadvantages just like any engineering solution, but I'm not going to blindly praise it either.
Re: 2018 Honda Pilot [Re: dogememe] #4752050
05/09/18 01:58 PM
05/09/18 01:58 PM
Canada
nap Offline
nap  Offline
Canada
I propose the following experiment:
google search for
timing chain recall
then for
timing belt recall
(P.S. the Juke has a timing chain however it will show in the second search as some journalists used the wrong term).
Re: 2018 Honda Pilot [Re: KrisZ] #4752257
05/09/18 06:21 PM
05/09/18 06:21 PM
CA
The Critic Offline
The Critic  Offline
CA
I do as well.
Chains seem to be quite problematic these days. T-Belts are predictable and are less expensive to replace than chains.
2011 Toyota Prius 1.8L - 185K - SuperTech Dexos Full Syn 0W-20
2007 Honda Accord 2.4 - 135K - Mobil 1 EP HM 5W-30
