Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
100 registered members (4WD, 69Torino, 1.8Tango, 97prizm, 53' Stude, 11 invisible), 1,799 guests, and 42 spiders.
Topics296,895
Posts4,961,137
Members66,997
Most Online2,688
Jan 19th, 2019
New shocks and lift #4751806
05/09/18 07:21 AM
05/09/18 07:21 AM
socal
barkingspider Offline OP
socal
Went w new Bilstein shocks, the oem shocks had 83k miles on them, they were just about done. Makes a huge enough difference in ride quality, worth the extra cost. Lift 2.5 front (torsion key) and 1.5 rear (shackles).
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: New shocks and lift [Re: barkingspider] #4751845
05/09/18 08:12 AM
05/09/18 08:12 AM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
Good choice in shocks. Good photos. Stance looks great. Thanks for posting.
If you want the job done right......do it yourself.
Re: New shocks and lift [Re: barkingspider] #4751863
05/09/18 08:34 AM
05/09/18 08:34 AM
California
Dave1027 Online content
Dave1027  Online Content
California
Looks like that top shackle nut is barely on there. Maybe you should install longer bolts?
Re: New shocks and lift [Re: barkingspider] #4751868
05/09/18 08:45 AM
05/09/18 08:45 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Nice truck, but yeah, get the right length bolts ...
Re: New shocks and lift [Re: barkingspider] #4751872
05/09/18 08:52 AM
05/09/18 08:52 AM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
I do not see the point in lifting. Leave it the way the factory made it.
2015 Ford F250 w/Powerstroke
Re: New shocks and lift [Re: barkingspider] #4751873
05/09/18 08:53 AM
05/09/18 08:53 AM
Clinton Twp. MI
bradepb Offline
bradepb  Offline
Clinton Twp. MI
Yep nice truck,lets keep it that way with proper bolts! top and bottom. Also some blue loctite if you are reusing those locknuts.
Re: New shocks and lift [Re: Dave1027] #4751874
05/09/18 08:53 AM
05/09/18 08:53 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
If that nut is tight its not cool. Truck looks good though. thumbsup
Re: New shocks and lift [Re: barkingspider] #4751882
05/09/18 09:02 AM
05/09/18 09:02 AM
Lakeside, CA
Blkstanger Offline
Blkstanger  Offline
Lakeside, CA
Truck looks good with that much lift. Not over done like so many do.
99 Jeep WJ 4.7 195,000 Maxlife 10w30, Fram Ultra.
Re: New shocks and lift [Re: barkingspider] #4751891
05/09/18 09:11 AM
05/09/18 09:11 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
I look at your truck and my joints from the hips down twinge.
Thick oil is better grin2
Re: New shocks and lift [Re: barkingspider] #4751924
05/09/18 10:02 AM
05/09/18 10:02 AM
USA
slacktide_bitog Offline
USA
Nice thumbsup
Who made the OEM shocks?
Re: New shocks and lift [Re: barkingspider] #4751927
05/09/18 10:09 AM
05/09/18 10:09 AM
Phoenix, AZ
Nick1994 Online content
Nick1994  Online Content
Phoenix, AZ
Don't forget to get an alignment. With IFS, it'll change the toe.
2015 Hyundai Sonata 2.4L 90k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 232k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: New shocks and lift [Re: barkingspider] #4751994
05/09/18 11:37 AM
05/09/18 11:37 AM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
Guys... look at the original bolts. They are plenty long enough.
Now recall that suspension parts like spring shackles shouldn't be tightened until the wheels are back on and the weight is on the car/truck. That shackle is almost vertical and there's no wheel on the other side, so you can logically conclude and assume the rear of the truck is still in the air and that at the time the pic was taken, he wasn't done yet. Jeez.
Re: New shocks and lift [Re: barkingspider] #4752002
05/09/18 11:43 AM
05/09/18 11:43 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
So you've used the same length shocks and mounting points, but have cranked the front springs up a couple inches and re-positioned the rear springs? Isn't the suspension pretty much topped out now? Or was the truck riding around near the bottom of its travel before?
On my old Tracker, a cheap off-road trick was too install longer travel rear shocks to get more rear articulation, perhaps you should do the same?
07 Focus ZXW, 5spd manual, 218km M1 5W30
18 Outback 2.5 CVT 15km 0W20
Re: New shocks and lift [Re: barkingspider] #4752052
05/09/18 01:00 PM
05/09/18 01:00 PM
socal
socal
Photo was taken before I torqued the nut down. Its the stock hardware so its plenty. Thanks bottom feeder. The lift kit came w spacers for the front shocks (1st pic) and spacers to drop the front diff (2nd pic). And yes, I did get an alignment . No need to get longer shocks, rides like stock.
