Brake Caliper Dampers?
by HangFire. 01/18/19 11:32 AM
Fully Formulated Coolant and old radiator
by Wheel. 01/18/19 11:27 AM
'15 6.7 Powerstroke UOA
by roadrunner1. 01/18/19 10:18 AM
Automotive Battery Voltage -What is ur reading?
by Patrick0525. 01/18/19 10:10 AM
Amsoil 0w-40 vs 5w-40
by Buddyp. 01/18/19 10:07 AM
M1 is changing their oils, site and adding a new oil
by Flashlightboy. 01/18/19 10:01 AM
Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
94 registered members (andyd, 69GTX, aquariuscsm, 2019StingrayZ51, badtlc, 10 invisible), 2,188 guests, and 46 spiders.
Topics296,781
Posts4,958,818
Members66,969
Most Online2,577
Jan 14th, 2019
Break in oils/procedures for new head/cam/valves/ #4751699
05/09/18 01:58 AM
05/09/18 01:58 AM
Manchester, England
Olas Offline OP
Olas  Offline OP
Manchester, England
Hello Everyone,
I have a question and I think I know the answer but want to clarify & confirm
I bought a used engine from eBay and pulled the head off, sent it for porting/polishing/bigger valves/worked manifolds etc. I also sent a USED camshaft to be included in the build and the valve lash has been set using solid shims which are NEW parts.
Does this combination of new&used valve train parts have any special requirements or techniques for running in? Or just drive it like normal and change the oil after a couple of hundred miles?
Looking forward to your responses
Cable ties should hold it
Re: Break in oils/procedures for new head/cam/valves/ [Re: Olas] #4751701
05/09/18 02:18 AM
05/09/18 02:18 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
If it was flat tappet, then you are likely doomed to fail.
Wife's Captiva had a recall for bad rocker arms, which they were prepared to install on the old cam (fine really, not flat tappets)...they had to do the cam as well, so it's new cam/new lifters...half way through an OCI, and the tech said not to bother changing it early.
Which was fine by me, used oil has more reactive additives.
Re: Break in oils/procedures for new head/cam/valves/ [Re: Olas] #4751724
05/09/18 04:40 AM
05/09/18 04:40 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
The cam shouldn't be a problem but I would use some assembly lube on all the parts and lobes. Use a little zinc additive in the oil and bring the RPM up to about 2K for 15-20 min and it will be fine.
If this is a VW vacuum fill the cooling system so you don't have the bleeding fiasco and overheating issues. Leave the oil in for 1K then change it.
Re: Break in oils/procedures for new head/cam/valves/ [Re: Olas] #4751740
05/09/18 05:14 AM
05/09/18 05:14 AM
West Yorkshire, UK
NGRhodes Offline
NGRhodes  Offline
West Yorkshire, UK
Get instructions from your builder to avoid invalidating any warranty due to following incorrect break in procedure.
Re: Break in oils/procedures for new head/cam/valves/ [Re: Trav] #4751852
05/09/18 08:16 AM
05/09/18 08:16 AM
Rabbit Creek, Alaska
jayg Offline
jayg  Offline
Just curious why you do a cam break in procedure on a used cam? It obviously doesn’t hurt it but if the lobes already have wear in, he should be able just to turn it on and go.
2018 Ford Ecosport AWD- Napa 0w20
2017 Ram 1500 Ecodiesel- CP Triton ECT 5w40
1973 Datsun 240Z 10w30- VWC from '73
1973 Triumph Bonneville 750- M1 5w50
1967 BSA 441 Victor Special- M1 5w50
Re: Break in oils/procedures for new head/cam/valves/ [Re: Olas] #4751861
05/09/18 08:32 AM
05/09/18 08:32 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
The discussion does not sound like a flat tappet. More like an overhead cam with shim adjusters ... If that's the case, I would not be overly concerned. But ...
You are have some serious head work done. That means you are bumping the HP and likely moving the Tq peak up the RPM range. Which will put extra stress on the cam and valve train. So the question is have you made allowances for additional oiling?
Re: Break in oils/procedures for new head/cam/valves/ [Re: jayg] #4751883
05/09/18 09:03 AM
05/09/18 09:03 AM
Trav Offline
Trav  Offline
He said addition work with the valves was done its possible they used heavier springs that could put additional stress on the lobes.
New shims may look nice and shiny but they need some run in time also to match. Its usually no problem but I do anything I can to help old parts wear in to new parts, assy lube is cheap insurance.
VW have no oiling issues that I am aware of on the top end.
Re: Break in oils/procedures for new head/cam/valves/ [Re: Olas] #4751958
05/09/18 10:57 AM
05/09/18 10:57 AM
Manchester, England
Olas Offline OP
Olas  Offline OP
Manchester, England
I was thinking of buying a qt. of Redline Race oil and lubing the top end with it just before fitting the valve cover and starting it up for the first time but assembly lube will stick better if it doesn't fire on the first turn.
Wold it be worth changing the oil just before the head swap to minimise particulates or is it the case that if they're small enough to pass the filter they won't do any measurable damage?
Thanks for your input
Re: Break in oils/procedures for new head/cam/valves/ [Re: Trav] #4751997
05/09/18 11:40 AM
05/09/18 11:40 AM
jayg Offline
jayg  Offline
For sure, I would run assembly lube and a zinc additive for the for quick change if it's an old vehicle without sensitive emissions equipment (hopefully since it's getting this much head work cool ).
Re: Break in oils/procedures for new head/cam/valves/ [Re: NGRhodes] #4752006
05/09/18 11:47 AM
05/09/18 11:47 AM
Cajun Country, La.
BlueOvalFitter Offline
Cajun Country, La.
^^^ THIS!!!!!^^^
Re: Break in oils/procedures for new head/cam/valves/ [Re: BlueOvalFitter] #4752110
05/09/18 02:25 PM
05/09/18 02:25 PM
Trav Offline
Trav  Offline
I think he is the builder, just a shop doing the machine work.
Re: Break in oils/procedures for new head/cam/valves/ [Re: Trav] #4752113
05/09/18 02:27 PM
05/09/18 02:27 PM
West Yorkshire, UK
NGRhodes Offline
NGRhodes  Offline
West Yorkshire, UK
I meant those that did the head work.
Re: Break in oils/procedures for new head/cam/valves/ [Re: NGRhodes] #4752603
05/10/18 05:03 AM
05/10/18 05:03 AM
Trav Offline
Trav  Offline
I don't know about machine shops in the UK but here they usually don't make any recommendations (at least in writing), they leave that up to you they dont want to held responsible if something goes afoul.
Remember this is a country where a old woman spilled coffee on her crotch and sued McDonald's because the coffee was hot and won 2.8 million. duh
