Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
120 registered members (77GrandPrix, 4WD, 2015_PSD, 01rangerxl, 87sammy, 10 invisible), 1,788 guests, and 59 spiders.
Topics286,092
Posts4,902,385
Members67,560
Most Online2,967
Mar 10th, 2019
Aisin ATF A750E/F - V5AWF #4751312
05/08/18 04:17 PM
05/08/18 04:17 PM
Norway
4M41V5AWF Offline OP
Norway
I have an Aisin (warner?) automatic transmission in my Mitsubishi called V5AWF, I believe this is the same as the Aisin A750E/F transmission.
What ATF fluid can i use in this transmission? How picky are transmissions on what oil being used?
Mitsubishi have their own OEM DIA QUEEN ATF PA oil - RAVENOL have a "special" V5AWF MM-PA oil but both of these are quite expansive.
What about the VALVOLINE ATF AW oil for Aisin transmissions? How can you tell what the differences in the oil's are? And would there be a different oil in the transmission depending on if the A/T have a cooler or not?
Re: Aisin ATF A750E/F - V5AWF [Re: 4M41V5AWF] #4751376
05/08/18 05:29 PM
05/08/18 05:29 PM
California
nthach Offline
nthach  Offline
California
Aisin wouldn't make a version of their transmission to meet a OEM's desire to use a certain fluid.
With that said, if it takes a Toyota T-IV/JWS3309 or ATF WS/JWS3324 compliant fluid, you can use fluid that meets those specs, I'm not sure about Norway but many users here in the US have used Valvoline MaxLife with success in Aisin transmissions. If that Valvoline fluid is the same, I think that will work. I also know Volvo uses Aisin transmissions and there should be easy availability of JWS3309/3324 fluids in Norway if Volvos are as big over there(and given that Sweden is a neighbor).
The oil type will not be different - the capacity will be depending if you have a cooler or not.
Re: Aisin ATF A750E/F - V5AWF [Re: 4M41V5AWF] #4751796
05/09/18 08:02 AM
05/09/18 08:02 AM
Nashville, TN via Memphis
john_pifer Offline
john_pifer  Offline
I have the A750E in my 2007 Tacoma PreRunner. Good gearbox. Just rolled over 201,000 miles on it and did a complete fluid exchange for the 2nd time. Used Toyota WS fluid both times. Expensive stuff. I've also heard of people using Maxlife, as well as Amsoil.
16 WRX - PPPP
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 208K
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
