What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
117 registered members (badtlc, avi1777, 97f150, Bailes1992, AdditiveOCD, 13 invisible), 2,209 guests, and 56 spiders.
Topics286,394
Posts4,907,473
Members67,614
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Cleaning a cat. Or how to fix a P0420 code? #4751074
05/08/18 12:15 PM
05/08/18 12:15 PM
Illinois
SHOZ Offline OP
SHOZ  Offline OP
Illinois
I've been getting the P0420 code on my Hyundai Accent(159k miles) it comes and goes on it's own, especially after some hard driving where the check engine light will go out. So I've decided to try and clean the cat.
I monitor the O2 voltage and you can see it does not work like a new one as it will more closely follow the primary 02 voltage rather than stay high like it should when cruising.
I took the primary O2 out. The cat hangs vertical. Then poured 2L of lacquer cleaner through it. Put O2 back in and then after a couple hours poured another L of the thinner.
My plan now is to let it sit overnight, then take the O2 out again and let it sit another 24 hours. Then put it back together, start it up and hope I don't blowout the cats and muffler......
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Cleaning a cat. Or how to fix a P0420 code? [Re: SHOZ] #4751081
05/08/18 12:21 PM
05/08/18 12:21 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
I'd suggest wearing a long sleeve shirt before cleaning your cat
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Cleaning a cat. Or how to fix a P0420 code? [Re: Nick1994] #4751083
05/08/18 12:25 PM
05/08/18 12:25 PM
Phoenix, Arizona - USA
SirTanon Online content
SirTanon  Online Content
Where at least 2 of my cats are involved, chain mail or kevlar would be a more appropriate choice.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 271,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 62,000mi
Re: Cleaning a cat. Or how to fix a P0420 code? [Re: SHOZ] #4751086
05/08/18 12:29 PM
05/08/18 12:29 PM
NJ
irad Offline
irad  Offline
NJ
I did the same thing except I sprayed throttle body cleaner in through the O2 port instead of lacquer cleaner. Probably does not matter which you use. I then ran the car for a minute. Let it cool, then I removed the O2 sensor and poured distilled water in. I then ran the car until all the steam stopped coming out. It worked. I thought of the water because some people clean the intake valves and piston tops by putting water mist through the intake.
Re: Cleaning a cat. Or how to fix a P0420 code? [Re: SHOZ] #4751096
05/08/18 12:35 PM
05/08/18 12:35 PM
Santa Barbara, CA
bdcardinal Online content
bdcardinal  Online Content
Santa Barbara, CA
Or you could stack 2 spark plug non foulers, drill out the top one, and thread them between the cat and the cat monitor sensor.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Cleaning a cat. Or how to fix a P0420 code? [Re: SHOZ] #4751099
05/08/18 12:37 PM
05/08/18 12:37 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
I read a thread on here that mentioned using caustic soda or something of that nature, I wish I had booked marked it.
If a solvent dip could fix a cat, there would not be nearly as many cars in the boneyard.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Cleaning a cat. Or how to fix a P0420 code? [Re: SHOZ] #4751117
05/08/18 12:53 PM
05/08/18 12:53 PM
NY, USA, etc.
oilpsi2high Offline
oilpsi2high  Offline
NY, USA, etc.
You can't "clean" a cat unless it's clogged with oil. More often than not, the honey comb inside melts. You can't unmelt the metal.
You can either hollow it out and use an o2 anti-fouler and pray that the code goes away, or fix it the right way by replacing the cat.
Re: Cleaning a cat. Or how to fix a P0420 code? [Re: maxdustington] #4751127
05/08/18 01:03 PM
05/08/18 01:03 PM
Illinois
SHOZ Offline OP
SHOZ  Offline OP
Illinois
Hmm, I buy caustic soda in bulk. It is a great carbon remover. But the cat is still on the car and would need a good water flushing to get rid of the caustic.
Re: Cleaning a cat. Or how to fix a P0420 code? [Re: Nick1994] #4751130
05/08/18 01:08 PM
05/08/18 01:08 PM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
My cat is self cleaning except for a few hair balls here and there.
2015 Ford F250 w/Powerstroke
Re: Cleaning a cat. Or how to fix a P0420 code? [Re: oilpsi2high] #4751136
05/08/18 01:17 PM
05/08/18 01:17 PM
Connecticut, USA
bmwpowere36m3 Offline
Connecticut, USA
+1
You can "hack it", but I'd be preparing to replace if the car requires emissions testing...
Re: Cleaning a cat. Or how to fix a P0420 code? [Re: SHOZ] #4751142
05/08/18 01:21 PM
05/08/18 01:21 PM
Olathe, KS
CARJ Offline
CARJ  Offline
Olathe, KS
Have you ever replaced your O2 sensors?
2004 Toyota 4Runner | 184k | PPHM 5w-30, YZZD3
2012 VW Passat | 88k | PPHM/Redline 5w-30, XG9911
1997 Honda Civic HX | 217k | Redline 5w-30, XG3593a
Re: Cleaning a cat. Or how to fix a P0420 code? [Re: SHOZ] #4751148
05/08/18 01:24 PM
05/08/18 01:24 PM
... or you could do what Scotty Kilmer says (I certainly wouldn't, but whatever), and do this:
Re: Cleaning a cat. Or how to fix a P0420 code? [Re: SHOZ] #4751198
05/08/18 02:23 PM
05/08/18 02:23 PM
Michigan
MrHorspwer Offline
MrHorspwer  Offline
Michigan
An appropriate retort to anything Scotty Kilmer says:
Re: Cleaning a cat. Or how to fix a P0420 code? [Re: SHOZ] #4751262
05/08/18 03:22 PM
05/08/18 03:22 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Like any plating once its gone its gone its gone you can clean it till you are blue in the face but its not coming back. The amount of wash coat is one of the big differences between OE and aftermarket.
Unfortunately this one of those times you cant put Humpty Dumpty back together.
Re: Cleaning a cat. Or how to fix a P0420 code? [Re: SHOZ] #4751316
05/08/18 04:19 PM
05/08/18 04:19 PM
Alberta, Canada
Smokescreen Offline
Smokescreen  Offline
Alberta, Canada
crackmeup MrHorspwer, that made my day !!!
13 Civic Si 2.4L- 69Kkms(43Kmi)-PP,Wix
05 LeSabre 3.8L-210Kkms(134Kmi)-PP,Wix
03 Sierra 2500 6.0L-204Kkms(127Kmi)-PP,Wix
All with mpg > EPA
Page 1 of 3 1 2 3
