Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
Starter cross reference?
by dlundblad. 01/22/19 05:11 AM
Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
How cold is it? (Humor)
by StevieC. 01/21/19 07:13 PM
Slight performance decrease
by A_User55555. 01/21/19 06:54 PM
Binco, Coolbreez1973, jmcast1127, DF8005, FT86dude11
67009 Registered Users
108 registered members (53' Stude, 4WD, alteredtuning990, 2strokeNorthstar, AandPDan, 11 invisible), 1,727 guests, and 32 spiders.
Topics296,966
Posts4,962,526
Members67,009
Most Online2,821
Jan 21st, 2019
Best welder for automotive body panel replacement? #4750247
05/07/18 02:13 PM
05/07/18 02:13 PM
NY, USA, etc.
oilpsi2high Offline OP
NY, USA, etc.
My truck has a few holes in the truck bed from where water collected under the plastic drop-in bedliner.
I'd like to weld in a sheet metal patch since the rest of the bed is in good shape. What's the best welder for accomplishing this task?
I'd prefer not to have to rely on gas if at all possible.
Would something like this work?
https://www.harborfreight.com/Flux-125-Welder-63582.html?ccdenc=eyJjb2RlIjoiMTQ4MjAwMzAiLCJza3UiOiI2MzU4MiIsImlzIjoiODkuOTkiLCJwcm9kdWN0X2lk%0D%0AIjoiMTIzMTIifQ%3D%3D%0D%0A
Thanks for any help.
Re: Best welder for automotive body panel replacement? [Re: oilpsi2high] #4750256
05/07/18 02:22 PM
05/07/18 02:22 PM
NY, USA, etc.
NY, USA, etc.
Could you weld body panels with something like this?
https://www.harborfreight.com/oxygen-and-acetylene-welding-kit-98958.html
Re: Best welder for automotive body panel replacement? [Re: oilpsi2high] #4750263
05/07/18 02:32 PM
05/07/18 02:32 PM
Chicago
Jooksing Offline
Jooksing  Offline
Chicago
"best" will be subjective. In your case, for small amount of welding it will probably do. Just need to spend more time to grind welds clean. Usually best and harbor freight will not run in the same sentence.
Re: Best welder for automotive body panel replacement? [Re: oilpsi2high] #4750265
05/07/18 02:32 PM
05/07/18 02:32 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
I've done welding on an exhaust system with a welder like the first one. I don't think you'll get good quality welds on body panels. You'd probably need to step up to harbor frieght's better line (Vulcan), but I'll let others chime in.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Best welder for automotive body panel replacement? [Re: oilpsi2high] #4750273
05/07/18 02:40 PM
05/07/18 02:40 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
It's easier learning with the flux welder, and safer too.
Re: Best welder for automotive body panel replacement? [Re: oilpsi2high] #4750280
05/07/18 02:51 PM
05/07/18 02:51 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
If its only a small amount of pieces you can just braze it as long as it not structural. A small torch set with a small tip will do the job with no problems you just have to go slow and keep the rest of the panel cool to prevent distortion. when I started out this is what we used, mig welder were no practical due to their size and huge cost.
Having a smoke wrench and cutting torch are added useful benefits.
You only need brazing goggles and gloves, the brazing rods are fluxed.
I do a lot of it and use a MillerMatic 211 inverter with steel mix gas from Airgas, the 211 can do 120v for thin sheet metal and 240v for thicker stuff but its not cheap.
The additional cost like a cart, helmet and gas bottle can add up the price of a small gas set alone.
Re: Best welder for automotive body panel replacement? [Re: oilpsi2high] #4750352
05/07/18 04:19 PM
05/07/18 04:19 PM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
Unless you want to learn how to weld, get an auto body shop do the welding. Some smaller auto body shops do rust repair, others do not want to touch rust.
Mig welding is easier than stick but still will take some time to learn.
2015 Ford F250 w/Powerstroke
Re: Best welder for automotive body panel replacement? [Re: oilpsi2high] #4750398
05/07/18 05:19 PM
05/07/18 05:19 PM
ME
eljefino Offline
eljefino  Offline
ME
Alternatively you can pop_rivet the patches in, or perhaps even get some body adhesive to stick between the sandwiched parts.
If you've never welded before, sheet metal is not the thing to practice on. You aren't "shooting glue", you're "shooting holes" and just hoping that the edges of the holes fall in on themselves.
Re: Best welder for automotive body panel replacement? [Re: oilpsi2high] #4750439
05/07/18 05:59 PM
05/07/18 05:59 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
The sheet metal of a bed of a truck is probably too thin for a beginner to weld.
Brazing is easy for a beginner to do a good enough job, but it will not look pretty. You will want to clean up the results and paint or use undercoat on it. If you have a bed liner to hide the area you brazed then brazing would be OK.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Best welder for automotive body panel replacement? [Re: oilpsi2high] #4750463
05/07/18 06:14 PM
05/07/18 06:14 PM
Prospect, KY
spk2000 Offline
spk2000  Offline
Prospect, KY
Take it to a shop for $50-100 you will be done and not need to buy anything. The thin sheet metal will be quite a challenge and you will likely do more damage than good. TIG would be my choice for welding this. We use mostly MIG weld in production as it is much faster but not quite as good at repairs as TIG. Novice welders generally cannot TIG weld that good.
96 Grand Marquis
01 Sable LS
02 Montero
Re: Best welder for automotive body panel replacement? [Re: oilpsi2high] #4750476
05/07/18 06:27 PM
05/07/18 06:27 PM
USA
NHGUY Offline
NHGUY  Offline
USA
Panel adhesive is a good alternative for non structural repairs.Its not cheap and you need to buy the dispensing gun too though.
Re: Best welder for automotive body panel replacement? [Re: oilpsi2high] #4750579
05/07/18 07:41 PM
05/07/18 07:41 PM
IL
Vern_in_IL Offline
Vern_in_IL  Offline
IL
Some cars today are using high strength steel that cannot be welded.
Re: Best welder for automotive body panel replacement? [Re: oilpsi2high] #4750745
05/07/18 11:40 PM
05/07/18 11:40 PM
Los Gatos CA
djb Offline
djb  Offline
Los Gatos CA
The flux wire welder will be the least expensive way to start. With a few minutes of practice on similar thickness sheets you'll be able to produce ugly tack welds. Then you can use a grinder to obliterate the worst looking parts.
You shouldn't expect a void-free seam weld that lays flat.
A gas setup will cost much more since you'll need to buy or rent tanks, and have them filled. Unless you are simply brazing, you'll need lots of practice to make a functional weld.
With both you'll need clean, solid metal that is nearly perfectly mated to start with. If you want to start with rusty metal, an AC stick welder will make "farmer" ugly-but-functional welds. Or burn through.
Re: Best welder for automotive body panel replacement? [Re: JimPghPA] #4750788
05/08/18 04:25 AM
05/08/18 04:25 AM
Trav Offline
Trav  Offline
If I were to braze it I would cut the surrounding area out like always then use a panel flanger, make a template so it fits with a small space all the way around then braze it. a few passes with a coarse grit flap wheel on a grinder will clean it up nicely.
A little filler and primer and its good to go.
It creates a flange and can punch holes for rivets to hold it in place, they work great. HF probably has a cheap version but they don't cost a lot to begin with.
https://www.amazon.com/dp/B007QV7WW0/ref...p;pd_rd_w=A8GeS
Re: Best welder for automotive body panel replacement? [Re: oilpsi2high] #4750792
05/08/18 04:39 AM
05/08/18 04:39 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Flange welds with gas are very, very easy. Essentially they weld themselves, and you don't need to manipulate filler rods, BUT gas gear is prohibitively expensive, and the appearance of a flange weld won't be acceptable in all applications.
Since it was the only weld I could do well, I redesigned the underside of my rotted-out Marina to use flange welds, since I had the use of army gas welding gear. MOT tester didn't like the novelty and, in defiance of the regulations, spent quite a long time hitting it with quite a big hammer. He got tired eventually.
I havn't tried flange welds with any other gear (though I have used MIG). I'd guess that they'd probably be almost as easy with TIG, since its like "electric gas welding", but TIG aint cheap either.
For the application you describe I probably wouldn't bother. Holes are natures way of improving drainage. Might patch with aluminium located with self-tappers, pop-rivets, and/or epoxy.
I dunno if you can get it hot enough for a good braze with just a blow-torch. Those twin-carbon arc gizmo's were cheap and might be worth trying if you can find one, but they seem to have gone out of style.
