Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
92 registered members (69Torino, 69GTX, ammolab, A310, 4WD, 1.8Tango, 10 invisible), 1,804 guests, and 44 spiders.
Topics296,895
Posts4,961,144
Members66,997
Most Online2,688
Jan 19th, 2019
Noack Volatility? #4750093
05/07/18 10:52 AM
05/07/18 10:52 AM
Cajun Country, La.
BlueOvalFitter Offline OP
Cajun Country, La.
How important is Noack Volatility in the quality of motor oils today? Is it more important in synthetic motor oils than in conventional motor oils? Now that our more modern engines have DI, turbo's, and increased horse power, the extra heat has to wreak more havoc on the engine oil. How would the Noack Volatility testing help with these extra heat contributors?
Re: Noack Volatility? [Re: BlueOvalFitter] #4750225
05/07/18 01:38 PM
05/07/18 01:38 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Biggest effect high NOACK has is burning off lighter parts of the oil, leaving thicker stuff behind, requiring more top offs and potentially causing carbon in the combustion chamber.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Noack Volatility? [Re: bullwinkle] #4750252
05/07/18 02:19 PM
05/07/18 02:19 PM
Cajun Country, La.
Cajun Country, La.
In that case, you would think it would be wiser to choose an oil for a DI engine with a lower Noack number over, say, a required 5W30 oil, right? ???
I did a GOOGLE search about it and found this;
http://www.perkinelmer.com/CMSResources/...lVolatility.pdf
Re: Noack Volatility? [Re: BlueOvalFitter] #4750308
05/07/18 03:30 PM
05/07/18 03:30 PM
Danh Offline
Danh  Offline
Some engine oil makers say they donít disclose Noack volatility because the results are imprecise and hard to repeat, as suggested in the article you attached. So I wouldnít place too much emphasis on that measure.
And while engines are getting more sophisticated and power dense, it doesnít necessarily follow that oil temps are higher: they still broadly follow coolant temperature unless the use is extreme.
I donít think you can go wrong with one of the major brands; maybe stick with a dexos1Gen2 and/or SN Plus. If you want to go a step further you may want to look at MSDS documents to see how much PAO/GTL is used, which tend to contribute to better Noack results. Some Mobil1 products are PAO rich and we know Pennzoil is a big GTL user.
Re: Noack Volatility? [Re: BlueOvalFitter] #4750334
05/07/18 03:56 PM
05/07/18 03:56 PM
sonoma
burla Online content
burla  Online Content
sonoma
Depends on how the NOACK numbers are achieved, if the low NOACK was achieved by dumping in a bunch of Vii's it is a temporary number dependent on when those very vii's shear off, if the NOACK is achieved by group 4/5 base oil the NOACK is closer to a stable number.
Re: Noack Volatility? [Re: Danh] #4750346
05/07/18 04:15 PM
05/07/18 04:15 PM
Cajun Country, La.
Cajun Country, La.
Does Pennzoil have the advantage over other brands being it uses GTL decisively? How about AMSOIL?
Re: Noack Volatility? [Re: BlueOvalFitter] #4750395
05/07/18 05:17 PM
05/07/18 05:17 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
NOACK volatility is a good indicator for how clean it will keep the rings and turbocharger. Places where the oil gets extremely hot (north of 400F). The less that burns off, the less deposits form. Generally, the lighter the baseoil, the more it burns off.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: EDGE 0W-30
Re: Noack Volatility? [Re: BlueOvalFitter] #4750422
05/07/18 05:38 PM
05/07/18 05:38 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Pennzoil (PYB 5W20) did have some awesome NOACK numbers, for a while (2013), as reported by PQIA-but not anymore:
http://www.pqiamerica.com/Feb2014/consolidated5w20ALL.html
DI engines seem to be a special case, the jury is still out (other than 2nd Gen. Dexos).
Re: Noack Volatility? [Re: BlueOvalFitter] #4750679
05/07/18 09:23 PM
05/07/18 09:23 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
I have a thread in this forum comparing the major brands in 5W-30, and they all were around 11% NOACK and lower, which is pretty good since you'll never find much out there that's 7% or less.
https://www.bobistheoilguy.com/forums/ub...-30#Post4745039
Re: Noack Volatility? [Re: ZeeOSix] #4750807
05/08/18 05:08 AM
05/08/18 05:08 AM
Cajun Country, La.
Cajun Country, La.
Thanks Z06, I missed that thread.
I see the PP/PUP has the lowest Noack # in that chart.
What do you use in your Z06 'Vette, if you don't mind me asking?
Re: Noack Volatility? [Re: BlueOvalFitter] #4750821
05/08/18 05:41 AM
05/08/18 05:41 AM
New England
Virtus_Probi Offline
New England
I believe that PP NOACK loss is for the obsolete dexos1 5W30 product...I have no reason to suspect that their d1G2 offering will be a lot different, but I haven't seen a test result for it yet and SOPUS doesn't share that info in the PDS.
The PQIA reported the NOACK loss for M1 5W30 AP as 8.5%, just in case you feel like spending $40 for a jug of oil! If you are looking to spend even more, you can get M1 5W30 ESP or try Ravenol's 5W30 DXG, both around 6% NOACK loss and maybe about $50 for 5l.
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: Noack Volatility? [Re: BlueOvalFitter] #4751163
05/08/18 12:41 PM
05/08/18 12:41 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Mobil 1 full synthetic, same as the factory fill. Wanted to try something different to see if the engine sounds any different.
Re: Noack Volatility? [Re: Virtus_Probi] #4751636
05/08/18 09:16 PM
05/08/18 09:16 PM
Pennsylbammyvania
dailydriver Offline
dailydriver  Offline
Pennsylbammyvania
I will happily GLADLY pay well OVER $50.00 for a 5L jug of the D1G2 DXG when it is available! wink
BTW; Most places get ~ $13.19/quart for the 5W-30 ESP Formula, but yes, depending on how much you buy at a time online, that can go down to ~$8.50/quart. (Does XOM even bottle it in 5 quart jugs?)
2016 Ford Fiesta ST 14K miles
Ravenol DXG 5W-30
Amsoil Ea15K51 filter
Ravenol MTF-2 in the IB6 transaxle
Re: Noack Volatility? [Re: dailydriver] #4751762
05/09/18 05:50 AM
05/09/18 05:50 AM
New England
New England
I can't remember the exact deal I got on ESP, something like $100 for 12 liters on Amazon...all I know is that it was under $10/l. This was a while ago and I think it was more expensive there the last time I looked...I have noticed that 4l or 5l jugs are available in Europe, but have never seen them in a shop or on Amazon here.
I'm with you on the Ravenol, interested to try it even at the present Amazon prices. Just need d1G2 to show up!
Last Change;
M1 0W30 AFE d1G2
Re: Noack Volatility? [Re: Virtus_Probi] #4769236
05/27/18 06:50 AM
05/27/18 06:50 AM
MA
PWMDMD Offline
PWMDMD  Offline
MA
I donít know why Iím so intrigued with Ravenol but I am - I donít know why Iím so intrigued with freaking engine oil but here I am. Does anyone have any idea when Ravenol 0W-20 DFE will be available in the US? Itís listed on the Ravenol America website but has no price and can not be added to the cart.
One of the areas where I think Ravenol does a poor job is in their marketing. The three different varieties of 0W-20 come in the same container, use virtually the same language in their description, seem to be a similar formulation and while I guess theyíre specifications are different, itís not until you see their spec sheets side-by-side you see any obvious differences in the products.
Current: 2018 Honda Pilot Touring (Mobil 1 EP 0W-20 and Fram ULTRA XG7317) and 2014 Mazda5 (Ravenol ECS 0W-20 and Fram ULTRA XG3614)
